F13_32bit Napisano Lipiec 24, 2010 Zgłoszenie Share Napisano Lipiec 24, 2010 Co tu zrobic ??? What is the location of the directory of C header files that match your running kernel? [/usr/src/linux/include] instalacja VMWare v2.0.2 pod Fedora v13 32bit [root@plfalfl10 bin]# ./vmware-config.pl Making sure services for VMware Server are stopped. Stopping VMware autostart virtual machines: Virtual machines [FAILED] Stopping VMware management services: VMware Virtual Infrastructure Web Access VMware Server Host Agent [FAILED] Stopping VMware services: VMware Authentication Daemon [ OK ] Virtual machine monitor [ OK ] None of the pre-built vmmon modules for VMware Server is suitable for your running kernel. Do you want this program to try to build the vmmon module for your system (you need to have a C compiler installed on your system)? [yes] yes Using compiler "/usr/bin/gcc". Use environment variable CC to override. What is the location of the directory of C header files that match your running kernel? [/usr/src/linux/include] folder /usr/src/linux/include nie istnieje SOS Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dither Napisano Lipiec 24, 2010 Zgłoszenie Share Napisano Lipiec 24, 2010 zainstaluj pakiet kernel-devel Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
F13_32bit Napisano Lipiec 24, 2010 Autor Zgłoszenie Share Napisano Lipiec 24, 2010 ten pakiet kernel-devel-2.6.33.6-147.fc13.i686 jest/byl zainstalowany [root@plfalfl10 Downloads]# rpm -qa kernel-dev* kernel-devel-2.6.33.6-147.fc13.i686 [root@plfalfl10 Downloads]# uname -a Linux plfalfl10.komp.co.uk 2.6.33.6-147.fc13.i686 #1 SMP Tue Jul 6 22:30:55 UTC 2010 i686 i686 i386 GNU/Linux [root@plfalfl10 Downloads]# SOS Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
thof Napisano Lipiec 24, 2010 Zgłoszenie Share Napisano Lipiec 24, 2010 kernel-headers Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
