AsFe Napisano Luty 28, 2013 Zgłoszenie Share Napisano Luty 28, 2013 (edytowane) Witam, Po zainstalowaniu sterowników ATI w Gnome 3.2.6 w F18, po kliknięciu "Podgląd" w górnym lewym rogu, zamiast transparentnego tła mam jednolite czarne. Można w jakiś sposób zmienić ustawienia, żeby było jednak widać to tło tak jak na domyślnych sterownikach? Reinstalowałem już gnome-shell, ale nic nie pomogło. Konsola i inne okna, działają prawidłowo - transparentne tło. uname -r: 3.7.9-205.fc18.x86_64 [root@asfe-at-fedora asfe]# fglrxinfo display: :0 screen: 0 OpenGL vendor string: Advanced Micro Devices, Inc. OpenGL renderer string: AMD Radeon HD 6300M Series OpenGL version string: 4.2.12002 Compatibility Profile Context 9.012 [root@asfe-at-fedora asfe]# glxgears 12160 frames in 5.0 seconds = 2431.937 FPS 11821 frames in 5.0 seconds = 2364.090 FPS 12972 frames in 5.0 seconds = 2594.400 FPS 12517 frames in 5.0 seconds = 2503.187 FPS 12170 frames in 5.0 seconds = 2433.905 FPS 12836 frames in 5.0 seconds = 2566.967 FPS 12673 frames in 5.0 seconds = 2534.510 FPS 12688 frames in 5.0 seconds = 2537.443 FPS 11969 frames in 5.0 seconds = 2393.753 FPS 11830 frames in 5.0 seconds = 2365.943 FPS XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0" after 125338 requests (125338 known processed) with 0 events remaining. tak wygląda plik xorg.conf: Section "ServerLayout" Identifier "aticonfig Layout" Screen 0 "aticonfig-Screen[0]-0" 0 0 EndSection Section "Module" EndSection Section "Monitor" Identifier "aticonfig-Monitor[0]-0" Option "VendorName" "ATI Proprietary Driver" Option "ModelName" "Generic Autodetecting Monitor" Option "DPMS" "true" EndSection Section "Device" Identifier "aticonfig-Device[0]-0" Driver "fglrx" BusID "PCI:1:0:0" EndSection Section "Screen" Identifier "aticonfig-Screen[0]-0" Device "aticonfig-Device[0]-0" Monitor "aticonfig-Monitor[0]-0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection Edit: Teraz widzę "paski" jak przy błędzie sterownika karty :/ Pulpit i okna wyglądają OK, ale hot corner i przełączanie okien alt+tab (gnome-extensions) ma właśnie "zepsute" tło. Edytowane Luty 28, 2013 przez AsFe Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
