madamus Napisano Październik 18, 2024 Zgłoszenie Share Napisano Październik 18, 2024 Witam Potrzebuje pomocy w konfiguracji firewalld. Od razu powiem że nie mam doświadczenia. Domyślnie firewalld na routerze jest jedna strefa public do której sa przypisane dwa interfejsy. To działało jako router. Na interfejsie enp0s3 działa dhcp, mam też zrobione przekierowanie ssh do niktórych komputerów w sieci lan . # firewall-cmd --get-active-zones public interfaces: enp0s3 enp0s8 # firewall-cmd --list-all public (active) target: default icmp-block-inversion: no interfaces: enp0s3 enp0s8 sources: services: cockpit dhcpv6-client ssh ports: protocols: forward: yes masquerade: yes forward-ports: port=2222:proto=tcp:toport=22:toaddr=192.168.10.10 source-ports: icmp-blocks: rich rules: Chciałem aby interfejs enp0s8 obsługiwała strefa public a enp0s3 strefa "internal". # firewall-cmd --zone=public --change-interface=enp0s8 --permanent The interface is under control of NetworkManager, setting zone to 'public'. success # firewall-cmd --zone=internal --change-interface=enp0s3 --permanent The interface is under control of NetworkManager, setting zone to 'internal'. success # firewall-cmd --zone=internal --add-forward --permanent success # firewall-cmd --runtime-to-permanent success # firewall-cmd --reload success # firewall-cmd --get-active-zones internal interfaces: enp0s3 public interfaces: enp0s8 # firewall-cmd --zone=public --list-all public (active) target: default icmp-block-inversion: no interfaces: enp0s8 sources: services: cockpit dhcpv6-client ssh ports: protocols: forward: yes masquerade: yes forward-ports: port=2222:proto=tcp:toport=22:toaddr=192.168.10.10 source-ports: icmp-blocks: rich rules: # firewall-cmd --zone=internal --list-all internal (active) target: default icmp-block-inversion: no interfaces: enp0s3 sources: services: cockpit dhcpv6-client mdns samba-client ssh ports: protocols: forward: yes masquerade: no forward-ports: source-ports: icmp-blocks: rich rules: Nie mogę sobie poradzić z skonfigrowaniem udostępnienia internetu w sieci LAN. Nie ida też pingi z sieci lan do np: 8.8.8.8 ani po nazwie domenowej. # sysctl -w net.ipv4.ip_forward=1 # ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. From 192.168.10.1 icmp_seq=1 Packet filtered From 192.168.10.1 icmp_seq=2 Packet filtered Z tego co widze to target w "internal" jest ustawiony na default. Jak zmienię na "accept" to net i wszystko inne działa ale nie o to mi chodzi. Chciałbym rozwiązać przyczynę przy polityce "default". Czy moge liczyć na pomoc? Pozdrawiam ma Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SeeM Napisano Październik 18, 2024 Zgłoszenie Share Napisano Październik 18, 2024 Jeżeli to nie było przez Ciebie konfigurowane od zera, to warto przejrzeć nie tylko strefy. Firewalld ma również firewall-cmd --info-policy które są rozciągnięte na wiele stref. Warto przejrzeć katalog firewalld w /etc oraz historię basha. Wówczas szybko znajdziesz, co tam jest skonfigurowane. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
