[F15] Virtualbox 4 Problem Z Uruchomieniem
k0nficjusz
Witam,
Nie bardzo wiem jak dokladnie opisac sytuacje, ale moze mi sie uda:)
Gdy chce zainstalowac nowa maszyne na virtualboxie pokazuje mi sie taki komunikat
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver (vboxdrv) is either not loaded or there is a permission problem with /dev/vboxdrv. Please reinstall the kernel module by executing
'/etc/init.d/vboxdrv setup'
as root. Users of Ubuntu, Fedora or Mandriva should install the DKMS package first. This package keeps track of Linux kernel changes and recompiles the vboxdrv kernel module if necessary.
Oczywiscie wedlug komunikatu uruchomilem polecenie etc/init.d/vboxdrv setup niestety pokazal mi sie kolejny komunikat
Stopping VirtualBox kernel modules                         [  OK  ]
Uninstalling old VirtualBox DKMS kernel modules            [  OK  ]
Trying to register the VirtualBox kernel modules using DKMSError! echo
Your kernel headers for kernel 2.6.38.6-26.rc1.fc15.i686 cannot be found at
/lib/modules/2.6.38.6-26.rc1.fc15.i686/build or /lib/modules/2.6.38.6-26.rc1.fc15.i686/source.
                                                          [FAILED]
 (Failed, trying without DKMS)
Recompiling VirtualBox kernel modules                      [FAILED]
 (Look at /var/log/vbox-install.log to find out what went wrong)
A log pokazuje cos takiego:
Uninstalling modules from DKMS
 removing old DKMS module vboxhost version  4.0.8
Deleting module version: 4.0.8
completely from the DKMS tree.
Done.
Attempting to install using DKMS
Creating symlink /var/lib/dkms/vboxhost/4.0.8/source ->
                /usr/src/vboxhost-4.0.8
DKMS: add Completed.
Failed to install using DKMS, attempting to install without
Makefile:169: *** Error: unable to find the sources of your current Linux kernel. Specify KERN_DIR=<directory> and run Make again.  Stop.
Co o tym sadzicie?
Posluchalem komunikatu Failed, trying without DKMS nie wiem czy slusznie ale po odinstalowaniu paczki zadzialalo i wlasnie stawia sie win7.
Niestety nie lubie komunikatów FAILED i martwi mnie jeszcze:
Trying to register the VirtualBox kernel modules using DKMS[FAILED]
Recompiling VirtualBox kernel modules                      [  OK  ]
Starting VirtualBox kernel modules                         [  OK  ]
Przeszukalem, przeczytalem poradnik o instalacji, a ze nie znalazlem rozwiazania to pytam.
Na pewno nie brakuje kernel-devel i kernel-headers
dla sprostowania:
Setting up Install Process
Package kernel-devel-2.6.38.6-27.fc15.i686 already installed and latest version
Package kernel-headers-2.6.38.6-27.fc15.i686 already installed and latest version
Nothing to do
To teraz zainstaluj jeszcze raz i zbuduje modul bez bledów.
Pomoglo dziekuje. Wszystko smiga jak powinno:)
Takie male potwierdzenie
Removing old VirtualBox netadp kernel module               [  OK  ]
Removing old VirtualBox netflt kernel module               [  OK  ]
Removing old VirtualBox kernel module                      [  OK  ]
Trying to register the VirtualBox kernel modules using DKMS[  OK  ]
