Kaffeine I Dvd
Darknek
to wywala konsola
kaffeine
QMetaObject::invokeMethod: No such method KUniqueApplication::loadCommandLineOptionsForNewInstance()
[james@Ferenczy ~]$ params.c:OpenConfFile() - Unable to open configuration file "/home/james/.smb/smb.conf":
Nie ma takiego pliku ani katalogu
params.c:OpenConfFile() - Unable to open configuration file "/home/james/.smb/smb.conf.append":
libdvdnav: Using dvdnav version 1.1.19 from http://xine.sf.net
libdvdread: Using libdvdcss version 1.2.10 for DVD access
libdvdnav: DVD Title: LG_RC590M
libdvdnav: DVD Serial Number: AB6D64B4IILZ3ZAZ
libdvdnav: DVD Title (Alternative):
libdvdnav: Unable to find map file '/home/james/.dvdnav/LG_RC590M.map'
libdvdnav: DVD disk reports itself with Region mask 0x00c00000. Regions: 1 2 3 4 5 6
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x00000350
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00000ca0
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00057400
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x000ce410
libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x000d3cf0
libdvdread: Found 4 VTS's
demux_wavpack: (open_wv_file:127) open_wv_file: non-seekable inputs aren't supported yet.
libdvdnav: Language 'en' not found, using 'ja' instead
libdvdnav: Menu Languages available: ja
*** libdvdread: CHECK_VALUE failed in nav_read.c:356 ***
*** for dsi->dsi_gi.zero1 == 0 ***
*** libdvdread: CHECK_VALUE failed in ../input/libdvdnav/nav_read.c:356 ***
received X error event: BadMatch (invalid parameter attributes)
X Error: BadMatch (invalid parameter attributes) 8
 Extension:    132 (Uknown extension)
 Minor opcode: 17 (Unknown request)
 Resource id:  0x3f
KCrash: Application 'kaffeine-xbu' crashing...
KCrash: Attempting to start /usr/libexec/kde4/drkonqi from kdeinit
sock_file=/home/james/.kde/socket-Ferenczy/kdeinit4__0
a to obsluga krytyczna bledow kde
Application: Kaffeine (kaffeine-xbu), signal: Segmentation fault
[Current thread is 1 (Thread 0xb774a9b0 (LWP 3343))]
Thread 10 (Thread 0xb7516b70 (LWP 3344)):
#0  0x006cb416 in __kernel_vsyscall ()
#1  0x00798c36 in poll () from /lib/libc.so.6
#2  0x00b22dac in g_poll () from /lib/libglib-2.0.so.0
#3  0x00b128b7 in ?? () from /lib/libglib-2.0.so.0
#4  0x00b1304b in g_main_loop_run () from /lib/libglib-2.0.so.0
#5  0x068f9ed5 in ?? () from /lib/libgio-2.0.so.0
#6  0x00b3bbd0 in ?? () from /lib/libglib-2.0.so.0
#7  0x0024ce99 in start_thread () from /lib/libpthread.so.0
#8  0x007a3d2e in clone () from /lib/libc.so.6
Thread 9 (Thread 0xb4283b70 (LWP 3347)):
#1  0x00251743 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib/libpthread.so.0
#2  0x07ed2e1d in ?? () from /usr/lib/libxine.so.1
#3  0x0024ce99 in start_thread () from /lib/libpthread.so.0
#4  0x007a3d2e in clone () from /lib/libc.so.6
Thread 8 (Thread 0xb3a82b70 (LWP 3348)):
#2  0x0368e063 in ?? () from /usr/lib/libpulse.so.0
#3  0x0367ce7a in pa_mainloop_poll () from /usr/lib/libpulse.so.0
#4  0x0367d655 in pa_mainloop_iterate () from /usr/lib/libpulse.so.0
#5  0x0367d734 in pa_mainloop_run () from /usr/lib/libpulse.so.0
#6  0x0368e004 in ?? () from /usr/lib/libpulse.so.0
#7  0x036e3973 in ?? () from /usr/lib/libpulsecommon-0.9.21.so
#8  0x0024ce99 in start_thread () from /lib/libpthread.so.0
#9  0x007a3d2e in clone () from /lib/libc.so.6
Thread 7 (Thread 0xaf0ffb70 (LWP 3349)):
#1  0x0025139b in pthread_cond_wait@@GLIBC_2.3.2 () from /lib/libpthread.so.0
#2  0x07ee61d8 in ?? () from /usr/lib/libxine.so.1
Thread 6 (Thread 0xae4f3b70 (LWP 3350)):
#1  0x0079b8c1 in select () from /lib/libc.so.6
#2  0x07efdf69 in xine_usec_sleep () from /usr/lib/libxine.so.1
#3  0x07ee18c7 in ?? () from /usr/lib/libxine.so.1
#4  0x0024ce99 in start_thread () from /lib/libpthread.so.0
#5  0x007a3d2e in clone () from /lib/libc.so.6
Thread 5 (Thread 0xad909b70 (LWP 3351)):
[KCrash Handler]
#7  0x06f802a0 in ?? () from /usr/lib/xine/plugins/1.29/xineplug_vo_out_xv.so
#8  0x07ee014b in ?? () from /usr/lib/libxine.so.1
#9  0x0819c5b8 in ?? () from /usr/lib/xine/plugins/1.29/post/xineplug_post_tvtime.so
#10 0x03e09e6b in ?? () from /usr/lib/xine/plugins/1.29/xineplug_decode_mpeg2.so
#11 0x03e201f2 in ?? () from /usr/lib/xine/plugins/1.29/xineplug_decode_mpeg2.so
#12 0x07edda2b in ?? () from /usr/lib/libxine.so.1
#13 0x0024ce99 in start_thread () from /lib/libpthread.so.0
#14 0x007a3d2e in clone () from /lib/libc.so.6
Thread 4 (Thread 0xacf3bb70 (LWP 3352)):
#2  0x07ed7094 in ?? () from /usr/lib/libxine.so.1
#3  0x07ede969 in ?? () from /usr/lib/libxine.so.1
Thread 3 (Thread 0xac73ab70 (LWP 3353)):
#2  0x07ee8e70 in ?? () from /usr/lib/libxine.so.1
Thread 2 (Thread 0xab8bdb70 (LWP 3354)):
#3  0x01c5f7b5 in ?? () from /usr/lib/xine/plugins/1.29/xineplug_inp_dvd.so
#4  0x07ef64ed in ?? () from /usr/lib/libxine.so.1
#5  0x022fb5c5 in ?? () from /usr/lib/xine/plugins/1.29/xineplug_dmx_mpeg_block.so
#6  0x022fc8a2 in ?? () from /usr/lib/xine/plugins/1.29/xineplug_dmx_mpeg_block.so
#7  0x07eecdcd in ?? () from /usr/lib/libxine.so.1
Thread 1 (Thread 0xb774a9b0 (LWP 3343)):
#2  0x001381e5 in ?? () from /usr/lib/libX11.so.6
#3  0x00137ba1 in ?? () from /usr/lib/libX11.so.6
#4  0x00138330 in ?? () from /usr/lib/libX11.so.6
#5  0x0013bc8d in XEventsQueued () from /usr/lib/libX11.so.6
#6  0x01105ed6 in ?? () from /usr/lib/libQtGui.so.4
#7  0x00b11e07 in g_main_context_check () from /lib/libglib-2.0.so.0
#8  0x00b12742 in ?? () from /lib/libglib-2.0.so.0
#9  0x00b12c35 in g_main_context_iteration () from /lib/libglib-2.0.so.0
#10 0x0040ee0d in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#11 0x011060e6 in ?? () from /usr/lib/libQtGui.so.4
#12 0x003e02aa in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#13 0x003e055a in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#14 0x003e5107 in QCoreApplication::exec() () from /usr/lib/libQtCore.so.4
#15 0x01050d58 in QApplication::exec() () from /usr/lib/libQtGui.so.4
#16 0x0804dae5 in _start ()
PS
Na drugim lapku gdzie nie robilem update systemu jest jeszcze wczesniejsze kde i tam wszystko smiga piknie. Uzywam gnome.
Jest mozliwosc downgradu kde? Czy trzeba czekac az nowe wyjdzie i poprawia?
PS nowy
i jeszcze czasem wywala mi ze takiej wtyczki mu brakuje, ale dociagnac jej nie potrafi
"element gstreamera deinterlace'
