Yum
MohSETH
Problem zwiazany jest z Yum wczesniej piknie wszystko chodzilo a teraz jak daje yum install cos tam to wyskakuje
You have enabled checking of packages via GPG keys. This is a good thing.
However, you do not have any GPG public keys installed. You need to download
the keys for packages you wish to install and install them.
You can do that by running the command:
rpm --import public.gpg.key
For more information contact your distribution or package provider.
i nie wiem o co chozii...
a jak daje
to jakas lipa tesh wyskakuje:
error: public.gpg.key: import read failed.
Prosze o pomoc
zainstaluj sobie
freshrpms-release-1-1.1.fc3.rf.noarch.rpm
Nie musisz tego instalować (czymkolwiek to jest)!
Wpisz to w terminalu (jako root):
rpm --import /usr/share/doc/fedora-release-3/RPM-GPG-KEY*
oraz np.
rpm --import http://www.fedora.us/FEDORA-GPG-KEY
dla fedora.us
rpm --import http://rpm.livna.org/RPM-LIVNA-GPG-KEY
dla rpm.livna.org
rpm --import http://freshrpms.net/packages/RPM-GPG-KEY.txt
dla freshrpms.net
rpm --import http://dag.wieers.com/packages/RPM-GPG-KEY.dag.txt
dla DAGa
