Problem Przy Kompilacji
prqr
brakuje mi jakiegos pakietu (albo kilku) przy kompilacji, moze ktos bedzie znal rozwiazanie tego problemu. oto log:
[root@localhost drivers]# ./makedrv
ieee80211/
ieee80211/ieee80211_tx.c
ieee80211/Modules.symvers
ieee80211/ieee80211_softmac_wx.c
ieee80211/LICENSE
ieee80211/ieee80211_rx.c
ieee80211/ieee80211_crypt_tkip.c
ieee80211/ieee80211_crypt.h
ieee80211/ieee80211_crypt_ccmp.c
ieee80211/ieee80211_module.c
ieee80211/Makefile
ieee80211/.tmp_versions/
ieee80211/.tmp_versions/ieee80211_crypt-rtl.mod
ieee80211/.tmp_versions/ieee80211_crypt_wep-rtl.mod
ieee80211/.tmp_versions/ieee80211_crypt_tkip-rtl.mod
ieee80211/.tmp_versions/ieee80211_crypt_ccmp-rtl.mod
ieee80211/.tmp_versions/ieee80211-rtl.mod
ieee80211/ieee80211.h
ieee80211/ieee80211_softmac.c
ieee80211/README
ieee80211/ieee80211_wx.c
ieee80211/ieee80211_crypt_wep.c
ieee80211/ieee80211_crypt.c
rtl818x-0.1/
rtl818x-0.1/r8180_wx.h
rtl818x-0.1/r8180_wx.c
rtl818x-0.1/r8180_rtl8225.h
rtl818x-0.1/r8180_rtl8255.h
rtl818x-0.1/AUTHORS
rtl818x-0.1/r8180_max2820.c
rtl818x-0.1/r8180.h
rtl818x-0.1/r8180_max2820.h
rtl818x-0.1/tags
rtl818x-0.1/r8180_sa2400.h
rtl818x-0.1/r8180_93cx6.c
rtl818x-0.1/ieee80211.h
rtl818x-0.1/r8180_gct.c
rtl818x-0.1/r8180_gct.h
rtl818x-0.1/.r8180_core.o.d
rtl818x-0.1/r8180_rtl8225.c.old
rtl818x-0.1/Modules.symvers
rtl818x-0.1/CHANGES
rtl818x-0.1/LICENSE
rtl818x-0.1/r8180_93cx6.h
rtl818x-0.1/README.master
rtl818x-0.1/r8180_hw.h
rtl818x-0.1/README
rtl818x-0.1/r8180_pm.c
rtl818x-0.1/r8180_sa2400.c
rtl818x-0.1/COPYING
rtl818x-0.1/README.adhoc
rtl818x-0.1/.tmp_versions/
rtl818x-0.1/.tmp_versions/r8180.mod
rtl818x-0.1/INSTALL
rtl818x-0.1/r8180_rtl8255.c
rtl818x-0.1/r8180_core.c
rtl818x-0.1/r8180_pm.h
rtl818x-0.1/Makefile
rtl818x-0.1/ieee80211_crypt.h
rm -f *.mod.c *.mod *.o .*.cmd *.ko
rm -rf /home/cichy/drivers/ieee80211/tmp
make -C /lib/modules/2.6.23.1-42.fc8/build M=/home/cichy/drivers/ieee80211 CC=gcc modules
make[1]: Wejście do katalogu `/usr/src/kernels/2.6.23.1-42.fc8-x86_64'
 CC [M]  /home/cichy/drivers/ieee80211/ieee80211_softmac.o
/home/cichy/drivers/ieee80211/ieee80211_softmac.c: In function ‘ieee80211_softmac_scan_wq’:
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:391: warning: ISO C90 forbids mixed declarations and code
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:412: warning: passing argument 2 of ‘queue_delayed_work’ from incompatible pointer type
/home/cichy/drivers/ieee80211/ieee80211_softmac.c: In function ‘ieee80211_softmac_stop_scan’:
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:486: warning: passing argument 1 of ‘cancel_delayed_work’ from incompatible pointer type
/home/cichy/drivers/ieee80211/ieee80211_softmac.c: In function ‘ieee80211_associate_abort’:
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:885: warning: passing argument 2 of ‘queue_delayed_work’ from incompatible pointer type
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:1359:4: warning: #warning CHECK_LOCK_HERE
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:1399:2: warning: #warning CHECK_LOCK_HERE
/home/cichy/drivers/ieee80211/ieee80211_softmac.c: In function ‘ieee80211_rx_frame_softmac’:
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:1470: warning: ISO C90 forbids mixed declarations and code
/home/cichy/drivers/ieee80211/ieee80211_softmac.c: In function ‘ieee80211_stop_protocol’:
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2059: warning: passing argument 1 of ‘cancel_delayed_work’ from incompatible pointer type
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2167:78: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/home/cichy/drivers/ieee80211/ieee80211_softmac.c: In function ‘ieee80211_softmac_init’:
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2167: error: ‘INIT_WORK’ undeclared (first use in this function)
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2167: error: (Each undeclared identifier is reported only once
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2167: error: for each function it appears in.)
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2168:88: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2169:94: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2170:96: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2171:82: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2172:82: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/home/cichy/drivers/ieee80211/ieee80211_softmac.c: In function ‘ieee80211_softmac_free’:
/home/cichy/drivers/ieee80211/ieee80211_softmac.c:2191: warning: passing argument 1 of ‘cancel_delayed_work’ from incompatible pointer type
make[2]: *** [/home/cichy/drivers/ieee80211/ieee80211_softmac.o] Błąd 1
make[1]: *** [_module_/home/cichy/drivers/ieee80211] Błąd 2
make[1]: Opuszczenie katalogu `/usr/src/kernels/2.6.23.1-42.fc8-x86_64'
make: *** [modules] Błąd 2
rm -rf /home/cichy/drivers/rtl818x-0.1/tmp
make -C /lib/modules/2.6.23.1-42.fc8/build M=/home/cichy/drivers/rtl818x-0.1 CC=gcc modules
 CC [M]  /home/cichy/drivers/rtl818x-0.1/r8180_core.o
In file included from /home/cichy/drivers/rtl818x-0.1/r8180_core.c:61:
/home/cichy/drivers/rtl818x-0.1/r8180.h:29:26: error: linux/config.h: Nie ma takiego pliku ani katalogu
/home/cichy/drivers/rtl818x-0.1/r8180_core.c: In function ‘proc_get_stats_hw’:
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:354: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:355: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:358: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:359: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:362: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:363: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:363: warning: format ‘%x’ expects type ‘unsigned int’, but argument 8 has type ‘dma_addr_t’
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:363: warning: format ‘%x’ expects type ‘unsigned int’, but argument 12 has type ‘dma_addr_t’
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:363: warning: format ‘%x’ expects type ‘unsigned int’, but argument 16 has type ‘dma_addr_t’
/home/cichy/drivers/rtl818x-0.1/r8180_core.c: In function ‘check_tx_ring’:
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:862: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:863: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c: In function ‘alloc_tx_desc_ring’:
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:1544: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:1544: warning: cast to pointer from integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c: In function ‘alloc_rx_desc_ring’:
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:1722: warning: cast from pointer to integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:1722: warning: cast to pointer from integer of different size
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:2953:67: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/home/cichy/drivers/rtl818x-0.1/r8180_core.c: In function ‘rtl8180_init’:
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:2953: error: ‘INIT_WORK’ undeclared (first use in this function)
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:2953: error: (Each undeclared identifier is reported only once
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:2953: error: for each function it appears in.)
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:3276: warning: ‘deprecated_irq_flag’ is deprecated (declared at include/linux/interrupt.h:64)
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:3276: warning: passing argument 2 of ‘request_irq’ from incompatible pointer type
/home/cichy/drivers/rtl818x-0.1/r8180_core.c: In function ‘rtl8180_pci_probe’:
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:4031: error: ‘struct net_device’ has no member named ‘get_wireless_stats’
/home/cichy/drivers/rtl818x-0.1/r8180_core.c: In function ‘rtl8180_pci_module_init’:
/home/cichy/drivers/rtl818x-0.1/r8180_core.c:4156: error: implicit declaration of function ‘pci_module_init’
make[2]: *** [/home/cichy/drivers/rtl818x-0.1/r8180_core.o] Błąd 1
make[1]: *** [_module_/home/cichy/drivers/rtl818x-0.1] Błąd 2
[root@localhost drivers]# ./wlan0up
./wlan0up: line 4: insmod: command not found
./wlan0up: line 5: insmod: command not found
./wlan0up: line 6: insmod: command not found
./wlan0up: line 7: insmod: command not found
./wlan0up: line 8: insmod: command not found
./wlan0up: line 11: insmod: command not found
./wlan0up: line 15: ifconfig: command not found
Kompilacja przebiegla pomyslnie po instalacji tych pakietow i pobraniu nowszych sterownikow, pozostaje jednak druga czesc problemu, a mianowicie:
jak sobie z tym poradzic?
Gość
