katoj Napisano Listopad 21, 2011 Zgłoszenie Share Napisano Listopad 21, 2011 problem wyglada tak: po wlaczeniu kompa pojawia sie stary ekran logowania (wyglada jak z gnome 2), po zalogowaniu wczytuje sie moja tapeta, i na tym koniec, zadnego paska ani nic nie widac. zainstalowane mam rozszerzenia powloki gnome'a i wlasny theme [wczoraj ladnie chodzilo, i rano tez] nic szczegolnego nie robilem, przegladalem sobie youtube'a na operze i przestal flash chodzic (bywa, nie? ), no to restart opery - nic. no to restart systemu - i jest jak jest. zawartosc .xsession-errors: GNOME_KEYRING_CONTROL=/tmp/keyring-QFNubX GPG_AGENT_INFO=/tmp/keyring-QFNubX/gpg:0:1 GNOME_KEYRING_CONTROL=/tmp/keyring-QFNubX GPG_AGENT_INFO=/tmp/keyring-QFNubX/gpg:0:1 GNOME_KEYRING_CONTROL=/tmp/keyring-QFNubX GPG_AGENT_INFO=/tmp/keyring-QFNubX/gpg:0:1 SSH_AUTH_SOCK=/tmp/keyring-QFNubX/ssh GNOME_KEYRING_CONTROL=/tmp/keyring-QFNubX GPG_AGENT_INFO=/tmp/keyring-QFNubX/gpg:0:1 SSH_AUTH_SOCK=/tmp/keyring-QFNubX/ssh (gnome-settings-daemon:1210): color-plugin-WARNING **: failed to get contents of /sys/class/dmi/id/chassis_vendor: Otwarcie pliku "/sys/class/dmi/id/chassis_vendor" siÄ™ nie powiodĹ‚o: Nie ma takiego pliku ani katalogu gnome-session[1053]: Gtk-WARNING: Theme parsing error: gtk-widgets.css:58:14: Themeing engine 'unico' not found (gnome-settings-daemon:1210): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:58:14: Themeing engine 'unico' not found gnome-session[1053]: WARNING: Application 'gnome-shell.desktop' killed by signal (gnome-settings-daemon:1210): color-plugin-WARNING **: failed to get edid: unable to get EDID for output (gdu-notification-daemon:1369): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:58:14: Themeing engine 'unico' not found (nm-applet:1374): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:58:14: Themeing engine 'unico' not found Initializing tracker-store... Tracker-Message: Setting up monitor for changes to config file:'/home/katoj/.config/tracker/tracker-store.cfg' (canberra-gtk-play:1386): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:58:14: Themeing engine 'unico' not found Failed to play sound: File or data not found Initializing tracker-miner-fs... Tracker-Message: Setting up monitor for changes to config file:'/home/katoj/.config/tracker/tracker-miner-fs.cfg' (gnome-screensaver:1390): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:58:14: Themeing engine 'unico' not found Tracker-Message: Setting up monitor for changes to config file:'/home/katoj/.config/tracker/tracker-store.cfg' Starting log: File:'/home/katoj/.local/share/tracker/tracker-miner-fs.log' Starting log: File:'/home/katoj/.local/share/tracker/tracker-store.log' ** Message: applet now removed from the notification area (nm-applet:1374): libnotify-WARNING **: Failed to connect to proxy zakladam ze to powinno byc puste moze ktos wie w czym tkwi problem i jak go rozwiazac. z gory dzieki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
katoj Napisano Listopad 22, 2011 Autor Zgłoszenie Share Napisano Listopad 22, 2011 dodam ze po usunieciu gnome'a i zainstalowaniu kde tez nie dziala, kde wyrzuca blad ze kde-deamon sie zakonczyl niespodziewanie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Listopad 22, 2011 Zgłoszenie Share Napisano Listopad 22, 2011 Kde wyrzucało taki błąd przy zainstalowanych sterownikach nvidii, ale teraz powinno być w porządku. Zaktualizowałbym też system, szczególnie glibc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
katoj Napisano Listopad 23, 2011 Autor Zgłoszenie Share Napisano Listopad 23, 2011 postawilem od nowa system z kde, niby chodzi, ale co chwile wyrzuca bledy o zamknietych procesach, np w polowe ustawien nie moge wejsc. nie wiem co jest nie tak - swiezy system i sypie bledami jak opetany. [edit] po zainstalowaniu nowego jajka wszystko jest ok [/edit] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
