linuxiarz Napisano Wrzesień 20, 2009 Zgłoszenie Share Napisano Wrzesień 20, 2009 Witam, mam problem nastepujacy - gdy daje katalog domowy --> edycja --> preferencje, chcac by Fedora pokazywala mi tez ukryte i systemowe foldery, wyskakuje takie cos : Distribution: Fedora release 11 (Leonidas) Gnome Release: 2.26.3 2009-07-07 (Red Hat, Inc) BugBuddy Version: 2.26.0 System: Linux 2.6.30.5-43.fc11.i586 #1 SMP Thu Aug 27 21:18:54 EDT 2009 i686 X Vendor: The X.Org Foundation X Vendor Release: 10603000 Selinux: Enforcing Accessibility: Disabled GTK+ Theme: Nodoka Icon Theme: Fedora GTK+ Modules: canberra-gtk-module, pk-gtk-module, gnomebreakpad Memory status: size: 0 vsize: 0 resident: 0 share: 0 rss: 0 rss_rlim: 0 CPU usage: start_time: 0 rtime: 0 utime: 0 stime: 0 cutime:0 cstime: 0 timeout: 0 it_real_value: 0 frequency: 0 ---- Critical and fatal warnings logged during execution ---- ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** Gtk **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed ** GLib-GObject **: g_object_set_data_full: assertion `G_IS_OBJECT (object)' failed ** Gtk **: gtk_widget_set_sensitive: assertion `GTK_IS_WIDGET (widget)' failed ** GLib-GObject **: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed ** GLib-GObject **: g_signal_handlers_block_matched: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed ** GLib-GObject **: g_object_get_data: assertion `G_IS_OBJECT (object)' failed ----------- .xsession-errors --------------------- (nautilus:5196): Gtk-CRITICAL **: gtk_combo_box_append_text: assertion `GTK_IS_COMBO_BOX (combo_box)' failed (nautilus:5196): GLib-GObject-CRITICAL **: g_object_set_data_full: assertion `G_IS_OBJECT (object)' failed (nautilus:5196): Gtk-CRITICAL **: gtk_widget_set_sensitive: assertion `GTK_IS_WIDGET (widget)' failed (nautilus:5196): GLib-GObject-WARNING **: invalid (NULL) pointer instance (nautilus:5196): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed (nautilus:5196): GLib-GObject-WARNING **: invalid (NULL) pointer instance (nautilus:5196): GLib-GObject-CRITICAL **: g_signal_handlers_block_matched: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed (nautilus:5196): GLib-GObject-CRITICAL **: g_object_get_data: assertion `G_IS_OBJECT (object)' failed -------------------------------------------------- Prosilbym o pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
matlas Napisano Wrzesień 20, 2009 Zgłoszenie Share Napisano Wrzesień 20, 2009 Mam to samo, nie moge sie dostac do preferencji nautilusa zeby zmienic opcje otwierania w 1 oknie, a nie w nowym .... :/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Wrzesień 20, 2009 Zgłoszenie Share Napisano Wrzesień 20, 2009 Jest na bugzilli i pewnie niedługo doczekamy się poprawki. EDIT: Jak komuś się spieszy to http://koji.fedoraproject.org/koji/buildinfo?buildID=132609 * Fri Sep 18 2009 Tomas Bzatek <[email protected]> - 2.26.3-3 - Make nautilus-file-management-properties not crash on start (#523749) EDIT2: yum update nautilus --enablerepo=updates-testing Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
linuxiarz Napisano Wrzesień 20, 2009 Autor Zgłoszenie Share Napisano Wrzesień 20, 2009 THX Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dj_oko Napisano Wrzesień 21, 2009 Zgłoszenie Share Napisano Wrzesień 21, 2009 Zawsze można posłużyć się Edytorem Konfiguracji (gconf-editor) i odnaleźć w /apps/nautilus/preferences (albo desktop, nie pamiętam) klucz always_use_browser. Wystarczy zmienić jego wartość na prawdziwą. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
