[Fedora 14] Jak Zainstalować Sterowniki Ati
DAREK WL.
Sprawdzaj ten temat http://forums.fedoraforum.org/showthread.php?t=155503, to najpewniejsze źródło informacji na temat instalacji ATI na Fedorce.
ps. Trzeba było kupić kartę nVidii.
Es.
Przed chwila chcialem zainstalowac stery ati w wersji pobranej ze strony ati . Niestety wywalilo mi takim bledem ;
[root@localhost ~]# sh /home/darek/ati-driver-installer-10-7-x86.x86_64.run
Created directory fglrx-install.elm3dz
Verifying archive integrity... All good.
Uncompressing ATI Catalyst(TM) Proprietary Linux Driver-8.753........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
ATI Technologies Linux Driver Installer/Packager
which: no XFree86 in (/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
Error: ./default_policy.sh does not support version
default:v2:x86_64:lib::none:2.6.35.6-48.fc14.x86_64:; make sure that the version is being
correctly set by --iscurrentdistro
Removing temporary directory: fglrx-install.elm3dz
[root@localhost ~]#
Czy temu mozna jakos zaradzic ?
Sciagnalem najnowsza wersje sterownika ze strony domowej AMD
Jego instalacja przebiegla sprawnie ; nie wywalil bledu
Ale po restarcie kompa X-y juz sie nie uruchomily tylko wywalilo bledami ktore sa opisane w logu Xorg.0.log
Chcialem tego loga zacytowac tutaj ale fedora uruchomiona live nie widzi tego co jest na dysku zapewne dlatego ze na dysku nie ma zwyklych partycji tylko woluminy logiczne. Te ktore domyslnie tworzy sam instalator anaconda .
To po co twórcy najnowszej Fedorki wsadzili do niej takie X-y do których
nie ma wsparcia ze strony Ati . Moze lepiej by bylo aby Fedora 14 byla mniej nowatorska w swoich rozwiazaniach , ale za to mniej klopotliwsa .
Na najnowszym ubuntu 10.10 stery ati instaluje sie klikajac na ta ikonke
"hardware drivers " . Czy do repo F14 nie mogliby dodac modulu "kmod-fglrx" :unsure:
Uploaded with ImageShack.us
  • Downvote 5
To uzywaj Ubuntu. Fedora ma taka urode nie inna, jak nie potrafisz (nie chcesz) pracowac na otwartych sterownikach póki do panów z ATI dotrze, ze jest nowy X.org to dla swojego zdrowia i innych przejdz na inna mniej nowoczesna dystrybucje.
"Czy do repo F14 nie mogliby dodac modulu "kmod-fglrx""
Nie nie mogliby, poczytaj o polityce Fedory dotyczacej oprogramowania to bedziesz wiedzial dlaczego.
Es.
  • Upvote 3
Gość
