[kompilacja] - Xdtv
marciek
Witam.
Kompilowałem sobie ' XDTV ' - program do tv ...
wszystko dziala mi dobrze tylko jesli w programie mam ustawione " mixer = line " nie diala mi podgłaśnianie ani pryciszanie..
Pokażę wynik " ./configure " może ktoś będzie wiedział, bo nie mam chyba w systemia zainstalowny jakis devel badz coś i nie kompiluje mi odsługą dzwieku.
( dzwiek jest tylko z programu nie oge pogłaśniać ani przyciszać ).
[marcin@localhost xdtv-2.4.0]$ ./configure --prefix=/usr
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether make sets $(MAKE)... (cached) yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag  works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for strings.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for off_t... yes
checking for size_t... yes
checking for struct stat.st_rdev... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether gcc needs -traditional... no
checking whether sys/types.h defines makedev... yes
checking for stdlib.h... (cached) yes
checking for getpagesize... yes
checking for working mmap... yes
checking for getcwd... yes
checking for gettimeofday... yes
checking for mkdir... yes
checking for strdup... yes
checking for strerror... yes
checking for sigrelse... yes
checking whether byte ordering is bigendian... no
checking for gcc version... 4.1.2
checking for mmx support... yes
checking CPU vendor... GenuineIntel (15:4:1)
checking CPU type...  Intel® Pentium® 4 CPU 2.66GHz
checking Check for sse... yes
checking Check for 3DNow!... no
checking Check for Extended 3DNow!... no
checking GCC & CPU optimization abilities... -march=pentium4
checking for host system... linux
checking for video4linux... yes
checking for video4linux version 2... yes
checking soundcard.h usability... no
checking soundcard.h presence... no
checking for soundcard.h... no
checking sys/soundcard.h usability... yes
checking sys/soundcard.h presence... yes
checking for sys/soundcard.h... yes
checking linux/soundcard.h usability... yes
checking linux/soundcard.h presence... yes
checking for linux/soundcard.h... yes
checking machine/soundcard.h usability... no
checking machine/soundcard.h presence... no
checking for machine/soundcard.h... no
checking for rint in -lm... yes
checking for socket... yes
checking for gethostbyname... yes
checking for herror... yes
checking for X... libraries , headers
checking for gethostbyname... (cached) yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for XShmAttach in -lXext... yes
checking for XtDisplay in -lXt... yes
checking for XmuGetHostname in -lXmu... yes
checking for XawDialogAddButton in -lXaw... yes
checking for Xaw3dComputeTopShadowRGB in -lXaw3d... yes
checking for Xaw3dComputeTopShadowRGB in -lXaw95... no
checking for Xaw3dComputeTopShadowRGB in -lXawM... no
checking for Xaw3dComputeTopShadowRGB in -lneXtaw... no
*** Will link against: -lXaw3d ***
checking for bdftopcf... /usr/bin/bdftopcf
checking for mkfontscale... /usr/bin/mkfontscale
checking for mkfontdir... /usr/bin/mkfontdir
checking for xset... /usr/bin/xset
checking for the fonts directory... /usr/share/X11/fonts/misc
checking for the app-defaults directory... /usr/share/X11/app-defaults
checking for the wizard conf directory... /etc/xdtv
checking for XpmCreatePixmapFromData in -lXpm... yes
checking for MwTextFieldGetString in -lMowitz... no
checking for jpeg_start_compress in -ljpeg... yes
checking for pthread_create in -lpthread... yes
checking for sem_init... no
checking for sem_init in -lpthread... yes
checking for lirc header files... yes
checking for lirc_init in -llirc_client... yes
checking for snd_pcm_readi in -lasound... yes
checking for alsa 0.9.x or 1.0.x with alsa/asoundlib.h... yes
checking for XF86DGAQueryExtension in -lXxf86dga... yes
checking for XF86VidModeQueryExtension in -lXxf86vm... yes
checking for DPMSQueryExtension in -lXdpms... no
checking for DPMSQueryExtension in -lXext... yes
checking for XineramaQueryExtension in -lXinerama... yes
checking for gettext... yes
checking for XvQueryExtension in -lXv... yes
checking for devfs... no
checking for dlopen in -ldl... yes
checking for ffmpeg inside distribution... yes
checking for XviD header files... yes
checking if XviD API version is 2.1 or 4.0 or 4.1... yes
checking for xvid_encore in -lxvidcore... yes
checking for ogg-vorbis-theora header files... yes
checking for ogg_stream_init  in -logg... yes
checking for vorbis_info_init  in -lvorbis... yes
checking for vorbis_encode_init  in -lvorbisenc... yes
checking for theora_encode_init in -ltheora... yes
checking for divx4linux header files... no
*** Could not find divx4linux header files ***
checking for encore in -ldivxencore... no
*** Could not find divx4linux libraries: feature is disabled ***
checking for lame header files... yes
checking for lame_init in -lmp3lame... yes
checking for lame_decode_exit... yes
checking for png_read_image in -lpng... yes
checking for zvbi header files... yes
checking for vbi_capture_fd in -lzvbi... yes
checking for faac header files... yes
checking for faacEncOpen in -lfaac... yes
checking for x264 header files... no
checking for DVB driver support... yes
checking for libsdl header files... yes
checking for SDL_Init in -lSDL... yes
checking for libcurl header files... no
*** DVB support disabled ***
*** AleVT vtxt font used ***
checking for lrintf... yes
checking for memalign... yes
*** FFMPEG LIBLAME: yes ***
*** FFMPEG XVID: yes ***
*** FFMPEG LIBFAAC: yes ***
*** FFMPEG with MMX: yes ***
configure: creating ./config.status
config.status: creating config.mak
config.status: creating Makefile
config.status: creating alevt/Makefile
config.status: creating src/Makefile
config.status: creating font/Makefile
config.status: creating xdtv.spec
config.status: creating xdtv-mandriva.spec
config.status: creating xdtv-fedora.spec
config.status: creating xdtv-suse.spec
config.status: creating xdtv_scan.sh
config.status: creating xdtv_record.sh
config.status: creating debian/xdtv.files
config.status: creating slackware/build.conf
config.status: creating XdTV.ad
config.status: creating man/Makefile
config.status: creating src/dvb/Makefile
config.status: creating config.h
config.status: executing depfiles commands
Chodzi chyba o to :
czyli tam gdzie jest "no"
ps. Ma ktoś jakąś rade na to ?
Może powiele problem ale jak skompiluje jakis program ( budowanie pakietu CHECKINSTALL) to przy instalacji RPM mam konflikt plików.
Musze instalowac " make install "
Ale po tym "make install" możesz już prawdopodobnie zbudować paczkę przy pomocy checkinstall. Też tak miałem na F7. Na F8 jeszcze nie sprawdzałem.
Nie jestem programistą, więc to pewnie głupi pomysł, ale jakby tak stworzyć na tym samym poziomie co podkatalog linux drugi o nazwie machine i cp linux/soundcard.h machine?
I jeszcze jedno. Czy te paczki z repo kwizart (z paczki kwizart-release-8.noarch.rpm) są jakieś trefne, że nie chcesz z nich korzystać? Bo mi się ładnie zainstalowało a nawet uruchamia, ale nie mam jak sprawdzić, bo moja stara karta chyba wyzionęła ducha :-\
bo przyciszasz suwakiem line, on nie dziala?
jak przyciszam w programie to żadne z suwkaów sie nie przesówa.
szczerze powiem nie próbowałem paczki na fc8, zainstaluje i zobacze.
---- łączenie postów ----
Zainstalowalem z paczki Kwizart jest o tyle lepsza ze mam XDTV w menu :)
a dzwiek mi dziala :
trzeba dopisac w ~/.xdtv/xdtvrc
mixer_dev = /dev/mixer
