Postfix - Wyslana Wiadomosc Nie Dochodzi Do Odbiorcy
szczygiel
Witam,
mam taki problem, ze gdy wysylam wiadomosc e-mail z tego samego konta na to samo konto badz z innego konta na inne konto, ale w obrebie sieci wewnetrznej wiadomosc wysyla sie, ale odbiorca jej nie odbiera nic nie trafia do jego skrzynki odbiorczej. Natomiast jesli zastosuje polecenie "maildrop -V9 -d [email protected]" to wiadomosc zostaje odebrana.
Log /var/log/maillog:
Feb 3 09:02:44 server1 postfix/cleanup[3335]: 377B65336C: message-id=<[email protected]>
Feb 3 09:02:45 server1 postfix/qmgr[3315]: 377B65336C: from=<[email protected]>, size=575, nrcpt=1 (queue active)
Feb 3 09:02:45 server1 postfix/smtpd[3326]: disconnect from server1.example.com[127.0.0.1]
Feb 3 09:02:45 server1 postfix/smtp[3337]: 377B65336C: to=<[email protected]>, relay=none, delay=1.2, delays=1.1/0.09/0/0, dsn=5.4.6, status=bounced (mail for 127.0.0.1 loops back to myself)
Feb 3 09:02:45 server1 postfix/cleanup[3335]: BC74F5336E: message-id=<[email protected]>
Feb 3 09:02:45 server1 postfix/bounce[3338]: 377B65336C: sender non-delivery notification: BC74F5336E
Feb 3 09:02:45 server1 postfix/qmgr[3315]: 377B65336C: removed
Feb 3 09:02:45 server1 postfix/qmgr[3315]: BC74F5336E: from=<>, size=2368, nrcpt=1 (queue active)
Feb 3 09:02:45 server1 postfix/smtp[3337]: BC74F5336E: to=<[email protected]>, relay=none, delay=0.04, delays=0.03/0.01/0.01/0, dsn=5.4.6, status=bounced (mail for 127.0.0.1 loops back to myself)
Feb 3 09:02:45 server1 postfix/qmgr[3315]: BC74F5336E: removed
Feb 3 09:05:11 server1 pop3d: Connection, ip=[::ffff:127.0.0.1]
Feb 3 09:05:11 server1 pop3d: LOGIN, [email protected], ip=[::ffff:127.0.0.1], port=[37860]
Feb 3 09:05:11 server1 pop3d: LOGOUT, [email protected], ip=[::ffff:127.0.0.1], port=[37860], top=0, retr=0, rcvd=12, sent=39, time=0
Feb 3 09:15:11 server1 pop3d: Connection, ip=[::ffff:127.0.0.1]
Feb 3 09:15:12 server1 pop3d: LOGIN, [email protected], ip=[::ffff:127.0.0.1], port=[44029]
Feb 3 09:15:12 server1 pop3d: LOGOUT, [email protected], ip=[::ffff:127.0.0.1], port=[44029], top=0, retr=0, rcvd=12, sent=39, time=0
Jaki jest blad ?
Dzieki
wciaz nie wiem gdzie tkwi problem o to log:
Feb 11 12:03:51 server1 postfix/smtpd[3014]: connect from eee[10.0.2.20]
Feb 11 12:03:51 server1 postfix/smtpd[3014]: DD55652F00: client=eee[10.0.2.20]
Feb 11 12:03:51 server1 postfix/cleanup[3022]: DD55652F00: message-id=<07C37479B2074FC69B81B9678691B840@eee>
Feb 11 12:03:52 server1 postfix/qmgr[1983]: DD55652F00: from=<[email protected]>, size=1304, nrcpt=1 (queue active)
Feb 11 12:03:52 server1 postfix/smtpd[3014]: disconnect from eee[10.0.2.20]
Feb 11 12:03:52 server1 postfix/smtp[3024]: DD55652F00: to=<[email protected]>, relay=none, delay=0.19, delays=0.14/0.04/0/0, dsn=5.4.6, status=bounced (mail for 127.0.0.1 loops back to myself)
Feb 11 12:03:52 server1 postfix/cleanup[3022]: 19A13533A9: message-id=<20090211110352.19A13533A9@server1>
Feb 11 12:03:52 server1 postfix/qmgr[1983]: 19A13533A9: from=<>, size=2989, nrcpt=1 (queue active)
Feb 11 12:03:52 server1 postfix/bounce[3025]: DD55652F00: sender non-delivery notification: 19A13533A9
Feb 11 12:03:52 server1 postfix/qmgr[1983]: DD55652F00: removed
Feb 11 12:03:52 server1 postfix/smtp[3024]: 19A13533A9: to=<[email protected]>, relay=none, delay=0.04, delays=0.03/0.01/0/0, dsn=5.4.6, status=bounced (mail for 127.0.0.1 loops back to myself)
Feb 11 12:03:52 server1 postfix/qmgr[1983]: 19A13533A9: removed
  • 2 months later...
Sprawdz mynetworks / amavisa
master.cf
Wyglada jakby maile sie zapetliły
  • 1 year later...
