SDC Napisano Czerwiec 12, 2010 Zgłoszenie Share Napisano Czerwiec 12, 2010 (edytowane) Witam, występuje problem z aktualizacją. Jak to rozwiązać? [root@localhost kuba]# yum search update Wczytane wtyczki: dellsysidplugin2, refresh-packagekit Traceback (most recent call last): File "/usr/bin/yum", line 29, in <module> yummain.user_main(sys.argv[1:], exit_code=True) File "/usr/share/yum-cli/yummain.py", line 311, in user_main errcode = main(args) File "/usr/share/yum-cli/yummain.py", line 180, in main result, resultmsgs = base.doCommands() File "/usr/share/yum-cli/cli.py", line 353, in doCommands return self.yum_cli_commands[self.basecmd].doCommand(self, self.basecmd, self.extcmds) File "/usr/share/yum-cli/yumcommands.py", line 628, in doCommand return base.search(extcmds) File "/usr/share/yum-cli/cli.py", line 804, in search for (po, keys, matched_value) in matching: File "/usr/lib/python2.6/site-packages/yum/__init__.py", line 1922, in searchGenerator for sack in self.pkgSack.sacks.values(): File "/usr/lib/python2.6/site-packages/yum/__init__.py", line 702, in <lambda> pkgSack = property(fget=lambda self: self._getSacks(), File "/usr/lib/python2.6/site-packages/yum/__init__.py", line 538, in _getSacks self.repos.populateSack(which=repos) File "/usr/lib/python2.6/site-packages/yum/repos.py", line 277, in populateSack sack.populate(repo, mdtype, callback, cacheonly) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 164, in populate if self._check_db_version(repo, mydbtype): File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 222, in _check_db_version return repo._check_db_version(mdtype) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1222, in _check_db_version repoXML = self.repoXML File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1386, in <lambda> repoXML = property(fget=lambda self: self._getRepoXML(), File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1378, in _getRepoXML self._loadRepoXML(text=self) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1368, in _loadRepoXML return self._groupLoadRepoXML(text, ["primary"]) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1351, in _groupLoadRepoXML if self._commonLoadRepoXML(text): File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1197, in _commonLoadRepoXML result = self._getFileRepoXML(local, text) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 976, in _getFileRepoXML cache=self.http_caching == 'all') File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 797, in _getFile result = self.grab.urlgrab(misc.to_utf8(relative), local, File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 498, in <lambda> grab = property(lambda self: self._getgrab()) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 493, in _getgrab self._setupGrab() File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 482, in _setupGrab self._grab = mgclass(self._grabfunc, self.urls, File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 655, in <lambda> urls = property(fget=lambda self: self._geturls(), File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 652, in _geturls self._baseurlSetup() File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 606, in _baseurlSetup mirrorurls.extend(self._getMirrorList()) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1625, in _getMirrorList print "Could not retrieve mirrorlist %s error was\n%s" % (url, e) File "/usr/lib/python2.6/codecs.py", line 351, in write data, consumed = self.encode(object, self.errors) UnicodeDecodeError: 'ascii' codec can't decode byte 0xc5 in position 153: ordinal not in range(128) Edytowane Czerwiec 12, 2010 przez WalDo Przy wklejaniu wyjścia terminal, kodów itp należy stosować [codebox][/codebox] lub [code][/code] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
borzole Napisano Czerwiec 12, 2010 Zgłoszenie Share Napisano Czerwiec 12, 2010 zacznij od wyłączenia pluginów i nie ma czegoś takiego jak "search update" jeśli już chcesz tylko sprawdzić dostępność aktualizacji to wklep yum check-update --noplugins jak nie pomoże to wyczyść cache yum clean all --noplugins zgłoś się jak będzie nadal kicha Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SDC Napisano Czerwiec 12, 2010 Autor Zgłoszenie Share Napisano Czerwiec 12, 2010 (edytowane) Pomogło. Cały czas stosowałem yum search update. Od kilku wydań fedory. Dzięki za pomoc: Edytowane Czerwiec 12, 2010 przez SDC usunięcie bezsensownych cytatów Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SDC Napisano Czerwiec 12, 2010 Autor Zgłoszenie Share Napisano Czerwiec 12, 2010 (edytowane) Jednak dalej problem, pobiera jakieś pliki i.. kuba@localhost ~]$ su Hasło: [root@localhost kuba]# yum clean all --noplugins Czyszczenie wszystkiego [root@localhost kuba]# yum check-update --noplugins fedora/metalink | 27 kB 00:01 fedora | 3.8 kB 00:00 fedora/primary_db | 8.4 MB 01:20 google-chrome | 951 B 00:00 google-chrome/primary | 3.1 kB 00:00 google-chrome 5/5 Traceback (most recent call last): File "/usr/bin/yum", line 29, in <module> yummain.user_main(sys.argv[1:], exit_code=True) File "/usr/share/yum-cli/yummain.py", line 311, in user_main errcode = main(args) File "/usr/share/yum-cli/yummain.py", line 180, in main result, resultmsgs = base.doCommands() File "/usr/share/yum-cli/cli.py", line 349, in doCommands self._getTs(needTsRemove) File "/usr/lib/python2.6/site-packages/yum/depsolve.py", line 100, in _getTs self._getTsInfo(remove_only) File "/usr/lib/python2.6/site-packages/yum/depsolve.py", line 111, in _getTsInfo pkgSack = self.pkgSack File "/usr/lib/python2.6/site-packages/yum/__init__.py", line 702, in <lambda> pkgSack = property(fget=lambda self: self._getSacks(), File "/usr/lib/python2.6/site-packages/yum/__init__.py", line 538, in _getSacks self.repos.populateSack(which=repos) File "/usr/lib/python2.6/site-packages/yum/repos.py", line 277, in populateSack sack.populate(repo, mdtype, callback, cacheonly) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 164, in populate if self._check_db_version(repo, mydbtype): File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 222, in _check_db_version return repo._check_db_version(mdtype) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1222, in _check_db_version repoXML = self.repoXML File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1386, in <lambda> repoXML = property(fget=lambda self: self._getRepoXML(), File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1378, in _getRepoXML self._loadRepoXML(text=self) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1368, in _loadRepoXML return self._groupLoadRepoXML(text, ["primary"]) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1351, in _groupLoadRepoXML if self._commonLoadRepoXML(text): File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1197, in _commonLoadRepoXML result = self._getFileRepoXML(local, text) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 976, in _getFileRepoXML cache=self.http_caching == 'all') File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 797, in _getFile result = self.grab.urlgrab(misc.to_utf8(relative), local, File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 498, in <lambda> grab = property(lambda self: self._getgrab()) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 493, in _getgrab self._setupGrab() File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 482, in _setupGrab self._grab = mgclass(self._grabfunc, self.urls, File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 655, in <lambda> urls = property(fget=lambda self: self._geturls(), File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 652, in _geturls self._baseurlSetup() File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 606, in _baseurlSetup mirrorurls.extend(self._getMirrorList()) File "/usr/lib/python2.6/site-packages/yum/yumRepo.py", line 1625, in _getMirrorList print "Could not retrieve mirrorlist %s error was\n%s" % (url, e) File "/usr/lib/python2.6/codecs.py", line 351, in write data, consumed = self.encode(object, self.errors) UnicodeDecodeError: 'ascii' codec can't decode byte 0xc5 in position 153: ordinal not in range(128) [root@localhost kuba]# Edytowane Czerwiec 12, 2010 przez WalDo Proszę po raz ostatni o znaczniki - patrz komentarz w post #1 :> Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość nick Napisano Czerwiec 19, 2010 Zgłoszenie Share Napisano Czerwiec 19, 2010 " File "/usr/lib/python2.6/site-packages/yum/__init__.py", line 2407, in groupRemove raise Errors.GroupsError, _("No Group named %s exists") % grpid UnicodeDecodeError: 'ascii' codec can't decode byte 0xc5 in position 3: ordinal not in range(128)" Udało mi się wywołać błąd jak powyżej. Wpisałem yum remove "Obsługa gruzinskiego" Czyli zamiast litery ń napisałem samo n Zatem taki błąd yuma wskazuje na literówkę. W twoim przypadku błąd tkwi w URL. Chyba jakiegoś mirrora? "Could not retrieve mirrorlist %s error was\n%s" % (url, e)" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
