Problem Z Iptables
neo_fox
Witam,
staram się zablokować pojedynczy adres IP:
# iptables -A INPUT -s 123.456.78.9 -j REJECT
i mimo że ipatbles twierdzi że ten adres jest zablokowany nadal mogę z tego hosta łączyć się z serwerem (Apache/SSH).
reszta konfiguracji wygląda w ten sposób:
cat iptables
# Generated by iptables-save v1.3.5 on Wed May  7 09:56:22 2008
*nat
:PREROUTING ACCEPT [575:34666]
:POSTROUTING ACCEPT [207:33510]
:OUTPUT ACCEPT [207:33510]
COMMIT
# Completed on Wed May  7 09:56:22 2008
*mangle
:PREROUTING ACCEPT [16290:2614427]
:INPUT ACCEPT [16290:2614427]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [21151:21739354]
:POSTROUTING ACCEPT [21151:21739354]
COMMIT
*filter
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [22437:22958990]
:RH-Firewall-1-INPUT - [0:0]
[17338:2814385] -A INPUT -j RH-Firewall-1-INPUT
[0:0] -A INPUT -s 141.100.40.65 -j REJECT --reject-with icmp-port-unreachable
[0:0] -A FORWARD -j RH-Firewall-1-INPUT
[298:60074] -A RH-Firewall-1-INPUT -i lo -j ACCEPT
[15:840] -A RH-Firewall-1-INPUT -p icmp -m icmp --icmp-type any -j ACCEPT
[0:0] -A RH-Firewall-1-INPUT -p esp -j ACCEPT
[0:0] -A RH-Firewall-1-INPUT -p ah -j ACCEPT
[0:0] -A RH-Firewall-1-INPUT -d 224.0.0.251 -p udp -m udp --dport 5353 -j ACCEPT
[0:0] -A RH-Firewall-1-INPUT -p udp -m udp --dport 631 -j ACCEPT
[0:0] -A RH-Firewall-1-INPUT -p tcp -m tcp --dport 631 -j ACCEPT
[16260:2705592] -A RH-Firewall-1-INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
[1:164] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 75 -j ACCEPT
[32:3575] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 62613 -j ACCEPT
[0:0] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 23 -j ACCEPT
[0:0] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 25 -j ACCEPT
[603:36311] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 80 -j ACCEPT
[0:0] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 21 -j ACCEPT
[3:180] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 443 -j ACCEPT
[126:7649] -A RH-Firewall-1-INPUT -j REJECT --reject-with icmp-host-prohibited
COMMIT
na czy może polegać problem?
Pozdrawiam,
Neo
Jak sprawdzasz to "twierdzenie"?
Nie jestem pewien, ale tu chyba jest tak, że łańcuch "INPUT" jest przekierowany na nowo utworzony łańcuch "RH-Firewall-1-INPUT" i następująca po nim regułka dot. łańcucha INPUT jest ignorowana. Spróbuj w poleceniu blokującym dostęp do serwera dla IP 141.100.40.65 zmienić INPUT na RH-Firewall-1-INPUT.
Poza tym jak już nie chcesz z tym IP gadać, to chyba lepiej zamiast "-j REJECT --reject-with icmp-port-unreachable" dać "-j DROP" - ciche i skuteczne.
sprawdzam to może dużo powiedziane. :rolleyes:
iptables -L | grep 141.100.40.65
Teraz mam tak:
 cat iptables
# Generated by iptables-save v1.3.5 on Wed May  7 13:53:25 2008
*filter
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [8211:9046271]
[5853:685021] -A INPUT -j RH-Firewall-1-INPUT
[0:0] -A RH-Firewall-1-INPUT -i lo -j ACCEPT
[4:224] -A RH-Firewall-1-INPUT -p icmp -m icmp --icmp-type any -j ACCEPT
[5554:662642] -A RH-Firewall-1-INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
[1:60] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 75 -j ACCEPT
[1:89] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 62613 -j ACCEPT
[228:13656] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 80 -j ACCEPT
[4:216] -A RH-Firewall-1-INPUT -p tcp -m state --state NEW -m tcp --dport 443 -j ACCEPT
[61:8134] -A RH-Firewall-1-INPUT -j REJECT --reject-with icmp-host-prohibited
[0:0] -A RH-Firewall-1-INPUT -s 141.100.40.65 -j REJECT --reject-with icmp-port-unreachable
COMMIT
# Completed on Wed May  7 13:53:25 2008
w sumie to nie kapuje dlaczego:
jesli dodałem poleceniem:
iptables -A RH-Firewall-1-INPUT -s 141.100.40.65 -j REJECT && service iptables save
sprawdzam cały czas z hosta (141.100.40.65) w ten sposób:
suski@stud1:~$ GET -ds sigsiu.net
200 OK
:lammer:
Zaraz... A czy to nie jest w druga stronę ;) Przecież to serwer odpowiada więc raczej zabronic należy serwerowi robić OUTPUT na docelowy 141.100.40.65. To chyba będzie coś w rodzaju:
iptables -A OUTPUT  -d 141.100.40.65 -j REJECT
A jeszcze ciszej będzie w sieci jak zamiast REJECT będzie DROP.
Niestety też nie działa.
Poza tym w dokumentacji iptables podane jest tak jak napisałem powyżej.
Ale za cholere nie działa :lammer:
