Koen1 Napisano Październik 3, 2012 Zgłoszenie Share Napisano Październik 3, 2012 Witam mam dylemat ,w laptopie mam zanotowaną kartę graficzną Radeon HD 3650 która niezbyt optymalnie działa na podstawowych sterownikach zainstalowanych wraz z fedorą 17 64bit .Co ma zrobić czy instalować zasłonięte stery, Przede wszystkim chodzi mi o dobre zarządzie energią.Troszkę więcej informacji. glxgears 309 frames in 5.0 seconds = 61.760 FPS 307 frames in 5.0 seconds = 61.335 FPS 307 frames in 5.0 seconds = 61.363 FPS 307 frames in 5.0 seconds = 61.353 FPS 307 frames in 5.0 seconds = 61.351 FPS 307 frames in 5.0 seconds = 61.351 FPS 307 frames in 5.0 seconds = 61.353 FPS 307 frames in 5.0 seconds = 61.353 FPS 307 frames in 5.0 seconds = 61.347 FPS 307 frames in 5.0 seconds = 61.357 FPS 307 frames in 5.0 seconds = 61.350 FPS 307 frames in 5.0 seconds = 61.353 FPS 307 frames in 5.0 seconds = 61.353 FPS 307 frames in 5.0 seconds = 61.351 FPS 307 frames in 5.0 seconds = 61.353 FPS glxinfo name of display: :0 display: :0 screen: 0 direct rendering: Yes server glx vendor string: SGI server glx version string: 1.4 server glx extensions: GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGI_swap_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_INTEL_swap_event client glx vendor string: Mesa Project and SGI client glx version string: 1.4 client glx extensions: GLX_ARB_create_context, GLX_ARB_create_context_profile, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_framebuffer_sRGB, GLX_EXT_create_context_es2_profile, GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent, GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap, GLX_INTEL_swap_event GLX version: 1.4 GLX extensions: GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent, GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap OpenGL vendor string: X.Org OpenGL renderer string: Gallium 0.4 on AMD RV635 OpenGL version string: 2.1 Mesa 8.0.4 OpenGL shading language version string: 1.20 OpenGL extensions: GL_ARB_multisample, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_copy_texture, GL_EXT_polygon_offset, GL_EXT_subtexture, GL_EXT_texture_object, GL_EXT_vertex_array, GL_EXT_compiled_vertex_array, GL_EXT_texture, GL_EXT_texture3D, GL_IBM_rasterpos_clip, GL_ARB_point_parameters, GL_EXT_draw_range_elements, GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_separate_specular_color, GL_EXT_texture_edge_clamp, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_ARB_framebuffer_sRGB, GL_ARB_multitexture, GL_EXT_framebuffer_sRGB, GL_IBM_multimode_draw_arrays, GL_IBM_texture_mirrored_repeat, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_transpose_matrix, GL_EXT_blend_func_separate, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays, GL_EXT_secondary_color, GL_EXT_texture_env_add, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias, GL_INGR_blend_func_separate, GL_NV_blend_square, GL_NV_light_max_exponent, GL_NV_texgen_reflection, GL_NV_texture_env_combine4, GL_SUN_multi_draw_arrays, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_EXT_framebuffer_object, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_MESA_window_pos, GL_NV_packed_depth_stencil, GL_NV_texture_rectangle, GL_ARB_depth_texture, GL_ARB_occlusion_query, GL_ARB_shadow, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat, GL_ARB_window_pos, GL_EXT_stencil_two_side, GL_EXT_texture_cube_map, GL_NV_depth_clamp, GL_NV_fog_distance, GL_APPLE_packed_pixels, GL_APPLE_vertex_array_object, GL_ARB_draw_buffers, GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_shader_objects, GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ATI_draw_buffers, GL_ATI_texture_env_combine3, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_MESA_pack_invert, GL_NV_primitive_restart, GL_ARB_depth_clamp, GL_ARB_fragment_program_shadow, GL_ARB_half_float_pixel, GL_ARB_occlusion_query2, GL_ARB_point_sprite, GL_ARB_shading_language_100, GL_ARB_sync, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object, GL_ATI_blend_equation_separate, GL_EXT_blend_equation_separate, GL_OES_read_format, GL_ARB_color_buffer_float, GL_ARB_pixel_buffer_object, GL_ARB_texture_compression_rgtc, GL_ARB_texture_rectangle, GL_ATI_texture_compression_3dc, GL_EXT_packed_float, GL_EXT_pixel_buffer_object, GL_EXT_texture_compression_rgtc, GL_EXT_texture_mirror_clamp, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_shared_exponent, GL_ARB_framebuffer_object, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample, GL_EXT_packed_depth_stencil, GL_ARB_vertex_array_object, GL_ATI_separate_stencil, GL_ATI_texture_mirror_once, GL_EXT_draw_buffers2, GL_EXT_gpu_program_parameters, GL_EXT_texture_array, GL_EXT_texture_compression_latc, GL_EXT_texture_sRGB_decode, GL_EXT_timer_query, GL_OES_EGL_image, GL_MESA_texture_array, GL_ARB_copy_buffer, GL_ARB_depth_buffer_float, GL_ARB_half_float_vertex, GL_ARB_instanced_arrays, GL_ARB_map_buffer_range, GL_ARB_texture_rg, GL_ARB_texture_swizzle, GL_ARB_vertex_array_bgra, GL_EXT_separate_shader_objects, GL_EXT_texture_swizzle, GL_EXT_vertex_array_bgra, GL_NV_conditional_render, GL_AMD_draw_buffers_blend, GL_AMD_shader_stencil_export, GL_ARB_ES2_compatibility, GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex, GL_ARB_explicit_attrib_location, GL_ARB_fragment_coord_conventions, GL_ARB_provoking_vertex, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map, GL_ARB_shader_stencil_export, GL_ARB_shader_texture_lod, GL_ARB_texture_rgb10_a2ui, GL_ARB_vertex_type_2_10_10_10_rev, GL_EXT_provoking_vertex, GL_EXT_texture_snorm, GL_MESA_texture_signed_rgba, GL_NV_texture_barrier, GL_ARB_robustness, GL_ARB_texture_storage 96 GLX Visuals visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat ---------------------------------------------------------------------------- 0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x022 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x101 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x102 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x103 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x104 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x105 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x106 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x107 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x108 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x109 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x10a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x10b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x10c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x10d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x10e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x10f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x110 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x111 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x112 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x113 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x114 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x115 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x116 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x117 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x118 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x119 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x11a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x11b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x11c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x11d 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x11e 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x11f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x120 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x121 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x122 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x123 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x124 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x125 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x126 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x127 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x128 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x129 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x12a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x12b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x12c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x12d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x12e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x12f 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x130 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x131 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x132 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x133 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x134 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x135 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x136 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x137 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x138 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x139 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x13a 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x13b 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x13c 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x13d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x13e 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x13f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x140 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x141 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x142 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x143 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x144 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x145 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x146 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x147 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x148 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x149 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x14a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x14b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x14c 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x14d 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x14e 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x14f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x150 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x151 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x152 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x153 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x154 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x155 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x156 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x157 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x158 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x159 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x15a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x15b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x15c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x15d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x070 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None144 GLXFBConfigs: visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat ---------------------------------------------------------------------------- 0x071 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x072 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x073 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x074 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x075 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x076 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x077 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x078 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x079 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x07a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x07b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x07c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x07d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x07e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x07f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x080 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x081 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x082 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x083 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x084 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x085 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x086 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x087 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x088 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x089 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x08a 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x08b 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x08c 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x08d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x08e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x08f 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x090 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x091 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x092 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x093 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x094 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x095 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x096 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x097 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x098 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x099 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x09a 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x09b 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x09c 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x09d 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x09e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x09f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x0a0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0a1 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x0a2 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0a3 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x0a4 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0a5 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x0a6 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0a7 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x0a8 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0a9 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x0aa 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0ab 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x0ac 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0ad 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None 0x0ae 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0af 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None 0x0b0 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0b1 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None 0x0b2 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0b3 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None 0x0b4 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0b5 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None 0x0b6 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0b7 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None 0x0b8 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0b9 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x0ba 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x0bb 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x0bc 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x0bd 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None 0x0be 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow 0x0bf 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x0c0 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x0c1 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x0c2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x0c3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None 0x0c4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 16 16 16 16 0 0 Slow 0x0c5 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x0c6 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x0c7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x0c8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x0c9 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None 0x0ca 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 16 16 16 16 0 0 Slow 0x0cb 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x0cc 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x0cd 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x0ce 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x0cf 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None 0x0d0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow 0x0d1 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x0d2 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0d3 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x0d4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0d5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None 0x0d6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0d7 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x0d8 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0d9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x0da 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0db 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 None 0x0dc 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0dd 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x0de 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0df 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x0e0 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0e1 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 None 0x0e2 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0e3 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x0e4 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0e5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x0e6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0e7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None 0x0e8 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0e9 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x0ea 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0eb 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x0ec 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0ed 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None 0x0ee 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 16 16 16 0 0 0 Slow 0x0ef 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x0f0 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0f1 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x0f2 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0f3 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None 0x0f4 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow 0x0f5 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None 0x0f6 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0f7 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None 0x0f8 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0f9 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 None 0x0fa 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 16 16 16 0 0 0 Slow 0x0fb 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None 0x0fc 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0fd 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None 0x0fe 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow 0x0ff 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 None 0x100 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 16 16 16 0 0 0 Slow Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Koen1 Napisano Październik 4, 2012 Autor Zgłoszenie Share Napisano Październik 4, 2012 postanowilem spróbowac jak dziela na sterownikach z strony ati pobralem instalator sie uruchomil Created directory fglrx-install.VYN1kO Verifying archive integrity... All good. Uncompressing AMD Catalyst(TM) Proprietary Driver-8.97.100.3.................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................... ===================================================================== AMD Catalyst(TM) Proprietary Driver Installer/Packager ===================================================================== Detected configuration: Architecture: x86_64 (64-bit) X Server: X.Org 6.9 or later 64-bit loki_setup: directory: (null) Removing temporary directory: fglrx-install.VYN1kO i dale nic sie nie dzieje z pod powiedzi od ati Check if system has the tools required for installation. fglrx installation requires that the system have kernel headers. /lib/modules/3.5.4-2.fc17.x86_64/build/include/linux/version.h cannot be found on this system. fglrx installation requires that the system has gcc tool. gcc cannot be found on this system. One or more tools required for installation cannot be found on the system. Install the required tools before installing the fglrx driver. Optionally, run the installer with --force option to install without the tools. Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended. wywnioskowalem ze (_niema_ → nie ma) ORT takiego pliku /lib/modules/3.5.4-2.fc17.x86_64/build/include/linux/version.h co mam robic Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Październik 4, 2012 Zgłoszenie Share Napisano Październik 4, 2012 Do Twojej karty potrzebne sa sterowniki legacy http://support.amd.c...cyproducts.aspx. Nie wiem czy dzialaja one na F17. Do instalacji sterowników potrzebujesz: yum install gcc kernel-headers kernel-devel Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
morsik Napisano Październik 6, 2012 Zgłoszenie Share Napisano Październik 6, 2012 60FPS jest OK. VSync jest wlaczony, wiec 3d jest rysowane taka sama ilosc razy co odswiezanie Twojego ekranu (60Hz). A karta moze dawac rade znacznie wiecej. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Koen1 Napisano Październik 6, 2012 Autor Zgłoszenie Share Napisano Październik 6, 2012 Dzięki morsik; sokar620 za odpowiedz, i tak zainstalowałem gcc ale kernel-headers kernel-devel nie więc teraz instaluję, sterowniki ma te właśnie pobrane. Dlaczego zdecydowałem się na xfce sterowniki dlatego że ponoć lepiej zażydzają energia a na lapku by się przydało po za tym na otwartych sterach wiatrak chodzi na drugim biegu to daje jakieś 35 dcb co nie jest przyjemne więc o cisze też chodzi. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Koen1 Napisano Październik 6, 2012 Autor Zgłoszenie Share Napisano Październik 6, 2012 (edytowane) no i przedobrzyłem instalacja poszła pomyślnie ale po restarcie środowisko gnome 3 nie odpala ponieważ niejset nie jest kopatybilne kompatybilne z sterownika mi ze sterownikami grafiki , ale nic jest tryb zastępczy włancza , włączam kosole konsolę wpisuje wpisuję fglrxinfo | grep OpenGL r of failed request: BadRequest (invalid request code or no such operation) Major opcode of failed request: 139 (ATIFGLEXTENSION) Minor opcode of failed request: 66 () Serial number of failed request: 13 Current serial number in output stream: 13[/b] [b] a w menu mam AMD catalisti center uruchamiam wszystko okej widzi kartę działa ,czyli jak by fedora nie obsługiwała jeszcze tych sterowników Edytowane Październik 6, 2012 przez WalDo Ortografia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Październik 6, 2012 Zgłoszenie Share Napisano Październik 6, 2012 Sterowniki się zainstalowały, system się uruchomił, nie jest źle. Poza brakiem wsparcia dla Gnome Shell problem jest z 3d. Masz do przejrzenia temat rzekę - http://forums.fedora...d.php?t=155503. Może potrzeba wygenerować xorg.conf za pomocą aticonfig --initial ? Ja mam Nvidię i czasem zdarzają się takie problemy jak u Ciebie. Zakładam że sterowniki instalują plik /usr/lib64/xorg/modules/extensions/catalyst/libglx.so. Jeśli tak to możesz sprubować: cd /usr/lib64/xorg/modules/extensions/ mv libglx.so libglx.so.bak Wystarczy Alt+Ctrl+Backspace. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
