Fc19 Problem Z Nvidia Przy Upgrade
deepblu
Dzieje się coś czego nie rozumiem:
(jakim cudem chce jakieś 173xx, 319, ...  ???)
sudo yum upgrade
Loaded plugins: fastestmirror, langpacks, refresh-packagekit
Loading mirror speeds from cached hostfile
 * fedora: sunsite.icm.edu.pl
 * rpmfusion-free: ftp.icm.edu.pl
 * rpmfusion-free-updates: ftp.icm.edu.pl
 * rpmfusion-nonfree: ftp.icm.edu.pl
 * rpmfusion-nonfree-updates: ftp.icm.edu.pl
 * updates: ftp.wsisiz.edu.pl
Resolving Dependencies
--> Running transaction check
---> Package akmod-nvidia.x86_64 1:319.23-1.fc19.3 will be updated
---> Package akmod-nvidia.x86_64 1:319.32-1.fc19 will be an update
---> Package kernel.x86_64 0:3.9.9-302.fc19 will be installed
---> Package kernel-devel.x86_64 0:3.9.9-302.fc19 will be installed
---> Package kernel-headers.x86_64 0:3.9.9-301.fc19 will be updated
---> Package kernel-headers.x86_64 0:3.9.9-302.fc19 will be an update
---> Package kernel-modules-extra.x86_64 0:3.9.9-302.fc19 will be installed
---> Package libX11.i686 0:1.5.99.902-1.fc19 will be updated
---> Package libX11.x86_64 0:1.5.99.902-1.fc19 will be updated
---> Package libX11.i686 0:1.6.0-1.fc19 will be an update
---> Package libX11.x86_64 0:1.6.0-1.fc19 will be an update
---> Package libX11-common.noarch 0:1.5.99.902-1.fc19 will be updated
---> Package libX11-common.noarch 0:1.6.0-1.fc19 will be an update
---> Package libexttextcat.x86_64 0:3.4.1-1.fc19 will be updated
---> Package libexttextcat.x86_64 0:3.4.3-1.fc19 will be an update
---> Package nvidia-settings.x86_64 0:1.0-32.fc19 will be obsoleted
---> Package nvidia-settings-desktop.x86_64 0:1.0-32.fc19 will be obsoleted
---> Package nvidia-xconfig.x86_64 0:1.0-28.fc19 will be obsoleted
---> Package xorg-x11-drv-nvidia.x86_64 1:319.23-5.fc19 will be updated
---> Package xorg-x11-drv-nvidia.x86_64 1:319.32-4.fc19 will be obsoleting
---> Package xorg-x11-drv-nvidia-173xx.x86_64 0:173.14.37-2.fc19 will be obsoleting
--> Processing Dependency: xorg-x11-drv-nvidia-173xx-libs(x86-64) = 173.14.37-2.fc19 for package: xorg-x11-drv-nvidia-173xx-173.14.37-2.fc19.x86_64
--> Processing Dependency: nvidia-173xx-kmod >= 173.14.37 for package: xorg-x11-drv-nvidia-173xx-173.14.37-2.fc19.x86_64
--> Processing Dependency: libGLcore.so.1()(64bit) for package: xorg-x11-drv-nvidia-173xx-173.14.37-2.fc19.x86_64
---> Package xorg-x11-drv-nvidia-304xx.x86_64 0:304.88-9.fc19 will be obsoleting
--> Processing Dependency: xorg-x11-drv-nvidia-304xx-libs(x86-64) = 304.88-9.fc19 for package: xorg-x11-drv-nvidia-304xx-304.88-9.fc19.x86_64
--> Processing Dependency: nvidia-304xx-kmod >= 304.88 for package: xorg-x11-drv-nvidia-304xx-304.88-9.fc19.x86_64
---> Package xorg-x11-drv-nvidia-libs.i686 1:319.23-5.fc19 will be updated
---> Package xorg-x11-drv-nvidia-libs.x86_64 1:319.23-5.fc19 will be updated
---> Package xorg-x11-drv-nvidia-libs.i686 1:319.32-4.fc19 will be an update
---> Package xorg-x11-drv-nvidia-libs.x86_64 1:319.32-4.fc19 will be an update
---> Package xorg-x11-server-Xorg.x86_64 0:1.14.2-3.fc19 will be updated
---> Package xorg-x11-server-Xorg.x86_64 0:1.14.2-4.fc19 will be an update
---> Package xorg-x11-server-common.x86_64 0:1.14.2-3.fc19 will be updated
---> Package xorg-x11-server-common.x86_64 0:1.14.2-4.fc19 will be an update
---> Package xulrunner.x86_64 0:22.0-1.fc19 will be updated
---> Package xulrunner.x86_64 0:22.0-4.fc19 will be an update
---> Package akmod-nvidia-173xx.x86_64 0:173.14.37-1.fc19.4 will be installed
---> Package akmod-nvidia-304xx.x86_64 0:304.88-1.fc19.3 will be installed
---> Package xorg-x11-drv-nvidia-173xx-libs.x86_64 0:173.14.37-2.fc19 will be installed
---> Package xorg-x11-drv-nvidia-304xx-libs.x86_64 0:304.88-9.fc19 will be installed
--> Processing Conflict: xorg-x11-drv-nvidia-304xx-304.88-9.fc19.x86_64 conflicts xorg-x11-drv-nvidia-173xx
--> Processing Conflict: 1:xorg-x11-drv-nvidia-319.32-4.fc19.x86_64 conflicts xorg-x11-drv-nvidia-173xx
--> Processing Conflict: xorg-x11-drv-nvidia-173xx-173.14.37-2.fc19.x86_64 conflicts xorg-x11-drv-nvidia
--> Finished Dependency Resolution
Error: xorg-x11-drv-nvidia-173xx conflicts with xorg-x11-drv-nvidia-304xx-304.88-9.fc19.x86_64
Error: xorg-x11-drv-nvidia-304xx conflicts with xorg-x11-drv-nvidia-173xx-173.14.37-2.fc19.x86_64
Error: xorg-x11-drv-nvidia-173xx conflicts with 1:xorg-x11-drv-nvidia-319.32-4.fc19.x86_64
Error: xorg-x11-drv-nvidia conflicts with xorg-x11-drv-nvidia-173xx-173.14.37-2.fc19.x86_64
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
