slabypingwin Napisano Listopad 29, 2015 Zgłoszenie Share Napisano Listopad 29, 2015 Odtwarzacz kaffeine znajduje wszystkie stacje naziemnej tv ale nie ma ani obrazu ani dźwięku W konsoli pokazuje tak ; [darek@localhost ~]$ kaffeine/usr/bin/kaffeine-xbu: /usr/lib64/nvidia-304xx/libOpenCL.so.1: no version information available (required by /lib64/libavutil.so.54)[darek@localhost ~]$ vo_vdpau: vdpau API version : 1vo_vdpau: vdpau implementation description : NVIDIA VDPAU Driver Shared Library 304.128 Wed Aug 26 11:01:14 PDT 2015vo_vdpau: maximum video surface size for chroma type 4:2:2 is 4096x4096vo_vdpau: maximum video surface size for chroma type 4:2:0 is 4096x4096vo_vdpau: maximum output surface size is 8192x8192vo_vdpau: hold a maximum of 10 video output surfaces for reusevo_vdpau: using 3 output surfaces of size 1680x1050 for display queuevo_vdpau: this hardware doesn't support mpeg4-part2.kaffeine(1922) DvbDevice::frontendEvent: tuning faileddemux_wavpack: (open_wv_file:127) open_wv_file: non-seekable inputs aren't supported yet.net_buf_ctrl: dvbspeed modenet_buf_ctrl: dvbspeed OFFdemux_wavpack: (open_wv_file:127) open_wv_file: non-seekable inputs aren't supported yet.net_buf_ctrl: dvbspeed modenet_buf_ctrl: dvbspeed OFF Proszę o porady Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
