Miszcz Napisano Grudzień 9, 2007 Zgłoszenie Share Napisano Grudzień 9, 2007 Witam. Mam problem zainstalowałem normalnie Amula z yum no i nie zabardzo mi działa tzn nie może znalesc listy serwerów wyskakuje mi takie coś i nie wiem co z tym dalej zrobić :/ 2007-12-09 14:17:49: The selected locale seems not to be installed on your box. (Note: I'll try to set it anyway) 2007-12-09 14:17:49: Credits: Failed to load creditfile 2007-12-09 14:17:49: No 'cryptkey.dat' file found, creating. 2007-12-09 14:17:49: Credits: Created new RSA keypair 2007-12-09 14:17:49: - This is aMule 2.1.3 using wxGTK2 v2.6.3 (Unicoded) based on eMule. 2007-12-09 14:17:49: Running on Linux 2.6.23.1-49.fc8 i686 2007-12-09 14:17:49: - Visit http://www.amule.org to check if a new version is available. 2007-12-09 14:17:49: Loading ipfilter.dat files. 2007-12-09 14:17:49: Loaded 0 IP-ranges from 'ipfilter.dat'. 0 malformed lines were discarded. 2007-12-09 14:17:49: Loaded 0 IP-ranges from 'ipfilter_static.dat'. 0 malformed lines were discarded. 2007-12-09 14:17:49: Loading server.met file: /home/alan/.aMule/server.met 2007-12-09 14:17:49: Server.met file not found! 2007-12-09 14:17:49: No part files found 2007-12-09 14:17:49: External connections disabled in config file 2007-12-09 14:17:49: MuleUDPSocket: Created Server UDP-Socket at port 4665 2007-12-09 14:17:49: MuleUDPSocket: Created Client UDP-Socket at port 4672 2007-12-09 14:17:49: Found 0 known shared files 2007-12-09 14:17:49: AICH Thread: Syncronization thread started. 2007-12-09 14:17:49: AICH Thread: Masterhashes of known files have been loaded. 2007-12-09 14:17:49: AICH Thread: No new files found. 2007-12-09 14:17:49: AICH Thread: Terminated. 2007-12-09 14:17:49: Connecting 2007-12-09 14:17:49: No valid servers to connect in serverlist found 2007-12-09 14:17:49: CFile: Error when opening file (/home/alan/.aMule/preferencesKad.dat): Nie ma takiego pliku ani katalogu 2007-12-09 14:17:49: CFile: Error when opening file (/home/alan/.aMule/load_index.dat): Nie ma takiego pliku ani katalogu 2007-12-09 14:17:49: CFile: Error when opening file (/home/alan/.aMule/key_index.dat): Nie ma takiego pliku ani katalogu 2007-12-09 14:17:49: CFile: Error when opening file (/home/alan/.aMule/src_index.dat): Nie ma takiego pliku ani katalogu 2007-12-09 14:17:49: CFile: Error when opening file (/home/alan/.aMule/nodes.dat): Nie ma takiego pliku ani katalogu 2007-12-09 14:18:04: Connecting 2007-12-09 14:18:04: No valid servers to connect in serverlist found 2007-12-09 14:18:04: Read 0 Kad contacts 2007-12-09 14:18:10: Loading server.met file: /home/alan/.aMule/server.met.download 2007-12-09 14:18:10: Failed to load server.met file '/home/alan/.aMule/server.met.download', unknown format encountered. 2007-12-09 14:18:13: Connecting 2007-12-09 14:18:13: No valid servers to connect in serverlist found 2007-12-09 14:18:13: Read 0 Kad contacts 2007-12-09 14:18:31: Loading server.met file: /home/alan/.aMule/server.met.download 2007-12-09 14:18:31: Failed to load server.met file '/home/alan/.aMule/server.met.download', unknown format encountered. 2007-12-09 14:19:02: Loading server.met file: /home/alan/.aMule/server.met.download 2007-12-09 14:19:02: Failed to load server.met file '/home/alan/.aMule/server.met.download', unknown format encountered. 2007-12-09 14:19:22: Loading server.met file: /home/alan/.aMule/server.met.download 2007-12-09 14:19:22: Failed to load server.met file '/home/alan/.aMule/server.met.download', unknown format encountered. 2007-12-09 14:19:46: Loading server.met file: /home/alan/.aMule/server.met.download 2007-12-09 14:19:46: Failed to load server.met file '/home/alan/.aMule/server.met.download', unknown format encountered. 2007-12-09 14:21:16: Loading server.met file: /home/alan/.aMule/server.met.download 2007-12-09 14:21:16: Failed to load server.met file '/home/alan/.aMule/server.met.download', unknown format encountered. 2007-12-09 14:28:08: Connecting 2007-12-09 14:28:08: No valid servers to connect in serverlist found 2007-12-09 14:28:08: Read 0 Kad contacts 2007-12-09 14:28:12: Connecting 2007-12-09 14:28:12: No valid servers to connect in serverlist found 2007-12-09 14:28:12: Read 0 Kad contacts 2007-12-09 14:28:18: Loading server.met file: /home/alan/.aMule/server.met.download 2007-12-09 14:28:18: Failed to load server.met file '/home/alan/.aMule/server.met.download', unknown format encountered. Ewentualnie mam prośbę jeżeli ktoś byłby w stanie wysłać mi plik server.met na maila ([email protected]). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
zajec00 Napisano Grudzień 9, 2007 Zgłoszenie Share Napisano Grudzień 9, 2007 hmmm... po wlaczeniu amula w linijce serwery podaj ten adres : http://www.gruk.org/server.met.gz powinno bez problemu pobrac liste... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Grudzień 9, 2007 Autor Zgłoszenie Share Napisano Grudzień 9, 2007 Dzięki wielkie działa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
