blaszki Napisano Sierpień 30, 2007 Zgłoszenie Share Napisano Sierpień 30, 2007 Tytułem wstępu: Po dzisiejszej próbie yum update [root@robert ~]# yum update Setting up Update Process Resolving Dependencies --> Running transaction check ---> Package tar.x86_64 2:1.15.1-27.fc7 set to be updated ---> Package qt.i386 1:3.3.8-6.fc7 set to be updated ---> Package libpurple.x86_64 0:2.1.1-1.fc7 set to be updated ---> Package cryptsetup-luks.x86_64 0:1.0.5-4.fc7.1 set to be updated ---> Package autofs.x86_64 1:5.0.1-26 set to be updated ---> Package perl-Net-DNS.x86_64 0:0.61-1.fc7 set to be updated ---> Package cryptsetup-luks.i386 0:1.0.5-4.fc7.1 set to be updated ---> Package crontabs.noarch 0:1.10-15.fc7 set to be updated ---> Package control-center.x86_64 1:2.18.0-20.fc7 set to be updated ---> Package qt-devel.x86_64 1:3.3.8-6.fc7 set to be updated ---> Package kde-filesystem.noarch 0:3.5-13.fc7 set to be updated ---> Package qt.x86_64 1:3.3.8-6.fc7 set to be updated ---> Package gdm.x86_64 1:2.18.4-2.fc7 set to be updated ---> Package ntp.x86_64 0:4.2.4p2-3.fc7 set to be updated ---> Package control-center.i386 1:2.18.0-20.fc7 set to be updated ---> Package pidgin.x86_64 0:2.1.1-1.fc7 set to be updated ---> Package dcraw.x86_64 0:8.77-1.fc7 set to be updated Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Updating: autofs x86_64 1:5.0.1-26 updates 863 k control-center x86_64 1:2.18.0-20.fc7 updates 2.8 M control-center i386 1:2.18.0-20.fc7 updates 2.8 M crontabs noarch 1.10-15.fc7 updates 6.7 k cryptsetup-luks x86_64 1.0.5-4.fc7.1 updates 631 k cryptsetup-luks i386 1.0.5-4.fc7.1 updates 638 k dcraw x86_64 8.77-1.fc7 updates 176 k gdm x86_64 1:2.18.4-2.fc7 updates 4.3 M kde-filesystem noarch 3.5-13.fc7 updates 15 k libpurple x86_64 2.1.1-1.fc7 updates 6.6 M ntp x86_64 4.2.4p2-3.fc7 updates 1.4 M perl-Net-DNS x86_64 0.61-1.fc7 updates 237 k pidgin x86_64 2.1.1-1.fc7 updates 1.1 M qt i386 1:3.3.8-6.fc7 updates 3.5 M qt x86_64 1:3.3.8-6.fc7 updates 3.6 M qt-devel x86_64 1:3.3.8-6.fc7 updates 11 M tar x86_64 2:1.15.1-27.fc7 updates 743 k Transaction Summary ============================================================================= Install 0 Package(s) Update 17 Package(s) Remove 0 Package(s) Total download size: 40 M Is this ok [y/N]: y Downloading Packages: Running rpm_check_debug --> Populating transaction set with selected packages. Please wait. ---> Package tar.x86_64 2:1.15.1-27.fc7 set to be updated ---> Package qt.i386 1:3.3.8-6.fc7 set to be updated ---> Package libpurple.x86_64 0:2.1.1-1.fc7 set to be updated ---> Package cryptsetup-luks.x86_64 0:1.0.5-4.fc7.1 set to be updated ---> Package autofs.x86_64 1:5.0.1-26 set to be updated ---> Package perl-Net-DNS.x86_64 0:0.61-1.fc7 set to be updated ---> Package cryptsetup-luks.i386 0:1.0.5-4.fc7.1 set to be updated ---> Package crontabs.noarch 0:1.10-15.fc7 set to be updated ---> Package control-center.x86_64 1:2.18.0-20.fc7 set to be updated ---> Package qt-devel.x86_64 1:3.3.8-6.fc7 set to be updated ---> Package kde-filesystem.noarch 0:3.5-13.fc7 set to be updated ---> Package qt.x86_64 1:3.3.8-6.fc7 set to be updated ---> Package gdm.x86_64 1:2.18.4-2.fc7 set to be updated ---> Package ntp.x86_64 0:4.2.4p2-3.fc7 set to be updated ---> Package control-center.i386 1:2.18.0-20.fc7 set to be updated ---> Package pidgin.x86_64 0:2.1.1-1.fc7 set to be updated ---> Package dcraw.x86_64 0:8.77-1.fc7 set to be updated Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Updating : qt ####################### [ 1/34] Naruszenie ochrony pamięci zgodnie z tym wątkiem http://forum.fedora.pl/index.php?showtopic...3%8B%EF%BF%BDci [robert@robert ~]$ su - Hasło: [root@robert ~]# rpm -q kernel kernel-2.6.22.1-41.fc7 kernel-2.6.22.4-65.fc7 [root@robert ~]# rpm -q prelink prelink-0.3.10-1 [root@robert ~]# touch /var/lib/misc/prelink.force && /etc/cron.daily/prelink [root@robert ~]# ls /var/lib/misc/ prelink.full prelink.quick niestety nie ma pliku prelink.force (nie jestem pewien czy powinien taki się pojawić ponieważ powyższy watek opisywał FC6 ). Dodam, że próbowałem także yum clean all, nie pomogło i nadal mam błędy z naruszeniem pamięci. I nie jest to problem qt ponieważ próba pojedynczej aktualizacji jakiegokolwiek pakietu kończy się podobnie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dj_oko Napisano Sierpień 30, 2007 Zgłoszenie Share Napisano Sierpień 30, 2007 Daj po prostu prelink, a potem yum clean all. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 30, 2007 Zgłoszenie Share Napisano Sierpień 30, 2007 IMHO problemem nie jest prelink. Raczej coś się porobiło z yumem w trakcie instalacji, ewentualnie posypała się baza RPM. Porada dj_oko powinna pomóc, chociaż ja wykonałbym w kolejności: yum clean all yum update prelink -a Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dj_oko Napisano Sierpień 30, 2007 Zgłoszenie Share Napisano Sierpień 30, 2007 Racja WalDo - zapomniałem o bazie RPM. blaszki - poszukaj na forum tematu dotyczącego: rpm -rebuild Na przykład ten: http://forum.fedora.pl/index.php?showtopic...47&hl=rpmdb Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
blaszki Napisano Sierpień 31, 2007 Autor Zgłoszenie Share Napisano Sierpień 31, 2007 [robert@robert ~]$ su - Hasło: [root@robert ~]# yum clean all Cleaning up Everything [root@robert ~]# rpm --rebuilddb Naruszenie ochrony pamięci Ogólnie tylko yum clean all nie wyrzuca komunikatu o naruszeniu i to tylko dopóki wcześniej taki komunikat nie pojawił się (tzn. po odpaleniu kompa dopóki nie wywołam operacji, która wywali komunikat o naruszeniu wówczas nawet yum clean all się wysypuje). Co do prelink: [robert@robert ~]$ su - Hasło: [root@robert ~]# prelink -a prelink: /usr/libexec/nx/nxdesktop: Could not find one of the dependencies prelink: /usr/libexec/nx/nxviewer: Could not find one of the dependencies prelink: /usr/libexec/nx/nxproxy: Could not find one of the dependencies prelink: /usr/libexec/nx/nxagent: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/b2f: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/xfsm: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/vasy: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/graal: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/ocp: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/k2f: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/pat2spi: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/mips_asm: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/asimut: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/sxlib2lef: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/flatbeh: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/x2vy: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/proof: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/l2p: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/nero: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/fmi: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/flatph: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/moka: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/ring: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/alcbanner: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/cougar: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/lvx: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/fsp: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/a2def: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/xsch: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/flatlo: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/druc: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/xvpn: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/loon: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/pdv: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/boog: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/s2r: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/def2a: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/boom: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/x2y: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/flatrds: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/dreal: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/xpat: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/scapin: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/syf: Could not find one of the dependencies prelink: /usr/lib/alliance/bin/m2e: Could not find one of the dependencies prelink: /usr/lib/debug/usr/bin/qtpfsgui.debug: PT_INTERP segment not corresponding to .interp section prelink: /usr/lib64/esc-1.0.1/xulrunner/xulrunner-bin: Could not find one of the dependencies prelink: /usr/bin/emacs-22.1: COPY relocations don't point into .bss or .sbss section prelink: /usr/lib64/maxima/5.12.0/binary-gcl/maxima: COPY relocations don't point into .bss or .sbss section prelink: /sbin/fxload: Not enough room to add .dynamic entry prelink: /usr/lib/opera/9.22-20070716.1/opera: Not enough room to add .dynamic entry prelink: /usr/lib/opera/9.22-20070716.1/works: Not enough room to add .dynamic entry prelink: /usr/lib/opera/plugins/operaplugincleaner: Not enough room to add .dynamic entry prelink: /usr/lib/opera/plugins/operapluginwrapper: Not enough room to add .dynamic entry więc chyba to prelink. Okazało się że nie tylko yum narusza ochronę pamięci ale także parę innych programów t.j gedit, firefox. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dj_oko Napisano Sierpień 31, 2007 Zgłoszenie Share Napisano Sierpień 31, 2007 Usuwałeś pliki poprzedniej rpmdb? Czy ps -e pokazuje ci procesy w stylu delay-000.cron? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Sierpień 31, 2007 Zgłoszenie Share Napisano Sierpień 31, 2007 Ciekawe są te wpisy "Not enough room to add .dynamic entry". Czy Tobie nie zabrakło po prostu miejsca na partycji? [EDIT]A może błędy na partycji? Odpal może system z jakiegoś LiveCD (niekoniecznie Fedory) i zapuść fsck na partycjach. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
blaszki Napisano Wrzesień 3, 2007 Autor Zgłoszenie Share Napisano Wrzesień 3, 2007 Mam zbyt mało czasu i muszę pracować nad pewnym innym problem i dlatego zrobiłem coś w stylu "błyskawiczna naprawa Windowsa". Przeinstalowałem cały system i na razie jest w porządku (doszedłem do takiego samego wniosku jak neo_fox w podanym przez was linku). Podsumuje tylko do czego doszedłem: 1. Tylko livecd fedory odpalił się na moim sprzęcie, i tutaj utknąłem ponieważ nie mogłem pod montować dysku i zrobić fsck. (nie szukałem za dużo dlaczego tak może być , później mi się przypomniało, że jak instalowałem F7 to dałem "zrób domyślny podział dysku" =LVM). (sprawdzałem jeszcze na knoppixie, gentoo, i jeszcze jakimś <nie pamietam nazwy> aden się nie odpalił) 2. ps -e nie pokazywał nic takiego 3. Jak usunąłem pakiety, przez które wysypywały się linker to liczba błedów zmiejszyła się (chociaż nie wszystko udało mi się usunąć) ,błąd ochrony nadal pozostał. 4. Jak już postanowiłem zainstalować ponownie system to zauważałem opcje "napraw instniejacy system"<czy jakoś tak>. Wysypał się z komunikatem coś o bash, wówczas przypomniało mi się że niedawno instalowałem coś do JTAG Xilinxa i tam było jakieś kombinowanie (INSTALL.txt) z powłokami więc być może to się to posypało. pozdrawiam ps. Co było łatwe do przewidzenia problem pojawił się ponownie. Rozwiązywanie problemów metoda "znajdź przyczynę"->usuń problem->"ciesz się sprawnym OS" jest dużo skuteczniejsze niż prosty i stosunkowo mniej czasochłonny "zainstaluj ponownie OS a może problem sam zniknie". Podejrzane w tym wszystkim było to ,iż system pracował na początku dobrze, natomiast po zainstalowaniu wszystkich programów coś się zaczęło sypać. Dziwne również było to, że czasami wszystko było ok czasami sypało się. Poszedłem waszym tropem, iż to może wina sprzętu i zapuściłem memtest. Okazało się, że druga pamięć (mam 2x512) sypała jakimiś błędami w okolicach 180MB. Prawdopodobnie po odpaleniu systemu wadliwy obszar nie był wykorzystywany a yum update zużywa sporo pamięci i pewnie już używał tych wadliwych. ps.2. rozwiązałem także problem z livecd. Posiadam płyty Intela DQ965 i należy w niej ustawić tryb dysku->AHCI oraz odpalać z parametrem linux all-generic-ide. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
