Rysio Napisano Listopad 19, 2012 Zgłoszenie Share Napisano Listopad 19, 2012 Korzystam z fc17.x86_64 , dwa dni temu bawilem sie symulatorem EU07, dzialal pod wien bez zarzutu, po zakonczeniu zabawy, dalem yum -y update, sprawdzalem i aktualizacja obejmowala "wine" Od tego czasu symulator nie dziala, usunalem konfiguracje wine z katalogu domowego rm -Rf .wine Po czym ponowna próba uruchomienia - ale niestety to samo; wklejam to co udalo mi sie "zdobyc": wine: created the configuration directory '/home/user/.wine' fixme:storage:create_storagefile Storage share mode not implemented. err:mscoree:LoadLibraryShim error reading registry key for installroot err:mscoree:LoadLibraryShim error reading registry key for installroot err:mscoree:LoadLibraryShim error reading registry key for installroot err:mscoree:LoadLibraryShim error reading registry key for installroot err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution. fixme:iphlpapi:NotifyAddrChange (Handle 0xdee2c8, overlapped 0xdee2e0): stub err:advpack:create_tmp_ini_file Can't find REGINST resource err:qmgr:register_server RegInstall failed: 80004005 fixme:storage:create_storagefile Storage share mode not implemented. err:mscoree:LoadLibraryShim error reading registry key for installroot err:mscoree:LoadLibraryShim error reading registry key for installroot err:mscoree:LoadLibraryShim error reading registry key for installroot err:mscoree:LoadLibraryShim error reading registry key for installroot p11-kit: couldn't load module: /usr/lib/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/pkcs11/gnome-keyring-pkcs11.so: nie mozna otworzyc pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution. fixme:iphlpapi:NotifyAddrChange (Handle 0xede8d0, overlapped 0xede8dc): stub err:advpack:create_tmp_ini_file Can't find REGINST resource err:qmgr:register_server RegInstall failed: 80004005 wine: configuration in '/home/user/.wine' has been updated. ____________________________________________________________________ [user@tysiaczek eu_07_424]$ wine RAINSTED.exe err:winediag:X11DRV_WineGL_InitOpenglInfo Direct rendering is disabled, most likely your OpenGL drivers haven't been installed correctly (using GL renderer "Mesa DRI Intel(R) Sandybridge Mobile ", version "1.4 (2.1 Mesa 8.0.4)"). err:mmdevapi:DllGetClassObject Driver initialization failed err:ole:apartment_getclassobject DllGetClassObject returned error 0x80004005 err:ole:CoGetClassObject no class object {bcde0395-e52f-467c-8e3d-c4579291692e} could be created for context 0x1 err:dsound:get_mmdevenum CoCreateInstance failed: 80004005 wine: Unhandled page fault on read access to 0x00000000 at address 0x461322 (thread 002a), starting debugger... [user@tysiaczek eu_07_424]$ ____________________________________________________________________ [user@tysiaczek eu_07_424]$ killall -9 EU07.EXE [user@tysiaczek eu_07_424]$ Process of pid=0029 has terminated No process loaded, cannot execute 'echo Modules:' Cannot get info on module while no process is loaded No process loaded, cannot execute 'echo Threads:' process tid prio (all id:s are in hex) 0000000e services.exe 00000016 0 00000015 0 00000010 0 0000000f 0 00000012 winedevice.exe 0000001a 0 00000019 0 00000014 0 00000013 0 00000026 explorer.exe 00000027 0 winedbg: Internal crash at 0x7edc5429 W logach widze problem z gnome - jednak ja korzystam ze srodowiska KDE. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
3k_PL Napisano Listopad 21, 2012 Zgłoszenie Share Napisano Listopad 21, 2012 Jesli Cie to pocieszy to mi jedna aplikacja po tej aktualizacji tez sie nie uruchamia, choc wczesniej dzialala. Zajrze do tego za jakis czas, ale nie teraz poniewaz sa wazniejsze dla mnie rzeczy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Rysio Napisano Listopad 21, 2012 Autor Zgłoszenie Share Napisano Listopad 21, 2012 Takie rzeczy raczej nie ciesza, natomiast dzieki za zainteresowanie tematem, faktem jest ze dla przykladu inna aplikacja dziala z wine - sa to testy na prawko, akurat mialem na dysku wiec dla dobra nauki uruchomilem. Dzialalo bez zarzutu. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
3k_PL Napisano Listopad 24, 2012 Zgłoszenie Share Napisano Listopad 24, 2012 Zaktualizuj wine z 1.5.16 do 1.5.17 i problem sam sie rozwiaze, a przynajmniej dla mnie sie rozwiazal. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Rysio Napisano Grudzień 22, 2012 Autor Zgłoszenie Share Napisano Grudzień 22, 2012 [sOLVED] Mialem wlasnie napisac ze po kolejnej aktualizacji wine wszystko wrócilo do normy. Dzieki za zainteresowanie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
