Nieobecne Man Pages
filiprem
Nie siedź na roocie.
Nie siedzę na roocie, siedzę na krześle ;-)
Coś w ogóle wypisuje po wpisaniu man ls?
Wypisuje to:
[root@host:~]$ man ls
No manual entry for ls
Z opcją '-d' wypisuje więcej - ale nadal nic mi to nie mówi.
[root@host:~]$ man -d ls
Reading config file /etc/man.config
found man directory /usr/man
found man directory /usr/share/man
found man directory /usr/local/man
found man directory /usr/local/share/man
found man directory /usr/X11R6/man
found manpath map /bin --> /usr/share/man
found manpath map /sbin --> /usr/share/man
found manpath map /usr/bin --> /usr/share/man
found manpath map /usr/sbin --> /usr/share/man
found manpath map /usr/local/bin --> /usr/local/share/man
found manpath map /usr/local/sbin --> /usr/local/share/man
found manpath map /usr/X11R6/bin --> /usr/X11R6/man
found manpath map /usr/bin/X11 --> /usr/X11R6/man
found manpath map /usr/bin/mh --> /usr/share/man
using less as pager
using /usr/bin/less -is as browser
using /bin/cat to dump HTML pages as text
path directory /usr/local/bin is in the config file
adding /usr/local/share/man to manpath
path directory /bin is in the config file
adding /usr/share/man/en to manpath
adding /usr/share/man to manpath
path directory /usr/bin is in the config file
path directory /usr/local/sbin is in the config file
path directory /usr/sbin is in the config file
path directory /sbin is in the config file
path directory /usr/lib/jvm/java-6-sun/bin is not in the config file
and we found no man directory nearby
path directory /home/filip/bin is not in the config file
adding mandatory man directories
Sprawdź, co jest w tych katalogach. Może nie ma nic? (co najmniej dziwne by to było) No i może reinstalacja pomoże?
Dokładnie, nie ma nic. Reinstalacja (przez yum reinstall man-pages) nie pomaga.
[root@host ~]# rpm -ql man-pages | grep -w cp
/usr/share/man/man1p/cp.1p.gz
[root@host ~]# ls /usr/share/man/man1p/cp.1p.gz
ls: cannot access /usr/share/man/man1p/cp.1p.gz: No such file or directory
  • 1 year later...
Witam,
podłączam się pod wątek, gdyż u mnie też strony manuala nie działają, co stało się po aktualizacji systemu z F15 do F16.
Poniżej trochę diagnostyki, :rolleyes:
[aaa@aaa ~]$ rpm -qa|grep man-pages
man-pages-3.32-14.fc16.noarch
man-pages-pl-0.24-12.fc16.noarch
[aaa@aaa ~]$ /usr/bin/manpath
/usr/bin/manpath: warning: $MANPATH set, ignoring /etc/man_db.conf
/usr/share/man/mpich2
[aaa@aaa ~]$ man ls
[aaa@aaa ~]$ man -d ls
From the config file /etc/man_db.conf:
Mandatory mandir `/usr/man'.
Mandatory mandir `/usr/share/man'.
Mandatory mandir `/usr/local/share/man'.
Path `/bin' mapped to mandir `/usr/share/man'.
Path `/usr/bin' mapped to mandir `/usr/share/man'.
Path `/sbin' mapped to mandir `/usr/share/man'.
Path `/usr/sbin' mapped to mandir `/usr/share/man'.
Path `/usr/local/bin' mapped to mandir `/usr/local/man'.
Path `/usr/local/bin' mapped to mandir `/usr/local/share/man'.
Path `/usr/local/sbin' mapped to mandir `/usr/local/man'.
Path `/usr/local/sbin' mapped to mandir `/usr/local/share/man'.
Path `/usr/X11R6/bin' mapped to mandir `/usr/X11R6/man'.
Path `/usr/bin/X11' mapped to mandir `/usr/X11R6/man'.
Path `/usr/games' mapped to mandir `/usr/share/man'.
Path `/opt/bin' mapped to mandir `/opt/man'.
Path `/opt/sbin' mapped to mandir `/opt/man'.
Global mandir `/usr/man', catdir `/var/cache/man/fsstnd'.
Global mandir `/usr/share/man', catdir `/var/cache/man'.
Global mandir `/usr/local/man', catdir `/var/cache/man/oldlocal'.
Global mandir `/usr/local/share/man', catdir `/var/cache/man/local'.
Global mandir `/usr/X11R6/man', catdir `/var/cache/man/X11R6'.
Global mandir `/opt/man', catdir `/var/cache/man/opt'.
Added section `1'.
Added section `1p'.
Added section `8'.
Added section `2'.
Added section `3'.
Added section `3p'.
Added section `4'.
Added section `5'.
Added section `6'.
Added section `7'.
Added section `9'.
Added section `0p'.
Added section `n'.
Added section `l'.
Added section `p'.
Added section `o'.
Added section `1x'.
Added section `2x'.
Added section `3x'.
Added section `4x'.
Added section `5x'.
Added section `6x'.
Added section `7x'.
Added section `8x'.
`/usr/man'	`'	`1'
`/usr/share/man'	`'	`1'
`/usr/local/share/man'	`'	`1'
`/bin'	`/usr/share/man'	`0'
`/usr/bin'	`/usr/share/man'	`0'
`/sbin'	`/usr/share/man'	`0'
`/usr/sbin'	`/usr/share/man'	`0'
`/usr/local/bin'	`/usr/local/man'	`0'
`/usr/local/bin'	`/usr/local/share/man'	`0'
`/usr/local/sbin'	`/usr/local/man'	`0'
`/usr/local/sbin'	`/usr/local/share/man'	`0'
`/usr/X11R6/bin'	`/usr/X11R6/man'	`0'
`/usr/bin/X11'	`/usr/X11R6/man'	`0'
`/usr/games'	`/usr/share/man'	`0'
`/opt/bin'	`/opt/man'	`0'
`/opt/sbin'	`/opt/man'	`0'
`/usr/man'	`/var/cache/man/fsstnd'	`-1'
`/usr/share/man'	`/var/cache/man'	`-1'
`/usr/local/man'	`/var/cache/man/oldlocal'	`-1'
`/usr/local/share/man'	`/var/cache/man/local'	`-1'
`/usr/X11R6/man'	`/var/cache/man/X11R6'	`-1'
`/opt/man'	`/var/cache/man/opt'	`-1'
`1'	`'	`-5'
`1p'	`'	`-5'
`8'	`'	`-5'
`2'	`'	`-5'
`3'	`'	`-5'
`3p'	`'	`-5'
`4'	`'	`-5'
`5'	`'	`-5'
`6'	`'	`-5'
`7'	`'	`-5'
`9'	`'	`-5'
`0p'	`'	`-5'
`n'	`'	`-5'
`l'	`'	`-5'
`p'	`'	`-5'
`o'	`'	`-5'
`1x'	`'	`-5'
`2x'	`'	`-5'
`3x'	`'	`-5'
`4x'	`'	`-5'
`5x'	`'	`-5'
`6x'	`'	`-5'
`7x'	`'	`-5'
`8x'	`'	`-5'
is a tty
using less -s as pager
add_nls_manpaths(): processing /usr/share/man/mpich2
checking for locale en_US.UTF-8
manpath search path (with duplicates) = /usr/share/man/mpich2:/usr/share/man/mpich2
adding /usr/share/man/mpich2 to manpathlist
Removing duplicate manpath entry /usr/share/man/mpich2 (1) -> /usr/share/man/mpich2 (0)
final search path = /usr/share/man/mpich2
searching in /usr/share/man/mpich2, section 1
trying section 1 with globbing
Layout is GNU (1)
update_directory_cache /usr/share/man/mpich2: miss
globbing pattern in /usr/share/man/mpich2: man1*
matched: /usr/share/man/mpich2/man1
update_directory_cache /usr/share/man/mpich2/man1: miss
globbing pattern in /usr/share/man/mpich2/man1: ls.1*
update_directory_cache /usr/share/man/mpich2: hit
globbing pattern in /usr/share/man/mpich2: cat1*
Failed to open /var/cache/man/mpich2/index.db O_RDONLY
searching in /usr/share/man/mpich2, section 1p
trying section 1p with globbing
update_directory_cache /usr/share/man/mpich2/man1: hit
globbing pattern in /usr/share/man/mpich2/man1: ls.1p*
searching in /usr/share/man/mpich2, section 8
trying section 8 with globbing
globbing pattern in /usr/share/man/mpich2: man8*
globbing pattern in /usr/share/man/mpich2: cat8*
searching in /usr/share/man/mpich2, section 2
trying section 2 with globbing
globbing pattern in /usr/share/man/mpich2: man2*
globbing pattern in /usr/share/man/mpich2: cat2*
searching in /usr/share/man/mpich2, section 3
trying section 3 with globbing
globbing pattern in /usr/share/man/mpich2: man3*
globbing pattern in /usr/share/man/mpich2: cat3*
searching in /usr/share/man/mpich2, section 3p
trying section 3p with globbing
searching in /usr/share/man/mpich2, section 4
trying section 4 with globbing
globbing pattern in /usr/share/man/mpich2: man4*
globbing pattern in /usr/share/man/mpich2: cat4*
searching in /usr/share/man/mpich2, section 5
trying section 5 with globbing
globbing pattern in /usr/share/man/mpich2: man5*
globbing pattern in /usr/share/man/mpich2: cat5*
searching in /usr/share/man/mpich2, section 6
trying section 6 with globbing
globbing pattern in /usr/share/man/mpich2: man6*
globbing pattern in /usr/share/man/mpich2: cat6*
searching in /usr/share/man/mpich2, section 7
trying section 7 with globbing
globbing pattern in /usr/share/man/mpich2: man7*
globbing pattern in /usr/share/man/mpich2: cat7*
searching in /usr/share/man/mpich2, section 9
trying section 9 with globbing
globbing pattern in /usr/share/man/mpich2: man9*
globbing pattern in /usr/share/man/mpich2: cat9*
searching in /usr/share/man/mpich2, section 0p
trying section 0p with globbing
globbing pattern in /usr/share/man/mpich2: man0*
globbing pattern in /usr/share/man/mpich2: cat0*
searching in /usr/share/man/mpich2, section n
trying section n with globbing
globbing pattern in /usr/share/man/mpich2: mann*
globbing pattern in /usr/share/man/mpich2: catn*
searching in /usr/share/man/mpich2, section l
trying section l with globbing
globbing pattern in /usr/share/man/mpich2: manl*
globbing pattern in /usr/share/man/mpich2: catl*
searching in /usr/share/man/mpich2, section p
trying section p with globbing
globbing pattern in /usr/share/man/mpich2: manp*
globbing pattern in /usr/share/man/mpich2: catp*
searching in /usr/share/man/mpich2, section o
trying section o with globbing
globbing pattern in /usr/share/man/mpich2: mano*
globbing pattern in /usr/share/man/mpich2: cato*
searching in /usr/share/man/mpich2, section 1x
trying section 1x with globbing
globbing pattern in /usr/share/man/mpich2/man1: ls.1x*
searching in /usr/share/man/mpich2, section 2x
trying section 2x with globbing
searching in /usr/share/man/mpich2, section 3x
trying section 3x with globbing
searching in /usr/share/man/mpich2, section 4x
trying section 4x with globbing
searching in /usr/share/man/mpich2, section 5x
trying section 5x with globbing
searching in /usr/share/man/mpich2, section 6x
trying section 6x with globbing
searching in /usr/share/man/mpich2, section 7x
trying section 7x with globbing
searching in /usr/share/man/mpich2, section 8x
trying section 8x with globbing
hashtable_free: 1 entries, 1 (100%) unique
hashtable_free: 2 entries, 2 (100%) unique
