Elthar Napisano Wrzesień 11, 2008 Zgłoszenie Share Napisano Wrzesień 11, 2008 Witam Kiedy zorentowałem się, że Myth TV znajduje się w repozytorium próbowałem je zainstalować standardowo poprzez yum. Podczas testu transakcji wyskakuje mi: Błąd podczas sprawdzania transakcji: file /usr/lib/libavformat.so.52.7.0 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 and libavformat52-0.4.9-26_r12135.fc9.i386 file /usr/lib/libpostproc.so.51.1.0 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 and libpostproc51-0.4.9-26_r12135.fc9.i386 file /usr/lib/vhook/drawtext.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 and ffmpeg-0.4.9-26_r12135.fc9.i386 file /usr/lib/vhook/fish.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 and ffmpeg-0.4.9-26_r12135.fc9.i386 file /usr/lib/vhook/imlib2.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 and ffmpeg-0.4.9-26_r12135.fc9.i386 file /usr/lib/vhook/null.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 and ffmpeg-0.4.9-26_r12135.fc9.i386 file /usr/lib/vhook/ppm.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 and ffmpeg-0.4.9-26_r12135.fc9.i386 file /usr/lib/vhook/watermark.so conflicts between attempted installs of ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 and ffmpeg-0.4.9-26_r12135.fc9.i386 file /usr/lib/libswscale.so.0.5.0 conflicts between attempted installs of libswscale0-0.4.9-26_r12135.fc9.i386 and ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 file /usr/lib/libavcodec.so.51.50.1 conflicts between attempted installs of libavcodec51-0.4.9-26_r12135.fc9.i386 and ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 file /usr/lib/libfaad.so.0.0.0 from install of faad2-2.6.1-8.fc9.i386 conflicts with file from package faad2-libs-2.6.1-3.lvn9.i386 file /usr/lib/libavutil.so.49.6.0 conflicts between attempted installs of libavutil49-0.4.9-26_r12135.fc9.i386 and ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 file /usr/lib/libavdevice.so.52.0.0 conflicts between attempted installs of libavdevice52-0.4.9-26_r12135.fc9.i386 and ffmpeg-libs-0.4.9-0.46.20080225.lvn9.i386 Próbowałem także przez yum wywalić paczki ffmpeg-libs i libpostproc51 efekt [root@localhost mythtv-0.21]# yum remove ffmpeg-libs Wczytane wtyczki: priorities, refresh-packagekit Ustawianie procesu usuwania Brak wyników dla argumentu: ffmpeg-libs Brak pakietów oznaczonych do usunięcia Co powinienem zrobić w takiej sytuacji? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Wrzesień 11, 2008 Zgłoszenie Share Napisano Wrzesień 11, 2008 Co powinienem zrobić w takiej sytuacji?1.Sprawdzić jakie masz włączone repozytoria. Na forum jest sporo postów nt. "gryzących" się repozytoriów. Jeśli są jakieś z tych, które wzajemnie sobie przeszkadzają, to warto zapoznać się z możliwościami wtyczki yum-priorities 2.Skąd masz paczki ffmpeg w systemie? Pokaż wyjście polecenia: rpm -qa | grep ffmpeg Kiedy zorentowałem się, że Myth TV znajduje się w repozytorium próbowałem je zainstalować standardowo poprzez yumA przedtem próbowałeś to instalować jakoś inaczej? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Elthar Napisano Wrzesień 11, 2008 Autor Zgłoszenie Share Napisano Wrzesień 11, 2008 1.Sprawdzić jakie masz włączone repozytoria. Na forum jest sporo postów nt. "gryzących" się repozytoriów. Jeśli są jakieś z tych, które wzajemnie sobie przeszkadzają, to warto zapoznać się z możliwościami wtyczki yum-priorities Jak mogę z niej skorzystać? 2.Skąd masz paczki ffmpeg w systemie? Pokaż wyjście polecenia:rpm -qa | grep ffmpeg Na wyjściu nie dostałem żadnego komunikatu, a ostatnio instalowałem wiele multimediów i nie wiem skąd jest ffmpeg A przedtem próbowałeś to instalować jakoś inaczej Tak próbowałem kompilować ze źródeł i nawet udało mi się uruchmić mythtv, ale utknąłem na konfiguracji MySQL więc pomyślalłem że zainstalowanie MythTV z repo załatwi ten problem. Dodam, że przed instalacją wszedłem do folderu mythtv i wykonałem make uninstall Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Wrzesień 11, 2008 Zgłoszenie Share Napisano Wrzesień 11, 2008 Jak mogę z niej skorzystać?Moja sygnaturka + Google Na forum jakiś czas temu ktoś opisał jak to działa i jak ustawić Na wyjściu nie dostałem żadnego komunikatuCzyli zapewne instalacja ze źródeł przy okazji jakichś innych multimediów. Tak próbowałem kompilować ze źródełWięc nie dziw się, że teraz masz kłopoty. Jeśli masz jeszcze katalog ze źródłami, z których kompilowałeś, to spróbuj make uninstall, ale wiele bym sobie po tym nie obiecywał. Na przyszłość (bo pewnie skończy się reinstalacją systemu) nie kombinuj ze źródłami jeśli coś jest w repo, chyba że wiesz dokładnie co robisz. Ręczna deinstalacja programów własnoręcznie kompilowanych (o ile nie robiłeś z nich RPMów) jest uciążliwa w usuwaniu, aktualizacji itd. Możesz próbować z checkinstall, ale to nie buduje poprawnych RPMów dla Fedory. Obawiam się, że w tej sytuacji nie jestem w stanie Ci pomóc. Może ktoś inny spróbuje swoich sił. Powodzenia. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Elthar Napisano Wrzesień 11, 2008 Autor Zgłoszenie Share Napisano Wrzesień 11, 2008 Tak właśnie myślałem że skończy się na reinstalce. Niemniej dzięki za pomoc i za te kilka rad, które na pewno przydadzą się w przyszłości. Jak na razie łącze jeszcze Linux z Windowsem i moja wiedza jest dość niewielka. Linux jest niejako wyzwaniem, dlatego czasem, gdy mam ochotę na "coś więcej" to kombinuję i uczę się. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
