marcincompl Napisano Grudzień 29, 2010 Zgłoszenie Share Napisano Grudzień 29, 2010 Witam Czy ktoś może korzysta z http://freedns.afraid.org bo wyświetla mi się taki komunikat: "Broken 12/12/2010 16.5 days" i nie wiem co z tym zrobić, czy to jest jakieś spawdzanie czy to jest moja domena. Nie bardzo kumam ten temat.... w FAQ jest takie wytłumaczenie tego: I've broken this question up into 2 parts. For new domains: If you have a domain and you see this message within afraid.org, this simply means your domain was found to not be correctly delegated to ns1 through ns4.afraid.org on the Internet. If you don't know what this last paragraph means, relax, I'll explain. Domains themselves all must be "registered" in order to work on the Internet to a central registration authority in charge of all domains on the Internet before afraid.org (or anyone) can make them work. Still with me? If not, re-read that last bit until it makes sense, its very important you understand this concept. The central authority for all domains on the Internet is ICANN. In the interest of "free trade", you can get a domain through many companies who are known as "ICANN accredited registrars". Any ICANN accredited registrar will do. For domains that used to work: The common cause of this, is if the place of registering your domain has removed delegation to afraid.org for your domain, maybe your domain has expired, or you have changed your authoritive nameservers to not use ns1-ns4.afraid.org at your domain registrar yourself. This check is automatically ran once a night to ensure the domains in afraid.org are working correctly to keep the shared lists clean. To check dns authority instantly, you can use the DNS Auth trace box in the right hand side on every page of FreeDNS. This works for any domain or subdomain, even if it is not hosted here. This will show you your live configuratio of your domain on the Internet starting from the Root DNS servers, and if it is correct, the broken check will catch it and remove the broken flag. Broken is only a internal FreeDNS flag, if a domain remains in a broken state for 30 days, it is auto-removed. Broken checking occurs once every 24 hours, or when you press the "Check for Broken Domains Now" button within the "domains" section. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Mikołaj Napisano Marzec 23, 2011 Zgłoszenie Share Napisano Marzec 23, 2011 ano ostatnio korzystam. gdzie Ci sie ten komunikat pokazuje? Jaka masz domene, wykupiona gdzie indziej, czy zalozona darmowa w tym serwisie? ---- edit: hmmm, teraz patrze, ze mala archeologie popelnilem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcincompl Napisano Październik 18, 2011 Autor Zgłoszenie Share Napisano Październik 18, 2011 Wykupioną w home.pl Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Październik 18, 2011 Zgłoszenie Share Napisano Październik 18, 2011 W tym tempie to juz kolo 2050 rozwiazecie problem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Mikołaj Napisano Październik 18, 2011 Zgłoszenie Share Napisano Październik 18, 2011 to jest niewykluczone ;p już zapomniałem o tym temacie ... w jaki sposób dodałeś tę domenę do freedns i czy wydelegowałeś ją na ich serwery DNS? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
