Proftpd Automatycznie Sie Wylacza
hhpl
Witam
skonfigurowalem proftpd niby usluga wstaje i dziala,
ale srednio raz dziennie sama sie wylacza, po "proftpd restart" wyskakuje, ze nie
moze wylaczyc (bo jest wylaczona) ale wlacza sie
juz normalnie i znowu przez jakis czas jest ok
mozecie jakos pomoc co to moze byc ?
tutaj conf
ServerType standalone
DefaultServer on
Umask 022
ServerName "0.0.0.0"
ServerIdent on "My FTP Server"
ServerAdmin [email protected]
IdentLookups off
UseReverseDNS off
Port 21
PassivePorts 49152 65534
#MasqueradeAddress None
TimesGMT off
MaxInstances 30
MaxLoginAttempts 3
TimeoutLogin 300
TimeoutNoTransfer 120
TimeoutIdle 120
DisplayLogin welcome.msg
DisplayChdir .message
User nobody
Group nobody
DirFakeUser off nobody
DirFakeGroup off nobody
DefaultTransferMode binary
AllowForeignAddress off
AllowRetrieveRestart on
AllowStoreRestart on
DeleteAbortedStores off
TransferRate RETR 220
TransferRate STOR 250
TransferRate STOU 250
TransferRate APPE 250
SystemLog /var/log/secure
RequireValidShell off
<IfModule mod_tls.c>
TLSEngine off
TLSRequired off
TLSVerifyClient off
TLSProtocol SSLv23
TLSLog /var/log/proftpd_tls.log
TLSRSACertificateFile /etc/gadmin-proftpd/certs/cert.pem
TLSRSACertificateKeyFile /etc/gadmin-proftpd/certs/key.pem
TLSCACertificateFile /etc/gadmin-proftpd/certs/cacert.pem
TLSRenegotiate required off
TLSOptions AllowClientRenegotiation
</IfModule>
<IfModule mod_ratio.c>
Ratios off
SaveRatios off
RatioFile "/restricted/proftpd_ratios"
RatioTempFile "/restricted/proftpd_ratios_temp"
CwdRatioMsg "Please upload first!"
FileRatioErrMsg "FileRatio limit exceeded, upload something first..."
ByteRatioErrMsg "ByteRatio limit exceeded, upload something first..."
LeechRatioMsg "Your ratio is unlimited."
</IfModule>
<Limit LOGIN>
 AllowUser brand
 DenyALL
</Limit>
<Anonymous /home/brand/WSPOLNY>
User brand
Group brand
AnonRequirePassword on
MaxClients 10 "The server is full, hosting %m users"
DisplayChdir .msg
<Limit LOGIN>
Allow from All
Deny from all
</Limit>
AllowOverwrite on
<Limit LIST NLST  STOR STOU  RETR  RNFR RNTO  DELE  MKD XMKD SITE_MKDIR  RMD XRMD SITE_RMDIR  SITE  MTDM  PWD XPWD  SIZE  STAT  CWD XCWD  CDUP XCUP >
AllowAll
</Limit>
<Limit APPE  SITE_CHMOD  SITE_CHGRP >
DenyAll
</Limit>
</Anonymous>
Wylacza sie zawsze o tej samej porze? A moze po takim samym czasie dzialania? Sprawdzales co sie dzieje w systemie w chwili wylaczenie proftpd?
Nie za bardzo sie znam na konfiguracji proftpd, ale wpis w czesci dla anonimowych wyglada tak jakby autor nie mógl sie zdecydowac ;)
<Limit LOGIN>
Allow from All
Deny from all
</Limit>
Raczej bez zwiazku z problemem, ale jakby bez sensu.
  • Upvote 1
nie wiem dokladnie kiedy sie wylacza bo tez w miejscu w ktorym wydaje mi sie powinny byc logi jest pusto /var/log/proftpd
czy trzeba wlaczyc jakos tworzenie logow czy gdzies indziej sa ?
-tamto faktycznie dziwnie wygladalo wiec juz zmienilem ale tak jak mowisz raczej bez zwiazku z tym wylaczaniem ;/
Ja bym przeszukal inne logi w /var/log ze szczególnym uwzglednieniem /var/log/messages. 'dmesg' tez moze cos ciekawego wyswietlic.
Mozesz spróbowac wylaczyc SElinux, chociaz jesli serwer sie uruchamia i dopiero potem pada, to raczej nie tu problem.
