Blad Przy Uruchamianiu Apache
adampzb
# ls -la /etc/httpd
razem 24
drwxr-xr-x.   4 root root  4096 02-05 20:22 .
drwxr-xr-x. 158 root root 12288 02-09 22:05 ..
drwxr-xr-x.   2 root root  4096 02-05 20:22 conf
drwxr-xr-x.   2 root root  4096 02-09 17:45 conf.d
lrwxrwxrwx.   1 root root    19 02-05 20:22 logs -> ../../var/log/httpd
lrwxrwxrwx.   1 root root    27 02-05 20:22 modules -> ../../usr/lib/httpd/modules
lrwxrwxrwx.   1 root root    19 02-05 20:22 run -> ../../var/run/httpd
# touch /var/log/httpd/error_log
[root@localhost adam]# systemctl start httpd.service
Job failed. See system logs and 'systemctl status' for details.
# ls -laZ /etc/httpd/logs/
drwx------. root root system_u:object_r:httpd_log_t:s0 .
drwxr-xr-x. root root system_u:object_r:var_log_t:s0   ..
-rw-r--r--. root root unconfined_u:object_r:httpd_log_t:s0 error_log
# cat /lib/systemd/system/httpd.service
[unit]
Description=The Apache HTTP Server (prefork MPM)
After=syslog.target network.target
[service]
Type=forking
PIDFile=/var/run/httpd/httpd.pid
EnvironmentFile=/etc/sysconfig/httpd
ExecStart=/usr/sbin/httpd $OPTIONS -k start
ExecReload=/usr/sbin/httpd $OPTIONS -t
ExecReload=/bin/kill -HUP $MAINPID
ExecStop=/usr/sbin/httpd $OPTIONS -k stop
[install]
WantedBy=multi-user.target[/code]
[code]# cat /etc/sysconfig/httpd
# Configuration file for the httpd service.
# The default processing model (MPM) is the process-based
# 'prefork' model.  A thread-based model, 'worker', is also
# available, but does not work with some modules (such as PHP).
# The service must be stopped before changing this variable.
#HTTPD=/usr/sbin/httpd.worker
# To pass additional options (for instance, -D definitions) to the
# httpd binary at startup, set OPTIONS here.
#OPTIONS=
# By default, the httpd process is started in the C locale; to
# change the locale in which the server runs, the HTTPD_LANG
# variable can be set.
#HTTPD_LANG=C
# When stopping the server a 10 second timeout is allowed before
# forcibly terminating the parent process (with a SIGKILL signal).
# To allow a longer delay, set the STOP_TIMEOUT variable.
#STOP_TIMEOUT=10
# By default, the httpd process will create the file
# /var/run/httpd/httpd.pid in which it records its process
# identification number when it starts.  If an alternate location is
# specified in httpd.conf (via the PidFile directive), the new
# location needs to be reported in the PIDFILE.
#PIDFILE=/var/run/httpd/httpd.pid[/code]
[code]d/httpd.pid
[root@localhost adam]# grep -v -E '(^#|^$)' /etc/httpd/conf/httpd.conf
ServerTokens OS
ServerRoot "/etc/httpd"
PidFile run/httpd.pid
Timeout 60
KeepAlive Off
MaxKeepAliveRequests 100
KeepAliveTimeout 5
<IfModule prefork.c>
StartServers       8
MinSpareServers    5
MaxSpareServers   20
ServerLimit      256
MaxClients       256
MaxRequestsPerChild  4000
</IfModule>
<IfModule worker.c>
StartServers         4
MaxClients         300
MinSpareThreads     25
MaxSpareThreads     75
ThreadsPerChild     25
MaxRequestsPerChild  0
</IfModule>
Listen 80
LoadModule auth_basic_module modules/mod_auth_basic.so
LoadModule auth_digest_module modules/mod_auth_digest.so
LoadModule authn_file_module modules/mod_authn_file.so
LoadModule authn_alias_module modules/mod_authn_alias.so
LoadModule authn_anon_module modules/mod_authn_anon.so
LoadModule authn_dbm_module modules/mod_authn_dbm.so
LoadModule authn_default_module modules/mod_authn_default.so
LoadModule authz_host_module modules/mod_authz_host.so
LoadModule authz_user_module modules/mod_authz_user.so
LoadModule authz_owner_module modules/mod_authz_owner.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_dbm_module modules/mod_authz_dbm.so
LoadModule authz_default_module modules/mod_authz_default.so
LoadModule authn_dbd_module modules/mod_authn_dbd.so
LoadModule dbd_module modules/mod_dbd.so
LoadModule ldap_module modules/mod_ldap.so
LoadModule authnz_ldap_module modules/mod_authnz_ldap.so
LoadModule include_module modules/mod_include.so
LoadModule log_config_module modules/mod_log_config.so
LoadModule logio_module modules/mod_logio.so
LoadModule env_module modules/mod_env.so
LoadModule ext_filter_module modules/mod_ext_filter.so
LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule expires_module modules/mod_expires.so
LoadModule deflate_module modules/mod_deflate.so
LoadModule headers_module modules/mod_headers.so
LoadModule usertrack_module modules/mod_usertrack.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule mime_module modules/mod_mime.so
LoadModule dav_module modules/mod_dav.so
LoadModule status_module modules/mod_status.so
LoadModule autoindex_module modules/mod_autoindex.so
LoadModule info_module modules/mod_info.so
LoadModule dav_fs_module modules/mod_dav_fs.so
LoadModule vhost_alias_module modules/mod_vhost_alias.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule dir_module modules/mod_dir.so
LoadModule actions_module modules/mod_actions.so
LoadModule speling_module modules/mod_speling.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule alias_module modules/mod_alias.so
LoadModule substitute_module modules/mod_substitute.so
LoadModule rewrite_module modules/mod_rewrite.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
LoadModule proxy_connect_module modules/mod_proxy_connect.so
LoadModule cache_module modules/mod_cache.so
LoadModule suexec_module modules/mod_suexec.so
LoadModule disk_cache_module modules/mod_disk_cache.so
LoadModule cgi_module modules/mod_cgi.so
LoadModule version_module modules/mod_version.so
Include conf.d/*.conf
User apache
Group apache
ServerAdmin root@localhost
UseCanonicalName Off
DocumentRoot "/var/www/html"
<Directory />
   Options FollowSymLinks
   AllowOverride None
</Directory>
<Directory "/var/www/html">
   # Possible values for the Options directive are "None", "All",
   # or any combination of:
   #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
   # Note that "MultiViews" must be named *explicitly* --- "Options All"
   # doesn't give it to you.
   # The Options directive is both complicated and important.  Please see
   # http://httpd.apache.org/docs/2.2/mod/core.html#options
   # for more information.
   Options Indexes FollowSymLinks
   # AllowOverride controls what directives may be placed in .htaccess files.
   # It can be "All", "None", or any combination of the keywords:
   #   Options FileInfo AuthConfig Limit
   AllowOverride None
   # Controls who can get stuff from this server.
   Order allow,deny
   Allow from all
</Directory>
<IfModule mod_userdir.c>
   # UserDir is disabled by default since it can confirm the presence
   # of a username on the system (depending on home directory
   # permissions).
   UserDir disabled
   # To enable requests to /~user/ to serve the user's public_html
   # directory, remove the "UserDir disabled" line above, and uncomment
   # the following line instead:
   #UserDir public_html
</IfModule>
DirectoryIndex index.html index.html.var
AccessFileName .htaccess
<FilesMatch "^\.ht">
   Order allow,deny
   Deny from all
   Satisfy All
</FilesMatch>
TypesConfig /etc/mime.types
DefaultType text/plain
<IfModule mod_mime_magic.c>
   MIMEMagicFile conf/magic
</IfModule>
HostnameLookups Off
ErrorLog logs/error_log
LogLevel warn
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
CustomLog logs/access_log combined
ServerSignature On
Alias /icons/ "/var/www/icons/"
<Directory "/var/www/icons">
   Options Indexes MultiViews FollowSymLinks
   AllowOverride None
   Order allow,deny
   Allow from all
</Directory>
<IfModule mod_dav_fs.c>
   # Location of the WebDAV lock database.
   DAVLockDB /var/lib/dav/lockdb
</IfModule>
ScriptAlias /cgi-bin/ "/var/www/cgi-bin/"
<Directory "/var/www/cgi-bin">
   AllowOverride None
   Options None
   Order allow,deny
   Allow from all
</Directory>
IndexOptions FancyIndexing VersionSort NameWidth=* HTMLTable Charset=UTF-8
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif ..
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
DefaultIcon /icons/unknown.gif
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
AddLanguage ca .ca
AddLanguage cs .cz .cs
AddLanguage da .dk
AddLanguage de .de
AddLanguage el .el
AddLanguage en .en
AddLanguage eo .eo
AddLanguage es .es
AddLanguage et .et
AddLanguage fr .fr
AddLanguage he .he
AddLanguage hr .hr
AddLanguage it .it
AddLanguage ja .ja
AddLanguage ko .ko
AddLanguage ltz .ltz
AddLanguage nl .nl
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddLanguage pt .pt
AddLanguage pt-BR .pt-br
AddLanguage ru .ru
AddLanguage sv .sv
AddLanguage zh-CN .zh-cn
AddLanguage zh-TW .zh-tw
LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
ForceLanguagePriority Prefer Fallback
AddDefaultCharset UTF-8
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
AddType application/x-x509-ca-cert .crt
AddType application/x-pkcs7-crl    .crl
AddHandler type-map var
AddType text/html .shtml
AddOutputFilter INCLUDES .shtml
Alias /error/ "/var/www/error/"
<IfModule mod_negotiation.c>
<IfModule mod_include.c>
   <Directory "/var/www/error">
       AllowOverride None
       Options IncludesNoExec
       AddOutputFilter Includes html
       Order allow,deny
       Allow from all
       LanguagePriority en es de fr
   </Directory>
</IfModule>
</IfModule>
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
BrowserMatch "MS FrontPage" redirect-carefully
BrowserMatch "^WebDrive" redirect-carefully
BrowserMatch "^WebDAVFS/1.[0123]" redirect-carefully
BrowserMatch "^gnome-vfs/1.0" redirect-carefully
BrowserMatch "^XML Spy" redirect-carefully
BrowserMatch "^Dreamweaver-WebDAV-SCM1" redirect-carefully
# tail /var/log/messages
Feb  9 23:26:06 localhost dbus-daemon[1031]: dbus[1031]: [system] Successfully activated service 'net.reactivated.Fprint'
Feb  9 23:26:06 localhost dbus-daemon[1031]: ** Message: D-Bus service launched with name: net.reactivated.Fprint
Feb  9 23:26:06 localhost dbus-daemon[1031]: ** Message: entering main loop
Feb  9 23:26:36 localhost dbus-daemon[1031]: ** Message: No devices in use, exit
Feb  9 23:28:11 localhost kernel: [ 5146.002360] ath5k_hw_get_isr: ISR: 0x00000080 IMR: 0x00000000
Feb 10 00:00:47 localhost httpd[3260]: (98)Address already in use: make_sock: could not bind to address 127.0.0.1:80
Feb 10 00:00:47 localhost httpd[3260]: no listening sockets available, shutting down
Feb 10 00:00:47 localhost httpd[3260]: Unable to open logs
Feb 10 00:00:47 localhost systemd[1]: httpd.service: control process exited, code=exited status=1
Feb 10 00:00:47 localhost systemd[1]: Unit httpd.service entered failed state.
# tail /var/log/audit/audit.log
type=USER_END msg=audit(1328826497.298:111): user pid=0 uid=0 auid=1000 ses=1 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:session_close acct="root" exe="/bin/su" hostname=? addr=? terminal=pts/1 res=success'
type=CRED_DISP msg=audit(1328826497.298:112): user pid=0 uid=0 auid=1000 ses=1 subj=unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 msg='op=PAM:setcred acct="root" exe="/bin/su" hostname=? addr=? terminal=pts/1 res=success'
type=SERVICE_START msg=audit(1328828447.586:113): user pid=0 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg=': comm="httpd" exe="/bin/systemd" hostname=? addr=? terminal=? res=failed'
type=USER_ACCT msg=audit(1328828461.637:114): user pid=0 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:crond_t:s0-s0:c0.c1023 msg='op=PAM:accounting acct="root" exe="/usr/sbin/crond" hostname=? addr=? terminal=cron res=success'
type=CRED_ACQ msg=audit(1328828461.637:115): user pid=0 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:crond_t:s0-s0:c0.c1023 msg='op=PAM:setcred acct="root" exe="/usr/sbin/crond" hostname=? addr=? terminal=cron res=success'
type=LOGIN msg=audit(1328828461.639:116): login pid=3262 uid=0 old auid=4294967295 new auid=0 old ses=4294967295 new ses=3
type=USER_START msg=audit(1328828461.658:117): user pid=0 uid=0 auid=0 ses=3 subj=system_u:system_r:crond_t:s0-s0:c0.c1023 msg='op=PAM:session_open acct="root" exe="/usr/sbin/crond" hostname=? addr=? terminal=cron res=success'
type=CRED_REFR msg=audit(1328828461.659:118): user pid=0 uid=0 auid=0 ses=3 subj=system_u:system_r:crond_t:s0-s0:c0.c1023 msg='op=PAM:setcred acct="root" exe="/usr/sbin/crond" hostname=? addr=? terminal=cron res=success'
type=CRED_DISP msg=audit(1328828461.772:119): user pid=0 uid=0 auid=0 ses=3 subj=system_u:system_r:crond_t:s0-s0:c0.c1023 msg='op=PAM:setcred acct="root" exe="/usr/sbin/crond" hostname=? addr=? terminal=cron res=success'
type=USER_END msg=audit(1328828461.772:120): user pid=0 uid=0 auid=0 ses=3 subj=system_u:system_r:crond_t:s0-s0:c0.c1023 msg='op=PAM:session_close acct="root" exe="/usr/sbin/crond" hostname=? addr=? terminal=cron res=success'
maly update wszystko juz dziala jak nalezy usunalem sterowniki nvidi i kde juz sie nie krzaczy a apache juz smiga. nie zgadniecie czemu. w nakladce graficznej administracja>ustawienia servera>http mialem dodany adres 127.0.0.1 na porcie 80 :S sory za sprawianie problemow ale nie pamietam nawet zebym cos tam grzebal, z ciekawosci wszedlem w te ustawienia usunalem adres i httpd zaskoczyl. fedora znow dobrze funkcjonuje... dzieki wszystkim za zainsteresowanie i pomoc
