butek Napisano Luty 12, 2005 Zgłoszenie Share Napisano Luty 12, 2005 Mam 1 komputer o adresie 192.168.0.1 (stacjionarny- nazwa) Squid działa bo jak wyłącze go to przeglądarka nie widzi stron ale nie ma blokady stron Co robić Oto mój squid.conf # # NETWORK OPTIONS # ----------------------------------------------------------------------------- iptables -t nat -A PREROTUING -i eth1 -p tcp --dport 80 -j REDIRECT --to-port 8080 http_port 8080 icp_port 3130 # ACCESS CONTROLS # ----------------------------------------------------------------------------- # # #Examples: #acl myexample dst_as 1241 #acl password proxy_auth 300 # #Defaults: acl fedora src 192.168.0.1/255.255.255.0 acl sex urlpath_regex "sex." acl randki dstdomain randki.interia.pl acl all src 192.168.0.0/24 acl manager proto cache_object acl localhost src 127.0.0.1/255.255.255.255 acl SSL_ports port 443 563 acl Safe_ports port 80 21 443 563 70 210 1025-65535 acl porn url_regex "/etc/squid/porn" acl nopo url_regex "/etc/squid/nopo" acl CONNECT method CONNECT acl localnet src 192.168.0.0/2 83.31.47.13 #acl zakaz url_regex porno sex laski http_access allow nopo all http_access deny porn all http_access deny sex http_access deny randki http_access allow all localhost http_access allow localnet http_access deny all # TAG: icp_access # Reply to all ICP queries we receive # icp_access allow all #visible_hostname www-cache.foo.org visible_hostname stacjonarny httpd_accel_host virtual httpd_accel_port 80 # TAG: httpd_accel_with_proxy on|off # If you want to use Squid as both a local httpd accelerator # and as a proxy, change this to 'on'. # httpd_accel_with_proxy on iptables -t nat -A PREROTUING -i eth1 -p tcp --dport 80 -j REDIRECT --to-port 8080 http_port 8080 # #Default configuration: #http_access deny zakaz http_access allow manager localhost http_access deny manager http_access deny !Safe_ports http_access deny CONNECT !SSL_ports # # INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS # http_access allow all localhost http_access allow localnet http_access deny all # #visible_hostname www-cache.foo.org visible_hostname stacjonarny Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ati Napisano Luty 12, 2005 Zgłoszenie Share Napisano Luty 12, 2005 Nie rozumiem Twojego problemu ??!!!! Wytłumacz jeszcze raz o co Ci chodzi i z czym masz problem . Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
MrReal Napisano Luty 12, 2005 Zgłoszenie Share Napisano Luty 12, 2005 Też nie rozumiem za bardzo pytania Może ustaw w przeglądarce połączenie bezpośrdnie a nie przez proxy (?) I jak wyłączasz proxy to wyłączaj przekierowanie na niego Czyli skasuj to iptables -t nat -A PREROTUING -i eth1 -p tcp --dport 80 -j REDIRECT --to-port 8080 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@WalDo Napisano Luty 12, 2005 Zgłoszenie Share Napisano Luty 12, 2005 Mnie to się wydaje, że butek chciał chyba ograniczyć dostęp do stron porno. Ja bym się na Twoim miejscu butek przyjrzał dokładniej zawartości i strukturze plików /etc/squid/porn, nopo itd. Ale najlepiej to by było, gdybyś jednak napisał co chcesz osiągnąć. Pozdr, W. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
butek Napisano Luty 12, 2005 Autor Zgłoszenie Share Napisano Luty 12, 2005 Chce blokować strony porno W plikach porn i nopo są pojedyńcza słowa typu sex - są to pliki tekstowe Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
