maestro Napisano Czerwiec 30, 2008 Zgłoszenie Share Napisano Czerwiec 30, 2008 Wczoraj wszystko bylo ok, a dzis yum sypie mi czyms takim: Wczytane wtyczki: refresh-packagekit YumRepo Warning: not using ftp, http[s], or file for repos, skipping - <html> YumRepo Warning: not using ftp, http[s], or file for repos, skipping - <head> YumRepo Warning: not using ftp, http[s], or file for repos, skipping - <title>Brak autoryzacji...</title> YumRepo Warning: not using ftp, http[s], or file for repos, skipping - <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-2"/> YumRepo Warning: not using ftp, http[s], or file for repos, skipping - <style> YumRepo Warning: not using ftp, http[s], or file for repos, skipping - BODY, TEXT, P, TD { color: gray; } YumRepo Warning: not using ftp, http[s], or file for repos, skipping - INPUT { border: 1px solid #009900; background-color: #112211; color: #00EE00; } YumRepo Warning: not using ftp, http[s], or file for repos, skipping - </style> YumRepo Warning: not using ftp, http[s], or file for repos, skipping - </head> YumRepo Warning: not using ftp, http[s], or file for repos, skipping - <body bgcolor="black"> YumRepo Warning: not using ftp, http[s], or file for repos, skipping - <center><font size="7" color="ligthgreen"><p>BRAK AUTORYZACJI</p></font><font size="5" color="#00EE00"> Traceback (most recent call last): File "/usr/bin/yum", line 29, in <module> yummain.user_main(sys.argv[1:], exit_code=True) File "/usr/share/yum-cli/yummain.py", line 241, in user_main errcode = main(args) File "/usr/share/yum-cli/yummain.py", line 116, in main result, resultmsgs = base.doCommands() File "/usr/share/yum-cli/cli.py", line 307, in doCommands self._getTs() File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 98, in _getTs self._getTsInfo() File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 104, in _getTsInfo self._tsInfo.setDatabases(self.rpmdb, self.pkgSack) File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 576, in <lambda> pkgSack = property(fget=lambda self: self._getSacks(), File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 419, in _getSacks self.repos.populateSack(which=repos) File "/usr/lib/python2.5/site-packages/yum/repos.py", line 245, in populateSack sack.populate(repo, mdtype, callback, cacheonly) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 149, in populate if self._check_db_version(repo, mydbtype): File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 203, in _check_db_version return repo._check_db_version(mdtype) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 928, in _check_db_version repoXML = self.repoXML File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 1086, in <lambda> repoXML = property(fget=lambda self: self._getRepoXML(), File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 1078, in _getRepoXML self._loadRepoXML(text=self) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 1068, in _loadRepoXML return self._groupLoadRepoXML(text, ["primary"]) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 1052, in _groupLoadRepoXML if self._commonLoadRepoXML(text): File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 904, in _commonLoadRepoXML result = self._getFileRepoXML(local, text) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 772, in _getFileRepoXML cache=self.http_caching == 'all') File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 643, in _getFile result = self.grab.urlgrab(relative, local, File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 463, in <lambda> grab = property(lambda self: self._getgrab()) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 458, in _getgrab self._setupGrab() File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 447, in _setupGrab self._grab = mgclass(self._grabfunc, self.urls, File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 548, in <lambda> urls = property(fget=lambda self: self._geturls(), File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 545, in _geturls self._baseurlSetup() File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 514, in _baseurlSetup self.mirrorurls = self._replace_and_check_url(mirrorurls) File "/usr/lib/python2.5/site-packages/yum/yumRepo.py", line 536, in _replace_and_check_url print 'YumRepo Warning: not using ftp, http[s], or file for repos, skipping - %s' % (url) File "/usr/lib/python2.5/codecs.py", line 303, in write data, consumed = self.encode(object, self.errors) UnicodeDecodeError: 'ascii' codec can't decode byte 0xe6 in position 84: ordinal not in range(128) Po prostu masakra. W /etc/yum.repos.d/ mam -rwxr-xr-x 1 root root 1168 maj 6 19:16 fedora.repo -rwxr-xr-x 1 root root 1078 maj 6 19:16 fedora-updates.repo -rwxr-xr-x 1 root root 1151 maj 6 19:16 fedora-updates-testing.repo -rw-r--r-- 1 root root 1904 maj 12 12:00 livna-devel.repo -rw-r--r-- 1 root root 1808 maj 12 12:00 livna.repo -rw-r--r-- 1 root root 2003 maj 12 12:00 livna-testing.repo Bardzo prosze o jakas pomoc, wczoraj jeszcze wszystko bylo ok, dzis nie pamietam dokladnie co robilem, ale na pewno instalowalem repo livny zeby zainstalowac sterowniki nvidii... Z gory dzieki i pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kalashnikov Napisano Czerwiec 30, 2008 Zgłoszenie Share Napisano Czerwiec 30, 2008 Spróbuj wykonać # yum clean all Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
kurzawa Napisano Czerwiec 30, 2008 Zgłoszenie Share Napisano Czerwiec 30, 2008 Jeśli wklejasz linijki kodu używaj opcji code, a jeśli masz więcej niż 15 linijek to codebox. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Czerwiec 30, 2008 Zgłoszenie Share Napisano Czerwiec 30, 2008 Dla pozostałych: link do zawartości plików repo: http://forum.fedora.pl/index.php?s=&sh...st&p=109622 W jaki sposób łączysz się z siecią? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
maestro Napisano Lipiec 1, 2008 Autor Zgłoszenie Share Napisano Lipiec 1, 2008 OK. Yum clean all zadziałało! Dziekuje za pomoc Nie wiem co sie stalo z ta konfiguracją, ale wazne ze jest juz ok. Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
