zmarekz Napisano Czerwiec 2, 2007 Zgłoszenie Share Napisano Czerwiec 2, 2007 Witam posiadam stara karte Riva TNT II, uzywam sterowników w wersji 1.0-7185 na fedorze 7 Akceleracja 3D (np w ppracer) dziala mi tylko na koncie root. Na user wywala *** ppracer error: Couldn't initialize video: Couldn't find matching GLX visual (Success) Mój xorg.conf # Xorg configuration created by livna-config-display Section "ServerLayout" Identifier "single head configuration" Screen 0 "Screen0" 0 0 InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" ModulePath "/usr/lib/xorg/modules/extensions/nvidia" ModulePath "/usr/lib/xorg/modules" EndSection Section "ServerFlags" Option "AIGLX" "off" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "Device" Identifier "Videocard0" Driver "nvidia" Option "AddARGBGLXVisuals" "True" Option "DisableGLXRootClipping" "True" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection Section "Extensions" Option "Composite" "Disable" EndSection a polecenie glxinfo daje: name of display: :0.0 display: :0 screen: 0 direct rendering: Yes server glx vendor string: NVIDIA Corporation server glx version string: 1.3 server glx extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control client glx vendor string: NVIDIA Corporation client glx version string: 1.3 client glx extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync, GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_NV_float_buffer GLX version: 1.3 GLX extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control, GLX_ARB_get_proc_address OpenGL vendor string: NVIDIA Corporation OpenGL renderer string: RIVA TNT2/AGP/SSE/3DNOW! OpenGL version string: 1.5.3 NVIDIA 71.85 OpenGL extensions: GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_point_parameters, GL_ARB_texture_env_add, GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object, GL_ARB_window_pos, GL_EXT_texture_env_add, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_compiled_vertex_array, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object, GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_stencil_wrap, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine, GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_vertex_array, GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat, GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil, GL_NV_texgen_reflection, GL_NV_texture_env_combine4, GL_SGIS_multitexture, GL_SUN_slice_accum visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x21 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None 0x22 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None 0x23 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None 0x24 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None 0x25 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None 0x26 24 tc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None 0x27 24 tc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None 0x28 24 tc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None 0x29 24 tc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None 0x2a 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None 0x2b 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None 0x2c 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None 0x2d 24 dc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None 0x2e 24 dc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None 0x2f 24 dc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None 0x30 24 dc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None[/code] I juz sam nie wiem co moze byc nie tak. Na root jest ok na user juz nie. Zauwazylem ze system w System-Administracja - Ekran zle wykryl karte graficzna (unkown card) pokazalem mu wlasciwa teraz dodastkowo doszlo [code]*** ppracer error: Couldn't initialize video: Couldn't find matching GLX visual (Success) Naruszenie ochrony pamieci tak samo na koncie user jak i na root. Czy a ktos jakis pomysl ?? Siedze nad tym juz kilka dni a dzis od rana i zero. -------- (Listingi do 12-15 linijek umieszczaj miedzy znacznikami [code] i [/code], dluzsze niz 15 linii pomiedzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help") (Nie pisz postów pod wlasnymi postami, korzystaj z przycisku "EDYCJA") (Obowiazuje zasada: jeden problem w jednym temacie. Niektórzy tutaj potrafia korzystac z wyszukiwarki, w nagrode niech maja przejrzyste watki) WalDo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zmarekz Napisano Czerwiec 3, 2007 Autor Zgłoszenie Share Napisano Czerwiec 3, 2007 Korzystałem z wyszukiwarki i guzik wyświetliła Ale ok Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Czerwiec 3, 2007 Zgłoszenie Share Napisano Czerwiec 3, 2007 Może spróbuj dodać do xorg.conf Section "Module" Load "glx" EndSection Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
