Pam_Cracklib
Sofcik
Cześć
Mam pytanie: w wymaganiach security mam nastepujące punkty:
1. Hasło ma mieć długość minimum 8 znaków
2. Hasło musi zawierać conajmniej jeden znak specjalny, jedną cyfrę i 2 wielkie litery
Stąd logicznym wydaje się wpis:
password     requisite     pam_cracklib.so try_first_pass retry=3 type= ocredit=-1 dcredit=-1 ucredit=-2 minlen=8
Jednak w sieci znalazłem następujące zalecenie:
password     requisite     pam_cracklib.so try_first_pass retry=3 type= ocredit=-1 dcredit=-1 ucredit=-2 minlen=9
Dlaczego jest tam liczba 9 a nie 8?
Piotrek
Jeden z instruktorów RH opisał to tak:
lcredit, ucredit, dcredit, and ocredit all default to 1 unless otherwise specified. The affect is that for the first character of each type, you actually get a credit of 2 (1 for the character itself plus an extra 1 for the first use). The next time you use a character of that class, you only get a credit of 1. This can lead to confusion regarding why users can set a password that is less than minlen. For example, on page 98, students use: minlen=12 ocredit=-1 dcredit=-1. The password i<3mylittleponies works as expected, but so does i<3mylittle (11 characters). Eleven characters are acceptable since the first lower-case character gets +2. i<3myLittl (10 characters) also works because you get +2 for the first lower-case character and +2 for the first upper-case character. If students were to only use other characters and digits, then the minimum length of 12 would be enforced. To make this work as expected, students should use: minlen=12 ocredit=-1 dcredit=-1 lcredit=0 ucredit=0. Item 10 of the comprehensive review (page 219 or 333 in the appendix of the student workbook) tries to adjust for this. Item 10 indicates that the password should be at least 8 characters long. The appendix shows minlen=9. Students could use minlen=8 provided they also use lcredit=0.
