Sterowniki Sis Mirage M672
daro91
Witam,
http://www.socialphy...nder-Linux.html
Notes
ATTENTION: some source code versions are out of date (are approx. of 2005) and doesn't compile if you have the Xserver version 1.12.
The problem is with some definitions that currently aren't available, because they have been deleted from the headers of the development packages of Xserver, for deprecated.
I tested it under Fedora 17 Beefy Miracle and I don't find a solution.
nie napawa to optymizmem.
Dla starszych wersji dobrze jest nalozyc przed kompilacja sterownika "XvFix.patch" na zródla.
Przykladowa budowa paczki dla CentOS 6.3 - zródla i XvFix.patch
http://forum.centos....la-centos-sl-63
