harpii Napisano Maj 14, 2007 Zgłoszenie Share Napisano Maj 14, 2007 Witam ,próbuje zainstalować to draństwo i nie bardzo mi idzie... Próbowałem wg tego http://forum.fedora.pl/index.php?showtopic=11290 ale mam wrażenie że to jest już nie aktualne bo gdzieś wyczytałem że w tym kernelu to juz powinno być zaimplementowane... Pozatym wywala mi takie błędy: /root/Desktop/zd1211-driver-r83/src/zd1211.c:1804:46: error: macro "INIT_WORK" passed 3 arguments, but takes just 2 /root/Desktop/zd1211-driver-r83/src/zd1211.c: In function ‘zd1211_InitSetup’: /root/Desktop/zd1211-driver-r83/src/zd1211.c:1804: error: ‘INIT_WORK’ undeclared (first use in this function) /root/Desktop/zd1211-driver-r83/src/zd1211.c:1804: error: (Each undeclared identifier is reported only once /root/Desktop/zd1211-driver-r83/src/zd1211.c:1804: error: for each function it appears in.) /root/Desktop/zd1211-driver-r83/src/zd1211.c:1805:55: error: macro "INIT_WORK" passed 3 arguments, but takes just 2 /root/Desktop/zd1211-driver-r83/src/zd1211.c:1850: warning: passing argument 6 of ‘usb_fill_bulk_urb’ from incompatible pointer type /root/Desktop/zd1211-driver-r83/src/zd1211.c:1892: error: ‘struct net_device’ has no member named ‘get_wireless_stats’ /root/Desktop/zd1211-driver-r83/src/zd1211.c: In function ‘zd1211_intr_cb’: /root/Desktop/zd1211-driver-r83/src/zd1211.c:2508: warning: passing argument 6 of ‘usb_fill_bulk_urb’ from incompatible pointer type /root/Desktop/zd1211-driver-r83/src/zd1211.c: In function ‘zd1211_submit_rx_urb’: /root/Desktop/zd1211-driver-r83/src/zd1211.c:2647: warning: passing argument 6 of ‘usb_fill_bulk_urb’ from incompatible pointer type /root/Desktop/zd1211-driver-r83/src/zd1211.c: In function ‘zd1211_submit_tx_urb’: /root/Desktop/zd1211-driver-r83/src/zd1211.c:2884: warning: passing argument 6 of ‘usb_fill_bulk_urb’ from incompatible pointer type make[2]: *** [/root/Desktop/zd1211-driver-r83/src/zd1211.o] Błąd 1 make[1]: *** [_module_/root/Desktop/zd1211-driver-r83] Błąd 2 make: *** [all] Błąd 2 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
