alastis Napisano Grudzień 13, 2017 Zgłoszenie Share Napisano Grudzień 13, 2017 Witam wszystkich mam problem z uruchomieniem Vmvare player polecenie: sh VMware-VIX-1.17.0-6661328.x86_64.bundle Zadziałało bez najmniejszego problemu ale niestety podczas uruchomienia pojawiają się okienko Cytuj before you can run vmware several modules must be compiled and loaded into the running kernel Podgląd vmware-6838.log 2017-12-13T22:00:58.544Z| vthread-1| I125: Log for VMware Workstation pid=5718 version=14.0.0 build=build-6661328 option=Release 2017-12-13T22:00:58.544Z| vthread-1| I125: The process is 64-bit. 2017-12-13T22:00:58.544Z| vthread-1| I125: Host codepage=UTF-8 encoding=UTF-8 2017-12-13T22:00:58.544Z| vthread-1| I125: Host is Linux 4.14.3-300.fc27.x86_64 Fedora release 27 (Twenty Seven) 2017-12-13T22:00:58.544Z| vthread-1| I125: DictionaryLoad: Cannot open file "/usr/lib/vmware/settings": No such file or directory. 2017-12-13T22:00:58.544Z| vthread-1| I125: [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/settings": No such file or directory. 2017-12-13T22:00:58.544Z| vthread-1| I125: PREF Optional preferences file not found at /usr/lib/vmware/settings. Using default values. 2017-12-13T22:00:58.544Z| vthread-1| I125: DictionaryLoad: Cannot open file "/home/alastis/.vmware/config": No such file or directory. 2017-12-13T22:00:58.544Z| vthread-1| I125: [msg.dictionary.load.openFailed] Cannot open file "/home/alastis/.vmware/config": No such file or directory. 2017-12-13T22:00:58.544Z| vthread-1| I125: PREF Optional preferences file not found at /home/alastis/.vmware/config. Using default values. 2017-12-13T22:00:58.544Z| vthread-1| I125: DictionaryLoad: Cannot open file "/home/alastis/.vmware/preferences": No such file or directory. 2017-12-13T22:00:58.544Z| vthread-1| I125: [msg.dictionary.load.openFailed] Cannot open file "/home/alastis/.vmware/preferences": No such file or directory. 2017-12-13T22:00:58.544Z| vthread-1| I125: PREF Optional preferences file not found at /home/alastis/.vmware/preferences. Using default values. 2017-12-13T22:00:58.560Z| vthread-1| W115: Logging to /tmp/vmware-root/vmware-5718.log 2017-12-13T22:00:58.575Z| vthread-1| I125: Obtaining info using the running kernel. 2017-12-13T22:00:58.575Z| vthread-1| I125: Created new pathsHash. 2017-12-13T22:00:58.575Z| vthread-1| I125: Setting header path for 4.14.3-300.fc27.x86_64 to "/lib/modules/4.14.3-300.fc27.x86_64/build/include". 2017-12-13T22:00:58.575Z| vthread-1| I125: Validating path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for kernel release "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:58.575Z| vthread-1| I125: Failed to find /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h 2017-12-13T22:00:58.575Z| vthread-1| I125: /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2017-12-13T22:00:58.575Z| vthread-1| I125: using /usr/bin/gcc for preprocess check 2017-12-13T22:00:58.586Z| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:58.586Z| vthread-1| I125: The header path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for the kernel "4.14.3-300.fc27.x86_64" is valid. Whoohoo! 2017-12-13T22:00:58.899Z| vthread-1| I125: found symbol version file /lib/modules/4.14.3-300.fc27.x86_64/build/Module.symvers 2017-12-13T22:00:58.899Z| vthread-1| I125: Reading symbol versions from /lib/modules/4.14.3-300.fc27.x86_64/build/Module.symvers. 2017-12-13T22:00:58.931Z| vthread-1| I125: Read 19116 symbol versions 2017-12-13T22:00:58.932Z| vthread-1| I125: Reading in info for the vmmon module. 2017-12-13T22:00:58.932Z| vthread-1| I125: Reading in info for the vmnet module. 2017-12-13T22:00:58.932Z| vthread-1| I125: Reading in info for the vmblock module. 2017-12-13T22:00:58.932Z| vthread-1| I125: Reading in info for the vmci module. 2017-12-13T22:00:58.932Z| vthread-1| I125: Reading in info for the vsock module. 2017-12-13T22:00:58.932Z| vthread-1| I125: Setting vsock to depend on vmci. 2017-12-13T22:00:58.932Z| vthread-1| I125: Invoking modinfo on "vmmon". 2017-12-13T22:00:58.936Z| vthread-1| I125: "/sbin/modinfo" exited with status 256. 2017-12-13T22:00:58.936Z| vthread-1| I125: Invoking modinfo on "vmnet". 2017-12-13T22:00:58.939Z| vthread-1| I125: "/sbin/modinfo" exited with status 0. 2017-12-13T22:00:58.939Z| vthread-1| I125: Invoking modinfo on "vmblock". 2017-12-13T22:00:58.942Z| vthread-1| I125: "/sbin/modinfo" exited with status 256. 2017-12-13T22:00:58.942Z| vthread-1| I125: Invoking modinfo on "vmci". 2017-12-13T22:00:58.945Z| vthread-1| I125: "/sbin/modinfo" exited with status 256. 2017-12-13T22:00:58.945Z| vthread-1| I125: Invoking modinfo on "vsock". 2017-12-13T22:00:58.950Z| vthread-1| I125: "/sbin/modinfo" exited with status 0. 2017-12-13T22:00:58.964Z| vthread-1| I125: to be installed: vmmon status: 0 2017-12-13T22:00:58.977Z| vthread-1| I125: Obtaining info using the running kernel. 2017-12-13T22:00:58.977Z| vthread-1| I125: Setting header path for 4.14.3-300.fc27.x86_64 to "/lib/modules/4.14.3-300.fc27.x86_64/build/include". 2017-12-13T22:00:58.977Z| vthread-1| I125: Validating path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for kernel release "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:58.977Z| vthread-1| I125: Failed to find /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h 2017-12-13T22:00:58.977Z| vthread-1| I125: /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2017-12-13T22:00:58.977Z| vthread-1| I125: using /usr/bin/gcc for preprocess check 2017-12-13T22:00:58.987Z| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:58.987Z| vthread-1| I125: The header path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for the kernel "4.14.3-300.fc27.x86_64" is valid. Whoohoo! 2017-12-13T22:00:59.198Z| vthread-1| I125: found symbol version file /lib/modules/4.14.3-300.fc27.x86_64/build/Module.symvers 2017-12-13T22:00:59.198Z| vthread-1| I125: Reading symbol versions from /lib/modules/4.14.3-300.fc27.x86_64/build/Module.symvers. 2017-12-13T22:00:59.219Z| vthread-1| I125: Read 19116 symbol versions 2017-12-13T22:00:59.219Z| vthread-1| I125: Kernel header path retrieved from FileEntry: /lib/modules/4.14.3-300.fc27.x86_64/build/include 2017-12-13T22:00:59.219Z| vthread-1| I125: Update kernel header path to /lib/modules/4.14.3-300.fc27.x86_64/build/include 2017-12-13T22:00:59.219Z| vthread-1| I125: Validating path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for kernel release "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.219Z| vthread-1| I125: Failed to find /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h 2017-12-13T22:00:59.219Z| vthread-1| I125: /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2017-12-13T22:00:59.219Z| vthread-1| I125: using /usr/bin/gcc for preprocess check 2017-12-13T22:00:59.230Z| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.230Z| vthread-1| I125: The header path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for the kernel "4.14.3-300.fc27.x86_64" is valid. Whoohoo! 2017-12-13T22:00:59.231Z| vthread-1| I125: Found compiler at "/usr/bin/gcc" 2017-12-13T22:00:59.237Z| vthread-1| I125: Got gcc version "7". 2017-12-13T22:00:59.237Z| vthread-1| I125: The GCC version matches the kernel GCC minor version like a glove. 2017-12-13T22:00:59.243Z| vthread-1| I125: Got gcc version "7". 2017-12-13T22:00:59.243Z| vthread-1| I125: The GCC version matches the kernel GCC minor version like a glove. 2017-12-13T22:00:59.244Z| vthread-1| I125: Trying to find a suitable PBM set for kernel "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.244Z| vthread-1| I125: No matching PBM set was found for kernel "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.244Z| vthread-1| I125: The GCC version matches the kernel GCC minor version like a glove. 2017-12-13T22:00:59.244Z| vthread-1| I125: Validating path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for kernel release "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.244Z| vthread-1| I125: Failed to find /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h 2017-12-13T22:00:59.244Z| vthread-1| I125: /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2017-12-13T22:00:59.245Z| vthread-1| I125: using /usr/bin/gcc for preprocess check 2017-12-13T22:00:59.255Z| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.255Z| vthread-1| I125: The header path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for the kernel "4.14.3-300.fc27.x86_64" is valid. Whoohoo! 2017-12-13T22:00:59.257Z| vthread-1| I125: The GCC version matches the kernel GCC minor version like a glove. 2017-12-13T22:00:59.257Z| vthread-1| I125: Validating path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for kernel release "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.257Z| vthread-1| I125: Failed to find /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h 2017-12-13T22:00:59.257Z| vthread-1| I125: /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2017-12-13T22:00:59.257Z| vthread-1| I125: using /usr/bin/gcc for preprocess check 2017-12-13T22:00:59.269Z| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.269Z| vthread-1| I125: The header path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for the kernel "4.14.3-300.fc27.x86_64" is valid. Whoohoo! 2017-12-13T22:00:59.269Z| vthread-1| I125: Using temp dir "/tmp". 2017-12-13T22:00:59.271Z| vthread-1| I125: Obtaining info using the running kernel. 2017-12-13T22:00:59.271Z| vthread-1| I125: Setting header path for 4.14.3-300.fc27.x86_64 to "/lib/modules/4.14.3-300.fc27.x86_64/build/include". 2017-12-13T22:00:59.271Z| vthread-1| I125: Validating path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for kernel release "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.271Z| vthread-1| I125: Failed to find /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h 2017-12-13T22:00:59.271Z| vthread-1| I125: /lib/modules/4.14.3-300.fc27.x86_64/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead. 2017-12-13T22:00:59.271Z| vthread-1| I125: using /usr/bin/gcc for preprocess check 2017-12-13T22:00:59.282Z| vthread-1| I125: Preprocessed UTS_RELEASE, got value "4.14.3-300.fc27.x86_64". 2017-12-13T22:00:59.283Z| vthread-1| I125: The header path "/lib/modules/4.14.3-300.fc27.x86_64/build/include" for the kernel "4.14.3-300.fc27.x86_64" is valid. Whoohoo! 2017-12-13T22:00:59.588Z| vthread-1| I125: found symbol version file /lib/modules/4.14.3-300.fc27.x86_64/build/Module.symvers 2017-12-13T22:00:59.588Z| vthread-1| I125: Reading symbol versions from /lib/modules/4.14.3-300.fc27.x86_64/build/Module.symvers. 2017-12-13T22:00:59.619Z| vthread-1| I125: Read 19116 symbol versions 2017-12-13T22:00:59.619Z| vthread-1| I125: Invoking modinfo on "vmmon". 2017-12-13T22:00:59.624Z| vthread-1| I125: "/sbin/modinfo" exited with status 256. 2017-12-13T22:00:59.746Z| vthread-1| I125: Setting destination path for vmmon to "/lib/modules/4.14.3-300.fc27.x86_64/misc/vmmon.ko". 2017-12-13T22:00:59.756Z| vthread-1| I125: Extracting the vmmon source from "/usr/lib/vmware/modules/source/vmmon.tar". 2017-12-13T22:00:59.801Z| vthread-1| I125: Successfully extracted the vmmon source. 2017-12-13T22:00:59.801Z| vthread-1| I125: Building module with command "/usr/bin/make -j4 -C /tmp/modconfig-N49bxg/vmmon-only auto-build HEADER_DIR=/lib/modules/4.14.3-300.fc27.x86_64/build/include CC=/usr/bin/gcc IS_GCC_3=no" 2017-12-13T22:01:04.787Z| vthread-1| W115: Failed to build vmmon. Failed to execute the build command. uname --r 4.14.3-300.fc27.x86_64 Wszelka pomoc mile widziana a i jeszcze to: [alastis@localhost ~]$ sudo su - [root@localhost ~]# vmware-modconfig --console --install-all [AppLoader] GLib does not have GSettings support. Zatrzymywanie vmware (przez systemctl): [ OK ] make: Wejście do katalogu '/tmp/modconfig-7RaPAH/vmmon-only' Using kernel build system. /usr/bin/make -C /lib/modules/4.14.3-300.fc27.x86_64/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. \ MODULEBUILDDIR= modules make[1]: Wejście do katalogu '/usr/src/kernels/4.14.3-300.fc27.x86_64' CC [M] /tmp/modconfig-7RaPAH/vmmon-only/linux/driverLog.o CC [M] /tmp/modconfig-7RaPAH/vmmon-only/linux/driver.o CC [M] /tmp/modconfig-7RaPAH/vmmon-only/linux/hostif.o CC [M] /tmp/modconfig-7RaPAH/vmmon-only/common/memtrack.o CC [M] /tmp/modconfig-7RaPAH/vmmon-only/common/apic.o CC [M] /tmp/modconfig-7RaPAH/vmmon-only/common/hashFunc.o CC [M] /tmp/modconfig-7RaPAH/vmmon-only/common/vmx86.o In file included from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm.h:43:0, from /tmp/modconfig-7RaPAH/vmmon-only/linux/hostif.c:60: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86msr.h:115:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x140 In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/rcupdate.h:40, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from ./include/linux/binfmts.h:5, from /tmp/modconfig-7RaPAH/vmmon-only/linux/hostif.c:32: ./arch/x86/include/asm/msr-index.h:572:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x00000140 CC [M] /tmp/modconfig-7RaPAH/vmmon-only/common/cpuid.o In file included from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm_x86.h:41:0, from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm_x86_64.h:40, from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm.h:46, from /tmp/modconfig-7RaPAH/vmmon-only/linux/hostif.c:60: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86_basic_defs.h:78:0: warning: "CR3_PCID_MASK" redefined #define CR3_PCID_MASK 0xFFF In file included from ./arch/x86/include/asm/irqflags.h:5:0, from ./include/linux/irqflags.h:16, from ./include/linux/rcupdate.h:39, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from ./include/linux/binfmts.h:5, from /tmp/modconfig-7RaPAH/vmmon-only/linux/hostif.c:32: ./arch/x86/include/asm/processor-flags.h:39:0: note: this is the location of the previous definition #define CR3_PCID_MASK 0xFFFull In file included from /tmp/modconfig-7RaPAH/vmmon-only/common/vmx86.h:32:0, from /tmp/modconfig-7RaPAH/vmmon-only/common/vmx86.c:43: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86msr.h:115:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x140 In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/rcupdate.h:40, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from /tmp/modconfig-7RaPAH/vmmon-only/common/vmx86.c:31: ./arch/x86/include/asm/msr-index.h:572:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x00000140 In file included from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm_x86.h:41:0, from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm_x86_64.h:40, from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm.h:46, from /tmp/modconfig-7RaPAH/vmmon-only/common/vmx86.c:46: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86_basic_defs.h:78:0: warning: "CR3_PCID_MASK" redefined #define CR3_PCID_MASK 0xFFF In file included from ./arch/x86/include/asm/irqflags.h:5:0, from ./include/linux/irqflags.h:16, from ./include/linux/rcupdate.h:39, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from /tmp/modconfig-7RaPAH/vmmon-only/common/vmx86.c:31: ./arch/x86/include/asm/processor-flags.h:39:0: note: this is the location of the previous definition #define CR3_PCID_MASK 0xFFFull In file included from /tmp/modconfig-7RaPAH/vmmon-only/./common/vmx86.h:32:0, from /tmp/modconfig-7RaPAH/vmmon-only/linux/driver.h:32, from /tmp/modconfig-7RaPAH/vmmon-only/linux/driver.c:47: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86msr.h:115:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x140 In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/spinlock.h:51, from ./include/linux/wait.h:9, from ./include/linux/wait_bit.h:8, from ./include/linux/fs.h:6, from ./include/linux/highmem.h:5, from /tmp/modconfig-7RaPAH/vmmon-only/linux/driver.c:25: ./arch/x86/include/asm/msr-index.h:572:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x00000140 CC [M] /tmp/modconfig-7RaPAH/vmmon-only/common/task.o In file included from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm_x86.h:41:0, from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm_x86_64.h:40, from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm.h:46, from /tmp/modconfig-7RaPAH/vmmon-only/linux/driver.c:49: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86_basic_defs.h:78:0: warning: "CR3_PCID_MASK" redefined #define CR3_PCID_MASK 0xFFF In file included from ./arch/x86/include/asm/processor.h:5:0, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/spinlock.h:51, from ./include/linux/wait.h:9, from ./include/linux/wait_bit.h:8, from ./include/linux/fs.h:6, from ./include/linux/highmem.h:5, from /tmp/modconfig-7RaPAH/vmmon-only/linux/driver.c:25: ./arch/x86/include/asm/processor-flags.h:39:0: note: this is the location of the previous definition #define CR3_PCID_MASK 0xFFFull /tmp/modconfig-7RaPAH/vmmon-only/linux/hostif.c: In function ‘HostIF_EstimateLockedPageLimit’: /tmp/modconfig-7RaPAH/vmmon-only/linux/hostif.c:1519:31: error: implicit declaration of function ‘global_page_state’; did you mean ‘global_numa_state’? [-Werror=implicit-function-declaration] unsigned int lockedPages = global_page_state(NR_PAGETABLE) + ^~~~~~~~~~~~~~~~~ global_numa_state /tmp/modconfig-7RaPAH/vmmon-only/linux/driver.c:981:1: warning: always_inline function might not be inlinable [-Wattributes] LinuxDriverSyncReadTSCs(uint64 *delta) // OUT: TSC max - TSC min ^~~~~~~~~~~~~~~~~~~~~~~ In file included from ./arch/x86/include/asm/processor.h:5:0, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/spinlock.h:51, from ./arch/x86/include/asm/mmu.h:5, from ./arch/x86/include/asm/desc.h:7, from /tmp/modconfig-7RaPAH/vmmon-only/common/task.c:70: ./arch/x86/include/asm/processor-flags.h:39:0: warning: "CR3_PCID_MASK" redefined #define CR3_PCID_MASK 0xFFFull In file included from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm_x86.h:41:0, from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm_x86_64.h:40, from /tmp/modconfig-7RaPAH/vmmon-only/./include/vm_asm.h:46, from /tmp/modconfig-7RaPAH/vmmon-only/common/task.c:53: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86_basic_defs.h:78:0: note: this is the location of the previous definition #define CR3_PCID_MASK 0xFFF In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/spinlock.h:51, from ./arch/x86/include/asm/mmu.h:5, from ./arch/x86/include/asm/desc.h:7, from /tmp/modconfig-7RaPAH/vmmon-only/common/task.c:70: ./arch/x86/include/asm/msr-index.h:572:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x00000140 In file included from /tmp/modconfig-7RaPAH/vmmon-only/common/vmx86.h:32:0, from /tmp/modconfig-7RaPAH/vmmon-only/common/task.c:51: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86msr.h:115:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x140 CC [M] /tmp/modconfig-7RaPAH/vmmon-only/common/comport.o CC [M] /tmp/modconfig-7RaPAH/vmmon-only/common/phystrack.o /tmp/modconfig-7RaPAH/vmmon-only/common/vmx86.o: warning: objtool: Vmx86EnableHVOnCPU() falls through to next function Vmx86GetMSR() CC [M] /tmp/modconfig-7RaPAH/vmmon-only/vmcore/moduleloop.o /tmp/modconfig-7RaPAH/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Free() falls through to next function PhysTrack_Add() /tmp/modconfig-7RaPAH/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Add() falls through to next function PhysTrack_Remove() /tmp/modconfig-7RaPAH/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Remove() falls through to next function PhysTrack_Test() CC [M] /tmp/modconfig-7RaPAH/vmmon-only/bootstrap/monLoaderVmmon.o cc1: some warnings being treated as errors make[2]: *** [scripts/Makefile.build:315: /tmp/modconfig-7RaPAH/vmmon-only/linux/hostif.o] Błąd 1 make[2]: *** Oczekiwanie na niezakończone zadania.... /tmp/modconfig-7RaPAH/vmmon-only/common/task.o: warning: objtool: .text: unexpected end of section In file included from /tmp/modconfig-7RaPAH/vmmon-only/./common/vmx86.h:32:0, from /tmp/modconfig-7RaPAH/vmmon-only/vmcore/moduleloop.c:35: /tmp/modconfig-7RaPAH/vmmon-only/./include/x86msr.h:115:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x140 In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/rcupdate.h:40, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from /tmp/modconfig-7RaPAH/vmmon-only/vmcore/moduleloop.c:31: ./arch/x86/include/asm/msr-index.h:572:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x00000140 /tmp/modconfig-7RaPAH/vmmon-only/bootstrap/monLoaderVmmon.o: warning: objtool: MonLoaderCallout_AllocMPN() falls through to next function MonLoaderCallout_MapMPNInPTE() /tmp/modconfig-7RaPAH/vmmon-only/bootstrap/monLoaderVmmon.o: warning: objtool: MonLoaderCallout_FillPage() falls through to next function MonLoaderCallout_CopyFromBlob() /tmp/modconfig-7RaPAH/vmmon-only/bootstrap/monLoaderVmmon.o: warning: objtool: MonLoaderCallout_CopyFromBlob() falls through to next function MonLoaderCallout_GetSharedUserPage() /tmp/modconfig-7RaPAH/vmmon-only/bootstrap/monLoaderVmmon.o: warning: objtool: MonLoaderCallout_GetSharedHostPage() falls through to next function MonLoaderCallout_IsPrivileged() /tmp/modconfig-7RaPAH/vmmon-only/bootstrap/monLoaderVmmon.o: warning: objtool: .text: unexpected end of section make[1]: *** [Makefile:1507: _module_/tmp/modconfig-7RaPAH/vmmon-only] Błąd 2 make[1]: Opuszczenie katalogu '/usr/src/kernels/4.14.3-300.fc27.x86_64' make: *** [Makefile:110: vmmon.ko] Błąd 2 make: Opuszczenie katalogu '/tmp/modconfig-7RaPAH/vmmon-only' make: Wejście do katalogu '/tmp/modconfig-7RaPAH/vmnet-only' Using kernel build system. /usr/bin/make -C /lib/modules/4.14.3-300.fc27.x86_64/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. \ MODULEBUILDDIR= modules make[1]: Wejście do katalogu '/usr/src/kernels/4.14.3-300.fc27.x86_64' CC [M] /tmp/modconfig-7RaPAH/vmnet-only/driver.o CC [M] /tmp/modconfig-7RaPAH/vmnet-only/hub.o CC [M] /tmp/modconfig-7RaPAH/vmnet-only/userif.o CC [M] /tmp/modconfig-7RaPAH/vmnet-only/netif.o In file included from ./include/linux/pci.h:37:0, from /tmp/modconfig-7RaPAH/vmnet-only/compat_netdevice.h:27, from /tmp/modconfig-7RaPAH/vmnet-only/netif.c:43: ./include/linux/pci_ids.h:2261:0: warning: "PCI_VENDOR_ID_VMWARE" redefined #define PCI_VENDOR_ID_VMWARE 0x15ad In file included from /tmp/modconfig-7RaPAH/vmnet-only/net.h:38:0, from /tmp/modconfig-7RaPAH/vmnet-only/vnetInt.h:26, from /tmp/modconfig-7RaPAH/vmnet-only/netif.c:42: /tmp/modconfig-7RaPAH/vmnet-only/vm_device_version.h:56:0: note: this is the location of the previous definition #define PCI_VENDOR_ID_VMWARE 0x15AD In file included from ./include/linux/pci.h:37:0, from /tmp/modconfig-7RaPAH/vmnet-only/compat_netdevice.h:27, from /tmp/modconfig-7RaPAH/vmnet-only/netif.c:43: ./include/linux/pci_ids.h:2262:0: warning: "PCI_DEVICE_ID_VMWARE_VMXNET3" redefined #define PCI_DEVICE_ID_VMWARE_VMXNET3 0x07b0 In file included from /tmp/modconfig-7RaPAH/vmnet-only/net.h:38:0, from /tmp/modconfig-7RaPAH/vmnet-only/vnetInt.h:26, from /tmp/modconfig-7RaPAH/vmnet-only/netif.c:42: /tmp/modconfig-7RaPAH/vmnet-only/vm_device_version.h:73:0: note: this is the location of the previous definition #define PCI_DEVICE_ID_VMWARE_VMXNET3 0x07B0 CC [M] /tmp/modconfig-7RaPAH/vmnet-only/bridge.o CC [M] /tmp/modconfig-7RaPAH/vmnet-only/procfs.o CC [M] /tmp/modconfig-7RaPAH/vmnet-only/smac_compat.o CC [M] /tmp/modconfig-7RaPAH/vmnet-only/smac.o CC [M] /tmp/modconfig-7RaPAH/vmnet-only/vnetEvent.o In file included from /tmp/modconfig-7RaPAH/vmnet-only/net.h:38:0, from /tmp/modconfig-7RaPAH/vmnet-only/vnetInt.h:26, from /tmp/modconfig-7RaPAH/vmnet-only/bridge.c:53: /tmp/modconfig-7RaPAH/vmnet-only/vm_device_version.h:56:0: warning: "PCI_VENDOR_ID_VMWARE" redefined #define PCI_VENDOR_ID_VMWARE 0x15AD In file included from ./include/linux/pci.h:37:0, from /tmp/modconfig-7RaPAH/vmnet-only/compat_netdevice.h:27, from /tmp/modconfig-7RaPAH/vmnet-only/bridge.c:52: ./include/linux/pci_ids.h:2261:0: note: this is the location of the previous definition #define PCI_VENDOR_ID_VMWARE 0x15ad In file included from /tmp/modconfig-7RaPAH/vmnet-only/net.h:38:0, from /tmp/modconfig-7RaPAH/vmnet-only/vnetInt.h:26, from /tmp/modconfig-7RaPAH/vmnet-only/bridge.c:53: /tmp/modconfig-7RaPAH/vmnet-only/vm_device_version.h:73:0: warning: "PCI_DEVICE_ID_VMWARE_VMXNET3" redefined #define PCI_DEVICE_ID_VMWARE_VMXNET3 0x07B0 In file included from ./include/linux/pci.h:37:0, from /tmp/modconfig-7RaPAH/vmnet-only/compat_netdevice.h:27, from /tmp/modconfig-7RaPAH/vmnet-only/bridge.c:52: ./include/linux/pci_ids.h:2262:0: note: this is the location of the previous definition #define PCI_DEVICE_ID_VMWARE_VMXNET3 0x07b0 CC [M] /tmp/modconfig-7RaPAH/vmnet-only/vnetUserListener.o LD [M] /tmp/modconfig-7RaPAH/vmnet-only/vmnet.o Building modules, stage 2. MODPOST 1 modules CC /tmp/modconfig-7RaPAH/vmnet-only/vmnet.mod.o LD [M] /tmp/modconfig-7RaPAH/vmnet-only/vmnet.ko make[1]: Opuszczenie katalogu '/usr/src/kernels/4.14.3-300.fc27.x86_64' /usr/bin/make -C $PWD SRCROOT=$PWD/. \ MODULEBUILDDIR= postbuild make[1]: Wejście do katalogu '/tmp/modconfig-7RaPAH/vmnet-only' make[1]: 'postbuild' jest aktualne. make[1]: Opuszczenie katalogu '/tmp/modconfig-7RaPAH/vmnet-only' cp -f vmnet.ko ./../vmnet.o make: Opuszczenie katalogu '/tmp/modconfig-7RaPAH/vmnet-only' Unable to install all modules. See log for details. sudo vmplayer Zatrzymywanie vmware (przez systemctl): [ OK ] make: Wejście do katalogu '/tmp/modconfig-pnr90z/vmmon-only' Using kernel build system. /bin/make -C /lib/modules/4.14.3-300.fc27.x86_64/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. \ MODULEBUILDDIR= modules make[1]: Wejście do katalogu '/usr/src/kernels/4.14.3-300.fc27.x86_64' CC [M] /tmp/modconfig-pnr90z/vmmon-only/linux/driverLog.o CC [M] /tmp/modconfig-pnr90z/vmmon-only/linux/driver.o CC [M] /tmp/modconfig-pnr90z/vmmon-only/linux/hostif.o CC [M] /tmp/modconfig-pnr90z/vmmon-only/common/memtrack.o CC [M] /tmp/modconfig-pnr90z/vmmon-only/common/apic.o CC [M] /tmp/modconfig-pnr90z/vmmon-only/common/hashFunc.o In file included from /tmp/modconfig-pnr90z/vmmon-only/./common/vmx86.h:32:0, from /tmp/modconfig-pnr90z/vmmon-only/linux/driver.h:32, from /tmp/modconfig-pnr90z/vmmon-only/linux/driver.c:47: /tmp/modconfig-pnr90z/vmmon-only/./include/x86msr.h:115:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x140 In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/spinlock.h:51, from ./include/linux/wait.h:9, from ./include/linux/wait_bit.h:8, from ./include/linux/fs.h:6, from ./include/linux/highmem.h:5, from /tmp/modconfig-pnr90z/vmmon-only/linux/driver.c:25: ./arch/x86/include/asm/msr-index.h:572:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x00000140 In file included from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm.h:43:0, from /tmp/modconfig-pnr90z/vmmon-only/linux/hostif.c:60: /tmp/modconfig-pnr90z/vmmon-only/./include/x86msr.h:115:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x140 In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/rcupdate.h:40, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from ./include/linux/binfmts.h:5, from /tmp/modconfig-pnr90z/vmmon-only/linux/hostif.c:32: ./arch/x86/include/asm/msr-index.h:572:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x00000140 CC [M] /tmp/modconfig-pnr90z/vmmon-only/common/vmx86.o In file included from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm_x86.h:41:0, from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm_x86_64.h:40, from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm.h:46, from /tmp/modconfig-pnr90z/vmmon-only/linux/hostif.c:60: /tmp/modconfig-pnr90z/vmmon-only/./include/x86_basic_defs.h:78:0: warning: "CR3_PCID_MASK" redefined #define CR3_PCID_MASK 0xFFF In file included from ./arch/x86/include/asm/irqflags.h:5:0, from ./include/linux/irqflags.h:16, from ./include/linux/rcupdate.h:39, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from ./include/linux/binfmts.h:5, from /tmp/modconfig-pnr90z/vmmon-only/linux/hostif.c:32: ./arch/x86/include/asm/processor-flags.h:39:0: note: this is the location of the previous definition #define CR3_PCID_MASK 0xFFFull In file included from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm_x86.h:41:0, from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm_x86_64.h:40, from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm.h:46, from /tmp/modconfig-pnr90z/vmmon-only/linux/driver.c:49: /tmp/modconfig-pnr90z/vmmon-only/./include/x86_basic_defs.h:78:0: warning: "CR3_PCID_MASK" redefined #define CR3_PCID_MASK 0xFFF In file included from ./arch/x86/include/asm/processor.h:5:0, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/spinlock.h:51, from ./include/linux/wait.h:9, from ./include/linux/wait_bit.h:8, from ./include/linux/fs.h:6, from ./include/linux/highmem.h:5, from /tmp/modconfig-pnr90z/vmmon-only/linux/driver.c:25: ./arch/x86/include/asm/processor-flags.h:39:0: note: this is the location of the previous definition #define CR3_PCID_MASK 0xFFFull /tmp/modconfig-pnr90z/vmmon-only/linux/driver.c:981:1: warning: always_inline function might not be inlinable [-Wattributes] LinuxDriverSyncReadTSCs(uint64 *delta) // OUT: TSC max - TSC min ^~~~~~~~~~~~~~~~~~~~~~~ CC [M] /tmp/modconfig-pnr90z/vmmon-only/common/cpuid.o /tmp/modconfig-pnr90z/vmmon-only/linux/hostif.c: In function ‘HostIF_EstimateLockedPageLimit’: /tmp/modconfig-pnr90z/vmmon-only/linux/hostif.c:1519:31: error: implicit declaration of function ‘global_page_state’; did you mean ‘global_numa_state’? [-Werror=implicit-function-declaration] unsigned int lockedPages = global_page_state(NR_PAGETABLE) + ^~~~~~~~~~~~~~~~~ global_numa_state In file included from /tmp/modconfig-pnr90z/vmmon-only/common/vmx86.h:32:0, from /tmp/modconfig-pnr90z/vmmon-only/common/vmx86.c:43: /tmp/modconfig-pnr90z/vmmon-only/./include/x86msr.h:115:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x140 In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/rcupdate.h:40, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from /tmp/modconfig-pnr90z/vmmon-only/common/vmx86.c:31: ./arch/x86/include/asm/msr-index.h:572:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x00000140 In file included from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm_x86.h:41:0, from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm_x86_64.h:40, from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm.h:46, from /tmp/modconfig-pnr90z/vmmon-only/common/vmx86.c:46: /tmp/modconfig-pnr90z/vmmon-only/./include/x86_basic_defs.h:78:0: warning: "CR3_PCID_MASK" redefined #define CR3_PCID_MASK 0xFFF In file included from ./arch/x86/include/asm/irqflags.h:5:0, from ./include/linux/irqflags.h:16, from ./include/linux/rcupdate.h:39, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from /tmp/modconfig-pnr90z/vmmon-only/common/vmx86.c:31: ./arch/x86/include/asm/processor-flags.h:39:0: note: this is the location of the previous definition #define CR3_PCID_MASK 0xFFFull CC [M] /tmp/modconfig-pnr90z/vmmon-only/common/task.o CC [M] /tmp/modconfig-pnr90z/vmmon-only/common/comport.o In file included from ./arch/x86/include/asm/processor.h:5:0, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/spinlock.h:51, from ./arch/x86/include/asm/mmu.h:5, from ./arch/x86/include/asm/desc.h:7, from /tmp/modconfig-pnr90z/vmmon-only/common/task.c:70: ./arch/x86/include/asm/processor-flags.h:39:0: warning: "CR3_PCID_MASK" redefined #define CR3_PCID_MASK 0xFFFull In file included from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm_x86.h:41:0, from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm_x86_64.h:40, from /tmp/modconfig-pnr90z/vmmon-only/./include/vm_asm.h:46, from /tmp/modconfig-pnr90z/vmmon-only/common/task.c:53: /tmp/modconfig-pnr90z/vmmon-only/./include/x86_basic_defs.h:78:0: note: this is the location of the previous definition #define CR3_PCID_MASK 0xFFF In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/spinlock.h:51, from ./arch/x86/include/asm/mmu.h:5, from ./arch/x86/include/asm/desc.h:7, from /tmp/modconfig-pnr90z/vmmon-only/common/task.c:70: ./arch/x86/include/asm/msr-index.h:572:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x00000140 In file included from /tmp/modconfig-pnr90z/vmmon-only/common/vmx86.h:32:0, from /tmp/modconfig-pnr90z/vmmon-only/common/task.c:51: /tmp/modconfig-pnr90z/vmmon-only/./include/x86msr.h:115:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x140 CC [M] /tmp/modconfig-pnr90z/vmmon-only/common/phystrack.o /tmp/modconfig-pnr90z/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Free() falls through to next function PhysTrack_Add() /tmp/modconfig-pnr90z/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Add() falls through to next function PhysTrack_Remove() /tmp/modconfig-pnr90z/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Remove() falls through to next function PhysTrack_Test() CC [M] /tmp/modconfig-pnr90z/vmmon-only/vmcore/moduleloop.o cc1: some warnings being treated as errors make[2]: *** [scripts/Makefile.build:315: /tmp/modconfig-pnr90z/vmmon-only/linux/hostif.o] Błąd 1 make[2]: *** Oczekiwanie na niezakończone zadania.... /tmp/modconfig-pnr90z/vmmon-only/common/vmx86.o: warning: objtool: Vmx86EnableHVOnCPU() falls through to next function Vmx86GetMSR() In file included from /tmp/modconfig-pnr90z/vmmon-only/./common/vmx86.h:32:0, from /tmp/modconfig-pnr90z/vmmon-only/vmcore/moduleloop.c:35: /tmp/modconfig-pnr90z/vmmon-only/./include/x86msr.h:115:0: warning: "MSR_MISC_FEATURES_ENABLES" redefined #define MSR_MISC_FEATURES_ENABLES 0x140 In file included from ./arch/x86/include/asm/msr.h:5:0, from ./arch/x86/include/asm/processor.h:21, from ./arch/x86/include/asm/cpufeature.h:5, from ./arch/x86/include/asm/thread_info.h:53, from ./include/linux/thread_info.h:38, from ./arch/x86/include/asm/preempt.h:7, from ./include/linux/preempt.h:81, from ./include/linux/rcupdate.h:40, from ./include/linux/rculist.h:11, from ./include/linux/pid.h:5, from ./include/linux/sched.h:14, from /tmp/modconfig-pnr90z/vmmon-only/vmcore/moduleloop.c:31: ./arch/x86/include/asm/msr-index.h:572:0: note: this is the location of the previous definition #define MSR_MISC_FEATURES_ENABLES 0x00000140 /tmp/modconfig-pnr90z/vmmon-only/common/task.o: warning: objtool: .text: unexpected end of section make[1]: *** [Makefile:1507: _module_/tmp/modconfig-pnr90z/vmmon-only] Błąd 2 make[1]: Opuszczenie katalogu '/usr/src/kernels/4.14.3-300.fc27.x86_64' make: *** [Makefile:110: vmmon.ko] Błąd 2 make: Opuszczenie katalogu '/tmp/modconfig-pnr90z/vmmon-only' Uruchamianie vmware (przez systemctl): Job for vmware.service failed because the control process exited with error code. See "systemctl status vmware.service" and "journalctl -xe" for details. [NIEUDANE] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
DEMON Napisano Grudzień 14, 2017 Zgłoszenie Share Napisano Grudzień 14, 2017 Nie wiem nie znam się ale może coś da ale problem jest vhyba bardziej złożony z tego co czytam na zagranicznych forach. dnf install kernel-headers-`uname -r` Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Grudzień 14, 2017 Autor Zgłoszenie Share Napisano Grudzień 14, 2017 21 minut temu, DEMON napisał: Nie wiem nie znam się ale może coś da ale problem jest vhyba bardziej złożony z tego co czytam na zagranicznych forach. dnf install kernel-headers-`uname -r` Niestety wszystko już miałem sudo dnf install kernel-headers-`uname -r` Ostatnio sprawdzono ważność metadanych: 2:20:32 temu w dniu czw, 14 gru 2017, 17:15:22. Pakiet kernel-headers-4.14.3-300.fc27.x86_64 jest już zainstalowany, pomijanie. Rozwiązano zależności. Nie ma nic do zrobienia. Ukończono. [alastis@localhost ~]$ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Grudzień 14, 2017 Zgłoszenie Share Napisano Grudzień 14, 2017 Sprawdź czy masz też pakiet kernel-devel. Ja muszę mieć ten pakiet do kompilacji sterowników VirtualBox, więc być może Vmware Player też tak ma. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Grudzień 14, 2017 Autor Zgłoszenie Share Napisano Grudzień 14, 2017 1 godzinę temu, WalDo napisał: Sprawdź czy masz też pakiet kernel-devel. Ja muszę mieć ten pakiet do kompilacji sterowników VirtualBox, więc być może Vmware Player też tak ma. Wszystko jest: [alastis@localhost ~]$ sudo dnf install kernel-devel Ostatnio sprawdzono ważność metadanych: 0:59:56 temu w dniu czw, 14 gru 2017, 20:18:26. Pakiet kernel-devel-4.13.16-302.fc27.x86_64 jest już zainstalowany, pomijanie. Pakiet kernel-devel-4.14.3-300.fc27.x86_64 jest już zainstalowany, pomijanie. Rozwiązano zależności. Nie ma nic do zrobienia. Ukończono. [alastis@localhost ~]$ VirtualBox i Qemu działają niestety Vmware Player ma problem sprawdzałem na innych forach taki problem ale dotyczy on zwykle Ubuntu i innego kernela wiec nie wiem czy próbować. Przyczyną problemu jest kernel 4.14 na 4.13 uruchomił się Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Grudzień 14, 2017 Zgłoszenie Share Napisano Grudzień 14, 2017 No jeśli masz 4.14 to kernel--devel 4.13 nie pomoże. Musisz mieć 4.14. Dziwne. Na jakim kernelu jesteś jak instalujesz/aktualizujesz kernel-devel? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Grudzień 14, 2017 Autor Zgłoszenie Share Napisano Grudzień 14, 2017 4 minuty temu, WalDo napisał: No jeśli masz 4.14 to kernel--devel 4.13 nie pomoże. Musisz mieć 4.14. Dziwne. Na jakim kernelu jesteś jak instalujesz/aktualizujesz kernel-devel? Teraz dopiero zauważyłem miałem 4.13.16-302.fc27.x86_64 i system mi się zaktualizował do 4.14 korzystam na co dzień z 4.14 ale teraz widz systemie śmietnik. Instaluje nowe a stare zostawia nieużywane. Może vmware po prostu nie wie z którego korzystać chociaż to bez sensu... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Grudzień 14, 2017 Autor Zgłoszenie Share Napisano Grudzień 14, 2017 2 godziny temu, alastis napisał: Teraz dopiero zauważyłem miałem 4.13.16-302.fc27.x86_64 i system mi się zaktualizował do 4.14 korzystam na co dzień z 4.14 ale teraz widz systemie śmietnik. Instaluje nowe a stare zostawia nieużywane. Może vmware po prostu nie wie z którego korzystać chociaż to bez sensu... Wywaliłem wszystko, zostawiłem 4.14 z kernel headers i kernel devel ale niestety nie rusza [alastis@localhost ~]$ sudo dnf install kernel-headers-`uname -r` Ostatnio sprawdzono ważność metadanych: 1:32:48 temu w dniu czw, 14 gru 2017, 23:24:04. Pakiet kernel-headers-4.14.3-300.fc27.x86_64 jest już zainstalowany, pomijanie. Rozwiązano zależności. Nie ma nic do zrobienia. Ukończono. [alastis@localhost ~]$ sudo dnf install kernel-devel Ostatnio sprawdzono ważność metadanych: 1:32:59 temu w dniu czw, 14 gru 2017, 23:24:04. Pakiet kernel-devel-4.14.3-300.fc27.x86_64 jest już zainstalowany, pomijanie. Rozwiązano zależności. Nie ma nic do zrobienia. Ukończono. [alastis@localhost ~]$ uname -r 4.14.3-300.fc27.x86_64 [alastis@localhost ~]$ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
alastis Napisano Grudzień 18, 2017 Autor Zgłoszenie Share Napisano Grudzień 18, 2017 Problem rozwiązany, przyczyną jest kernel 4.14, który nie jest jeszcze wspierany przez Vmvare na 4.13 wszystko działa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
