Problem Ze Sterownikiem Amd Catalyst 12.6
demageron
Witam!
Po instalacji sterowników do karty graficznej gnome-shell nie uruchamia się a w rogu ekranu mam znak wodny "AMD Testing use only". Wie ktoś może jak to naprawić?
fglrx-install.log:
Check if system has the tools required for installation.
Uninstalling any previously installed drivers.
Unloading radeon module...
Error: Module radeon is in use
Unloading drm module...
Error: Module drm is in use by: ttm drm_kms_helper radeon
[Message] Kernel Module : Trying to install a precompiled kernel module.
[Message] Kernel Module : Precompiled kernel module version mismatched.
[Message] Kernel Module : Found kernel module build environment, generating kernel module now.
AMD kernel module generator version 2.1
doing Makefile based build for kernel 2.6.x and higher
rm -rf *.c *.h *.o *.ko *.a .??* *.symvers
make -C /lib/modules/3.6.6-1.fc17.x86_64/build SUBDIRS=/usr/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Wejście do katalogu `/usr/src/kernels/3.6.6-1.fc17.x86_64'
 CC [M]  /usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function ‘KCL_MEM_AllocLinearAddrInterval’:
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2152:5: error: implicit declaration of function ‘do_mmap’ [-Werror=implicit-function-declaration]
/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2152:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
cc1: some warnings being treated as errors
make[2]: *** [/usr/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o] Błąd 1
make[1]: *** [_module_/usr/lib/modules/fglrx/build_mod/2.6.x] Błąd 2
make[1]: Opuszczenie katalogu `/usr/src/kernels/3.6.6-1.fc17.x86_64'
make: *** [kmod_build] Błąd 2
build failed with return value 2
[Error] Kernel Module : Failed to compile kernel module - please consult readme.
[Reboot] Kernel Module : dracut
Posilalem sie tym poradnikiem: http://wiki.fedora.p...ki/Poradnik#AMD, a paczke sciagnalem ze strony: http://support.amd.c...cyproducts.aspx. Jak instalowalem ten z repo (wg. poradnika) to nie moglem uruchomic systemu. Dostawalem taki ekran:
Pomoglo recovery i usuniecie sterowników. Moze stare sterowniki cos maca w systemie? Jest jakis inny sposób na instalacje?
