nitr0x92 Napisano Sierpień 2, 2007 Zgłoszenie Share Napisano Sierpień 2, 2007 Mam problem z którym sie borykam od jakiś 4godzin i mam już tego dość wiem że juz powstawały tematy związane z tym problemem ale umnie nie działają te rozwiązania [root@nitr0x proftpd-1.3.1rc3]# ./configure --with-modules=mod_sql:mod_sql_mysql:mod_quotatab:mod_quotatab_sql --with-includes=/usr/include/mysql --with-libraries=/usr/lib/mysql --sysconfdir=/etc --localstatedir=/var checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking target system type... i686-pc-linux-gnu checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking whether make sets $(MAKE)... yes checking for a BSD-compatible install... /usr/bin/install -c checking for a sed that does not truncate output... /bin/sed checking for egrep... grep -E checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes checking how to recognise dependent libraries... pass_all checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking for g++... no checking for c++... no checking for gpp... no checking for aCC... no checking for CC... no checking for cxx... no checking for cc++... no checking for cl... no checking for FCC... no checking for KCC... no checking for RCC... no checking for xlC_r... no checking for xlC... no checking whether we are using the GNU C++ compiler... no checking whether g++ accepts -g... no checking how to run the C++ preprocessor... /lib/cpp configure: error: C++ preprocessor "/lib/cpp" fails sanity check See `config.log' for more details. Chodzi mi o ostatnie 2 linijki mam zainstalowane gcc. Proszę o pomoc! Z góty dziękuje! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zybex_pl Napisano Sierpień 3, 2007 Zgłoszenie Share Napisano Sierpień 3, 2007 zainstaluj glibc-headers znalezienie rozwiązania w goglu zajęło ok 30 sekund i okazało się że temat był już wałkowany na forum.fedora w 2005 roku http://forum.fedora.pl/index.php?showtopic=4109 zmarnowałeś 4 godziny czasu pozdro zybex_pl Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
nitr0x92 Napisano Sierpień 3, 2007 Autor Zgłoszenie Share Napisano Sierpień 3, 2007 ja wiem że to trzeba zainstalować tylko że gdy wpisuje [root@nitr0x ~]# yum install glibc-headers Setting up Install Process Setting up repositories dag 100% |=========================| 1.1 kB 00:00 kbs-CentOS-Extras 100% |=========================| 951 B 00:00 update 100% |=========================| 951 B 00:00 base 100% |=========================| 1.1 kB 00:00 addons 100% |=========================| 951 B 00:00 extras 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files Excluding Packages from Dag RPM Repository for Red Hat Enterprise Linux Finished Parsing package install arguments Nothing to do to mi siue ukazuje coś takiego.(widziałem ten post) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zybex_pl Napisano Sierpień 3, 2007 Zgłoszenie Share Napisano Sierpień 3, 2007 http://rpm.pbone.net pozdro zybex_pl Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
nitr0x92 Napisano Sierpień 3, 2007 Autor Zgłoszenie Share Napisano Sierpień 3, 2007 Mam jednak ten pakiet. I nadal nie działa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ecik__ Napisano Sierpień 3, 2007 Zgłoszenie Share Napisano Sierpień 3, 2007 Mam jednak ten pakiet. I nadal nie działa A masz pakiet cpp? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
