movsd Napisano Listopad 25, 2009 Zgłoszenie Share Napisano Listopad 25, 2009 Staram się skonfigurować sieć w runlevel 3 (pod 5 chodzi bezbłędnie - pod 3 nie mam sieci w ogóle). Sieć jest zabezpieczona, wpa2 aes. polecenie: wpa_supplicant -D wext -i wlan0 -e /etc/wpa_supplicant/wpa_supplicant.conf daje rezultat taki zapętlony: [ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:00:00:00:00:00 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with ioctl[sIOCSIWSCAN]: Device or resource busy ioctl[sIOCSIWSCAN]: Device or resource busy 00:23:cd:ce:4d:40 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. Trying to associate with 00:23:cd:ce:4d:40 (SSID='TP-LINK' freq=2437 MHz) Associated with 00:00:00:00:00:00 CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Failed to initiate AP scan. CTRL-EVENT-TERMINATING - signal 2 received wpa_supplicant.conf ctrl_interface=/var/run/wpa_supplicant ctrl_interface_group=0 ap_scan=1 network={ ssid="TP-LINK" proto=WPA2 key_mgmt=WPA-PSK pairwise=CCMP group=CCMP #psk="haslo" psk=haslo w hexach } Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Listopad 26, 2009 Zgłoszenie Share Napisano Listopad 26, 2009 Nie wiem, ale zobacz to http://wiki.archlinux.org/index.php/WPA_supplicant . Poza tym w jaki sposób NM sobie z tym radzi? Bo NM można uruchomić w trybie tekstowego daemona. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
movsd Napisano Listopad 26, 2009 Autor Zgłoszenie Share Napisano Listopad 26, 2009 Okazało się, że był jakiś konflikt pomiędzy NetworkManager i wpa_supplicant. Odinstalowałem NM (yum remove NetowrkManager) i wszystko działa. Pozdrawiam. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
