[fc6]problem Na Poziomie Configure
woody91
Podczas wywoywania komendy ./configure wszystko jest ok, az do tego momentu:
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
Co jest nie tak?
dalej nic :).
Dodano:
Chociaz nie. Zupdateowalem kilka pakietow, ale teraz wywala mi:
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
dzieki, ale to nie to :).
[cox@localhost xmms-scrobbler-0.3.6]$ ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for a sed that does not truncate output... /bin/sed
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for f95... f95
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether f95 accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag  works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for f95 option to produce PIC... -fPIC
checking if f95 PIC flag -fPIC works... yes
checking if f95 supports -c -o file.o... yes
checking whether the f95 linker (/usr/bin/ld) supports shared libraries... yes
checking whether byte ordering is bigendian... no
checking for long... yes
checking size of long... 4
checking if XMMS plugin is to be built... yes
checking for glib-config... /usr/bin/glib-config
checking for GLIB - version >= 1.2.2... yes
checking for xmms-config... /usr/bin/xmms-config
checking for gawk... (cached) gawk
checking for XMMS - version >= 1.2.4... yes
checking if BMP plugin is to be built... yes
checking for pkg-config... /usr/bin/pkg-config
checking for glib-2.0 >= 2.4.0 gtk+-2.0 >= 2.4.0... configure: WARNING: *** GLIB >= 2.4.0 or GTK+ >= 2.4.0 not installed - please install first ***
checking for bmp >= 0.9.7... configure: WARNING: *** BMP >= 0.9.7rc2 not installed - please install first ***
checking whether to prefer APE to ID3v2... no
checking curl/curl.h usability... no
checking curl/curl.h presence... no
checking for curl/curl.h... no
configure: error: *** unable to find libcurl headers
raczej to, bo poszedłeś dalej... :)
Zwróć uwagę:
i na to:
Wszytko jak na dłoni czego brakuje teraz.... :)
sudo yum install libcurl
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
core                      100% |=========================| 1.1 kB    00:00
livna                     100% |=========================| 1.1 kB    00:00
flash                     100% |=========================|  951 B    00:00
jpackage-fedora           100% |=========================|  951 B    00:00
jpackage-generic          100% |=========================|  951 B    00:00
extras                    100% |=========================| 1.1 kB    00:00
updates                   100% |=========================| 1.2 kB    00:00
No Match for argument: libcurl
Nothing to do
sudo yum install libmusicbrainz
Nothing to do
BTW. Skad wiecie jak nazywaja sie te wszystkie pakiety?
