Błąd Podczas Instalacji
B16
22:13:59 WARNING : /usr/lib/anaconda/isys.py:873: UserWarning: device node created in /tmp
 makeDevInode(device, "/tmp/disk")
22:13:59 WARNING : /usr/lib/anaconda/isys.py:864: UserWarning: device node created in /tmp
22:13:59 WARNING : /usr/lib/anaconda/isys.py:799: UserWarning: device node created in /tmp
22:13:59 WARNING : /usr/lib/anaconda/isys.py:832: UserWarning: device node created in /tmp
22:13:59 WARNING : /usr/lib/anaconda/isys.py:926: UserWarning: device node created in /tmp
22:13:59 DEBUG   : error reading jfs label on /tmp/disk: [Errno 22] Zły argument
22:13:59 DEBUG   : error reading reiserfs label on /tmp/disk: [Errno 22] Zły argument
22:14:01 INFO	: moving (1) to step parttype
22:14:18 INFO	: moving (1) to step autopartitionexecute
22:14:19 DEBUG   : adding drive sda to disk list
22:14:19 DEBUG   : used space is 2024
22:14:19 DEBUG   : actual space is 4096
22:14:19 DEBUG   : used space is 3008
22:14:19 DEBUG   : used space is 4096
22:14:19 INFO	: moving (1) to step partitiondone
22:14:19 INFO	: moving (1) to step bootloadersetup
22:14:19 WARNING : /usr/lib/booty/bootloaderInfo.py:216: UserWarning: device node created in /tmp
 isys.makeDevInode(dev, '/tmp/' + dev)
22:14:19 INFO	: moving (1) to step networkdevicecheck
22:14:21 INFO	: moving (1) to step timezone
22:14:33 INFO	: moving (1) to step accounts
22:14:39 INFO	: moving (1) to step reposetup
22:14:39 INFO	: added repository Additional Fedora Software with source URL [None]
22:14:39 INFO	: switching from CD [1] to 1 for
22:14:41 WARNING : /usr/lib/python2.5/site-packages/yum/repos.py:63: RuntimeWarning: YumProgress.progressbar called when popped
 self.callback.progressbar(num, len(repos), repo.id)
22:14:42 INFO	: no groups missing
22:14:42 INFO	: moving (1) to step basepkgsel
22:14:44 INFO	: moving (1) to step tasksel
22:14:51 INFO	: moving (1) to step group-selection
22:15:37 INFO	: moving (1) to step postselection
22:15:37 INFO	: selected kernel package for kernel
22:15:37 DEBUG   : selecting kernel-devel
22:15:39 DEBUG   : no package matching system-config-securitylevel-tui
22:16:39 INFO	: moving (-1) to step group-selection
22:17:43 INFO	: moving (1) to step postselection
22:17:43 INFO	: selected kernel package for kernel
22:17:45 DEBUG   : no package matching system-config-securitylevel-tui
22:18:00 WARNING : /usr/lib/anaconda/gui.py:558: GtkWarning: gtk_progress_set_percentage: assertion `percentage >= 0 && percentage <= 1.0' failed
 self.progress.set_fraction (newval)
22:18:28 INFO	: moving (-1) to step group-selection
22:18:29 INFO	: moving (-1) to step tasksel
22:18:30 INFO	: moving (-1) to step basepkgsel
22:18:30 INFO	: moving (-1) to step reposetup
22:18:30 INFO	: added repository Additional Fedora Software with source URL [None]
22:18:30 INFO	: moving (-1) to step accounts
22:18:31 INFO	: moving (-1) to step timezone
22:18:32 INFO	: moving (-1) to step network
22:18:33 INFO	: moving (-1) to step networkdevicecheck
22:18:33 INFO	: moving (-1) to step bootloadersetup
22:18:33 INFO	: moving (-1) to step partitiondone
22:18:33 WARNING : getting self.dev more than once for VG Request -- name: VolGroup00  uniqueID: 8
 format: 1 pesize: 32768
 physvols: [7]
22:18:33 INFO	: moving (-1) to step autopartitionexecute
22:18:35 DEBUG   : adding drive sda to disk list
22:18:35 DEBUG   : error reading jfs label on /tmp/disk: [Errno 22] Zły argument
22:18:35 DEBUG   : error reading reiserfs label on /tmp/disk: [Errno 22] Zły argument
22:18:37 INFO	: moving (-1) to step parttype
22:18:44 INFO	: moving (1) to step partition
22:19:20 DEBUG   : adding drive sda to disk list
22:19:24 INFO	: moving (1) to step partitiondone
22:19:24 INFO	: moving (1) to step bootloadersetup
22:19:32 INFO	: moving (-1) to step bootloadersetup
22:19:32 INFO	: moving (-1) to step partitiondone
22:19:35 INFO	: moving (1) to step partitiondone
22:19:35 INFO	: moving (1) to step bootloadersetup
22:19:38 INFO	: moving (1) to step networkdevicecheck
22:19:40 INFO	: moving (1) to step timezone
22:19:41 INFO	: moving (1) to step accounts
22:19:42 INFO	: moving (1) to step reposetup
22:19:42 INFO	: added repository Additional Fedora Software with source URL [None]
22:19:42 INFO	: switching from CD [1] to 1 for
22:19:43 INFO	: no groups missing
22:19:43 INFO	: moving (1) to step basepkgsel
22:19:46 INFO	: moving (1) to step tasksel
22:19:54 INFO	: moving (1) to step group-selection
22:20:26 INFO	: moving (1) to step postselection
22:20:26 INFO	: selected kernel package for kernel
22:20:26 DEBUG   : selecting kernel-devel
22:20:28 DEBUG   : no package matching system-config-securitylevel-tui
22:20:51 INFO	: moving (1) to step confirminstall
22:21:08 INFO	: moving (1) to step install
22:21:08 INFO	: moving (1) to step enablefilesystems
22:21:10 INFO	: disk.commit() for /dev/sda
22:21:12 DEBUG   : adding drive sda to disk list
22:21:12 WARNING : /usr/lib/anaconda/fsset.py:2223: UserWarning: device node created in /tmp
 isys.makeDevInode(self.getDevice(), path)
22:21:12 INFO	: formatting / as ext3
22:21:12 INFO	: Format command:  ['mke2fs', '/tmp/sda2', '-i', '4096', '-j']
22:21:20 DEBUG   : adding drive sda to disk list
22:21:22 DEBUG   : error reading jfs label on /tmp/disk: [Errno 22] Zły argument
22:21:22 DEBUG   : error reading reiserfs label on /tmp/disk: [Errno 22] Zły argument
22:21:22 INFO	: trying to mount /tmp/sda2 on /
22:21:22 INFO	: set SELinux context for mountpoint / to False
22:21:22 DEBUG   : isys.py:mount()- going to mount /tmp/sda2 on /mnt/sysimage
22:21:22 INFO	: set SELinux context for newly mounted filesystem root at / to False
22:21:22 INFO	: trying to mount sys on /sys
22:21:22 INFO	: set SELinux context for mountpoint /sys to False
22:21:22 DEBUG   : isys.py:mount()- going to mount sys on /mnt/sysimage/sys
22:21:22 INFO	: set SELinux context for newly mounted filesystem root at /sys to False
22:21:22 INFO	: trying to mount proc on /proc
22:21:22 INFO	: set SELinux context for mountpoint /proc to False
22:21:22 DEBUG   : isys.py:mount()- going to mount proc on /mnt/sysimage/proc
22:21:22 INFO	: set SELinux context for newly mounted filesystem root at /proc to False
22:21:22 INFO	: moving (1) to step migratefilesystems
22:21:22 INFO	: moving (1) to step setuptime
22:21:22 ERROR   : unable to set timezone
22:21:22 INFO	: moving (1) to step preinstallconfig
22:21:26 CRITICAL: error transferring stage2.img: [Errno 5] Błąd wejścia/wyjścia
22:21:53 INFO	: moving (1) to step installpackages
22:21:53 INFO	: Preparing to install packages
/tmp/lvmout:
Finding all volume groups
  No volume groups found
było tego więcej ale streściłem
taki błąd wyskakuje :/
nie znam się na (_linuxie_ ? Linuksie) ORT ale chodzi chyba o to pogrubione :P
co mam zrobić ?
Akurat to co chciałeś pogrubić nie jest istotne, ja też nie mam woluminów logicznych. Co do problemu to standardowe pytanie:
sprawdzałeś sumy sha1 i czy test na początku po odpaleniu płyty przechodzi pomyślnie?
No i przy długich listingach używamy codebox zamiast code
sum sha1 nie sprawdziłem bo nie wiem co to jest (^^) za to test na początku przechodzi pomyślnie
[---- łaczenie postów ---]
prosze pilnie o pomoc.
Pobierałem z tego torrentu
http://torrenty.org/templates/torrent_details.php?id=168800&info2=true
wszystkim innym z tego linku działa
