Jasiek_M Napisano Sierpień 8, 2007 Zgłoszenie Share Napisano Sierpień 8, 2007 Witam! Mam problem z mikrofonem, graficznie wszystko jest ok: http://img406.imageshack.us/img406/8503/zrzutekranuue3.png http://img175.imageshack.us/img175/1620/zrzutekranuzp2.png http://img253.imageshack.us/img253/6097/zrzutekranubt6.png Za to wynik komendy "amixer" jest: [Jasiek@localhost ~]$ amixer Simple mixer control 'Master',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [0.00dB] [on] Front Right: Playback 31 [100%] [0.00dB] [on] Simple mixer control '3D Control - Center',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 15 Mono: 0 [0%] Simple mixer control '3D Control - Depth',0 Capabilities: volume volume-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 15 Mono: 0 [0%] Simple mixer control '3D Control - Switch',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'PCM',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [12.00dB] [on] Front Right: Playback 31 [100%] [12.00dB] [on] Simple mixer control 'Line',0 Capabilities: pvolume pswitch pswitch-joined cswitch cswitch-exclusive Capture exclusive group: 0 Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: Playback 0 - 31 Front Left: Playback 31 [100%] [12.00dB] [on] Capture [off] Front Right: Playback 31 [100%] [12.00dB] [on] Capture [off] Simple mixer control 'CD',0 Capabilities: pvolume pswitch pswitch-joined cswitch cswitch-exclusive Capture exclusive group: 0 Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: Playback 0 - 31 Front Left: Playback 31 [100%] [12.00dB] [on] Capture [on] Front Right: Playback 31 [100%] [12.00dB] [on] Capture [on] Simple mixer control 'Mic',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined cswitch cswitch-exclusive Capture exclusive group: 0 Playback channels: Mono Capture channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Playback 31 [100%] [12.00dB] [on] Front Left: Capture [off] Front Right: Capture [off] Simple mixer control 'Mic Boost (+20dB)',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Video',0 Capabilities: cswitch cswitch-exclusive Capture exclusive group: 0 Capture channels: Front Left - Front Right Front Left: Capture [off] Front Right: Capture [off] Simple mixer control 'Phone',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined cswitch cswitch-exclusive Capture exclusive group: 0 Playback channels: Mono Capture channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Playback 31 [100%] [12.00dB] [on] Front Left: Capture [off] Front Right: Capture [off] Simple mixer control 'PC Speaker',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 15 Mono: Playback 15 [100%] [0.00dB] [on] Simple mixer control 'Aux',0 Capabilities: pvolume pswitch pswitch-joined cswitch cswitch-exclusive Capture exclusive group: 0 Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: Playback 0 - 31 Front Left: Playback 0 [0%] [-34.50dB] [off] Capture [off] Front Right: Playback 0 [0%] [-34.50dB] [off] Capture [off] Simple mixer control 'Capture',0 Capabilities: cvolume cswitch cswitch-joined Capture channels: Front Left - Front Right Limits: Capture 0 - 15 Front Left: Capture 15 [100%] [22.50dB] [on] Front Right: Capture 15 [100%] [22.50dB] [on] Simple mixer control 'Mix',0 Capabilities: cswitch cswitch-exclusive Capture exclusive group: 0 Capture channels: Front Left - Front Right Front Left: Capture [off] Front Right: Capture [off] Simple mixer control 'Mix Mono',0 Capabilities: cswitch cswitch-exclusive Capture exclusive group: 0 Capture channels: Front Left - Front Right Front Left: Capture [off] Front Right: Capture [off] Simple mixer control 'External Amplifier',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Input Source Select',0 Capabilities: enum Items: 'Input1' 'Input2' Item0: 'Input1' Simple mixer control 'Input Source Select',1 Capabilities: enum Items: 'Input1' 'Input2' Item0: 'Input1' Simple mixer control 'VIA DXS',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [-48.00dB] Front Right: Playback 31 [100%] [-48.00dB] Simple mixer control 'VIA DXS',1 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [-48.00dB] Front Right: Playback 31 [100%] [-48.00dB] Simple mixer control 'VIA DXS',2 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [-48.00dB] Front Right: Playback 31 [100%] [-48.00dB] Simple mixer control 'VIA DXS',3 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [-48.00dB] Front Right: Playback 31 [100%] [-48.00dB] [Jasiek@localhost ~]$ Nie wiem co z tym zrobić ale z komendy wynika że wiele rzeczy które powinny być włączone(i wg. trybu graficznego są np. "mix mono" i "mix") są wyłączone... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
razor Napisano Sierpień 8, 2007 Zgłoszenie Share Napisano Sierpień 8, 2007 Spróbuj ustawić wszystko za pomocą alsamixer . (w konsoli) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jasiek_M Napisano Sierpień 8, 2007 Autor Zgłoszenie Share Napisano Sierpień 8, 2007 Nadal: Simple mixer control 'Mix',0 Capabilities: cswitch cswitch-exclusive Capture exclusive group: 0 Capture channels: Front Left - Front Right Front Left: Capture [off] Front Right: Capture [off] Simple mixer control 'Mix Mono',0 Capabilities: cswitch cswitch-exclusive Capture exclusive group: 0 Capture channels: Front Left - Front Right Front Left: Capture [off] Front Right: Capture [off] grr:/ Bo to chyba przez to że jest off a nie on. A alsamixer ustawiłem chyba dobrze: Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Sierpień 9, 2007 Zgłoszenie Share Napisano Sierpień 9, 2007 ja tez kiedys mialem problem z mikrofonem i uzyłem programu kmix bo alsamixer w dziwny sposób sobie nie radziła, program prosty w obsłudze więc sobie poradzisz, wystarczy zapalić na zakładce Wejścia lampki zielona do aktywacji i ewentualnie czerwona do przechwytywania dzwieku, Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jasiek_M Napisano Wrzesień 2, 2007 Autor Zgłoszenie Share Napisano Wrzesień 2, 2007 [Jasiek@localhost ~]$ kmix bash: kmix: command not found [Jasiek@localhost ~]$ su - Hasło: [root@localhost ~]# kmix -bash: kmix: command not found [root@localhost ~]# yum install kmix Loading "installonlyn" plugin Setting up Install Process Setting up repositories livna 100% |=========================| 2.1 kB 00:00 beryl 100% |=========================| 951 B 00:00 core 100% |=========================| 1.1 kB 00:00 updates 100% |=========================| 1.2 kB 00:00 extras 100% |=========================| 1.1 kB 00:00 Reading repository metadata in from local files Parsing package install arguments Nothing to do [root@localhost ~]# kmix -bash: kmix: command not found [root@localhost ~]# Wybacz, nowy jestem i nie wiem jak inaczej zainstalować i włączyć ten program Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Wrzesień 2, 2007 Zgłoszenie Share Napisano Wrzesień 2, 2007 po pierwsze ze względu, że jesteś początkującym podpowiem ci jak wyszukiwać programów, programy nie zawsze występują samodzielnie (dlatego yum install tego nie znalazł), czasami są one dytrybuowane w większych pakietach, szczególnie kiedy są powiązane ze środowiskiem graficznym, w przypadku kmix tak właśnie jest, żeby odnaleźć program w jakimś większym pakiecie naleźy użyć yum search: yum search kmix natomiast jeżeli szukasz fragmentów programów np. bibliotek, robisz to za pomocą yum provides jak widzisz z powyższych kmix jest częścią pakietu kdemultimedia, więcu musisz wydać polecenie: yum install kdemultimedia potem już możesz używać kmix jako zwykły użytkownik Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Jasiek_M Napisano Wrzesień 3, 2007 Autor Zgłoszenie Share Napisano Wrzesień 3, 2007 Wiedziałem o tym poleceniu ale nie wpadłem że to nie była nazwa pakietu który mam ściągnąć Przepraszam za problem:( Już wszystko działa. Pozdrawiam, dziękuję za pomoc i przepraszam za problem Jasiek Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
