Błąd Zależności Przy Yum Update
alucard87
mam taki problem z yumem:
[root@marcin_jedrecki alucard]# yum update -y
Loading "fastestmirror" plugin
Loading mirror speeds from cached hostfile
* livna: wftp.tu-chemnitz.de
* fedora: ftp.pbone.net
* adobe-linux-i386: linuxdownload.adobe.com
* updates: ftp.pbone.net
livna                     100% |=========================| 2.1 kB    00:00
primary.sqlite.bz2        100% |=========================| 190 kB    00:00
fedora                    100% |=========================| 2.1 kB    00:00
adobe-linux-i386          100% |=========================|  951 B    00:00
updates                   100% |=========================| 2.3 kB    00:00
primary.sqlite.bz2        100% |=========================| 2.3 MB    00:01
Setting up Update Process
Resolving Dependencies
--> Running transaction check
--> Processing Dependency: libGLcore.so.1 for package: xorg-x11-drv-nvidia-96xx
--> Processing Dependency: libnvidia-tls.so.1 for package: xorg-x11-drv-nvidia-96xx
---> Package kmod-nvidia-96xx.i686 0:96.43.05-1.2.6.23.14_64.fc7 set to be installed
---> Package xorg-x11-drv-nvidia-96xx.i386 0:96.43.05-1.lvn7 set to be updated
filelists.sqlite.bz2      100% |=========================| 268 kB    00:00
filelists.sqlite.bz2      100% |=========================| 5.0 MB    00:02
--> Processing Dependency: /usr/lib/nvidia/libGL.so.96.43.05 for package: xorg-x11-drv-nvidia-96xx
--> Processing Dependency: xorg-x11-drv-nvidia-96xx-libs = 96.43.05-1.lvn7 for package: xorg-x11-drv-nvidia-96xx
---> Package xorg-x11-drv-nvidia-96xx-libs.i386 0:96.43.05-1.lvn7 set to be updated
---> Package xorg-x11-drv-nvidia.i386 0:169.07-4.lvn7 set to be updated
--> Processing Dependency: nvidia-kmod >= 169.07 for package: xorg-x11-drv-nvidia
---> Package kmod-nvidia.i686 0:169.09-3.2.6.23.14_64.fc7 set to be installed
--> Processing Dependency: nvidia-kmod-common >= 169.09 for package: kmod-nvidia
---> Package xorg-x11-drv-nvidia.i386 0:169.09-3.lvn7 set to be updated
--> Processing Dependency: xorg-x11-drv-nvidia-libs = 169.09-3.lvn7 for package: xorg-x11-drv-nvidia
--> Processing Dependency: /usr/lib/nvidia/libGL.so.169.09 for package: xorg-x11-drv-nvidia
---> Package xorg-x11-drv-nvidia-libs.i386 0:169.09-3.lvn7 set to be updated
--> Processing Conflict: xorg-x11-drv-nvidia conflicts xorg-x11-drv-nvidia-96xx
--> Processing Conflict: xorg-x11-drv-nvidia-96xx conflicts xorg-x11-drv-nvidia
--> Restarting Dependency Resolution with new changes.
--> Finished Dependency Resolution
---> Package kmod-nvidia-96xx.i686 0:96.43.01-1.2.6.23.12_52.fc7 set to be erased
Error: xorg-x11-drv-nvidia conflicts with xorg-x11-drv-nvidia-96xx
yum update -y wykonałem też przedwczoraj i nic takiego nie było
jestem zielony, nie mam bladego pojęcia jak to naprawic?
