Fedora 16 - Błąd Podczas Otwierania Plików .Mkv
Fardorn
Witam,
Gdy próbuje otworzyc plik .mkv, to albo mam zielony ekran (vlc), albo wyskakuje mi komunikat z bledem (smplayer):
/usr/bin/mplayer -noquiet -nofs -nomouseinput -sub-fuzziness 1 -identify -slave -vo xv -ao pulse -nokeepaspect -framedrop -nodr -double -input nodefault-bindings:conf=/dev/null -stop-xscreensaver -wid 31457315 -monitorpixelaspect 1 -ass -embeddedfonts -ass-line-spacing 0 -ass-font-scale 1 -ass-styles /home/fardorn/.config/smplayer/styles.ass -fontconfig -font Arial -subfont-autoscale 0 -subfont-osd-scale 20 -subfont-text-scale 20 -subcp UTF-8 -subpos 100 -volume 50 -nocache -osdlevel 0 -vf-add screenshot -slices -channels 2 -af scaletempo,equalizer=0:0:0:0:0:0:0:0:0:0 -softvol -softvol-max 110 /home/fardorn/Pobrane/**************
MPlayer SVN-r33996-4.6.1 (C) 2000-2011 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /home/fardorn/Pobrane/****************.
libavformat file format detected.
[matroska,webm @ 0x438e9fa0]max_analyze_duration 5000000 reached at 5019000
[matroska,webm @ 0x438e9fa0]Estimating duration from bitrate, this may be inaccurate
ID_CHAPTER_ID=0
ID_CHAPTER_0_START=33
ID_CHAPTER_0_END=64982
ID_CHAPTER_0_NAME=Intro
ID_CHAPTER_ID=1
ID_CHAPTER_1_START=64982
ID_CHAPTER_1_END=155922
ID_CHAPTER_1_NAME=OP
ID_CHAPTER_ID=2
ID_CHAPTER_2_START=155922
ID_CHAPTER_2_END=602902
ID_CHAPTER_2_NAME=Part A
ID_CHAPTER_ID=3
ID_CHAPTER_3_START=602902
ID_CHAPTER_3_END=1278902
ID_CHAPTER_3_NAME=Part B
ID_CHAPTER_ID=4
ID_CHAPTER_4_START=1278902
ID_CHAPTER_4_END=1369902
ID_CHAPTER_4_NAME=ED
ID_CHAPTER_ID=5
ID_CHAPTER_5_START=1369902
ID_CHAPTER_5_END=1374832
ID_CHAPTER_5_NAME=Preview
ID_SUBTITLE_ID=0
[lavf] stream 0: subtitle (ass), -sid 0
ID_VIDEO_ID=0
[lavf] stream 1: video (h264), -vid 0
ID_AUDIO_ID=0
ID_AID_0_LANG=jpn
ID_AID_0_NAME=Commie
[lavf] stream 2: audio (aac), -aid 0, -alang jpn, Commie
VIDEO:  [H264]  1280x720  0bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
Load subtitles in /home/fardorn/Pobrane/
[ass] Added subtitle file: <memory> (19 styles, 452 events)
MPlayer interrupted by signal 11 in module: read_subtitles_file
ID_SIGNAL=11
- MPlayer crashed by bad usage of CPU/FPU/RAM.
 Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
 disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
 It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
 gcc version. If you think it's MPlayer's fault, please read
 DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
 won't help unless you provide this information when reporting a possible bug.
Zastosowalem sie do http://wiki.fedora.pl/wiki/Poradnik, jesli chodzi o instalacje kodeków i przeszla ona pomyslnie. Dodatkowe kodeki (z pkt. Instalacja kodeków potrzebnych do odtwarzania np. filmów rmvb) równiez zainstalowalem.
