Bitchx
gudri
Witam wszystkich
Otuz mam problem z instalacja BitchX-a na Fc3 . (wersja klienta 1.0c19 )
Daje ./configure jest OK
Daje make jest pelno ostrzezen i na koniec to: cc -I. -I/usr/src/BitchX/include -I../include -I. -I./include -O2 -Wall -g -c stack.c
gcc -I. -I/usr/src/BitchX/include -I../include -I. -I./include -O2 -Wall -g -c status.c
status.c:1227:1: pasting "status_user0" and "(" does not give a valid preprocessing token
status.c:1228:1: pasting "status_user1" and "(" does not give a valid preprocessing token
status.c:1229:1: pasting "status_user2" and "(" does not give a valid preprocessing token
status.c:1230:1: pasting "status_user3" and "(" does not give a valid preprocessing token
status.c:1231:1: pasting "status_user4" and "(" does not give a valid preprocessing token
status.c:1232:1: pasting "status_user5" and "(" does not give a valid preprocessing token
status.c:1233:1: pasting "status_user6" and "(" does not give a valid preprocessing token
status.c:1234:1: pasting "status_user7" and "(" does not give a valid preprocessing token
status.c:1235:1: pasting "status_user8" and "(" does not give a valid preprocessing token
status.c:1236:1: pasting "status_user9" and "(" does not give a valid preprocessing token
status.c:1237:1: pasting "status_user10" and "(" does not give a valid preprocessing token
status.c:1238:1: pasting "status_user11" and "(" does not give a valid preprocessing token
status.c:1239:1: pasting "status_user12" and "(" does not give a valid preprocessing token
status.c:1240:1: pasting "status_user13" and "(" does not give a valid preprocessing token
status.c:1241:1: pasting "status_user14" and "(" does not give a valid preprocessing token
status.c:1242:1: pasting "status_user15" and "(" does not give a valid preprocessing token
status.c:1243:1: pasting "status_user16" and "(" does not give a valid preprocessing token
status.c:1244:1: pasting "status_user17" and "(" does not give a valid preprocessing token
status.c:1245:1: pasting "status_user18" and "(" does not give a valid preprocessing token
status.c:1246:1: pasting "status_user19" and "(" does not give a valid preprocessing token
gmake[1]: *** [status.o] Błąd 1
gmake[1]: Leaving directory `/usr/src/BitchX/source'
gmake: *** [bitchX] Błąd 2
[root@komputerQ BitchX]# o co tu chodzi?
Czy mam wymienioni GCC? wczesniej wychodzi cos takiego:
gmake[1]: Entering directory `/usr/src/BitchX/source'
gcc -I. -I/usr/src/BitchX/include -I../include -I. -I./include -O2 -Wall -g \
-DDEFAULT_HELP_PATH=\"/usr/local/lib/bx/help\" -c ./help.c
-DIRCLIB=\"/usr/local/lib/bx\" -DIRCPATH=\"~/.BitchX:~/.BitchX/plugins:.:/usr/local/lib/bx/plugins:/usr/local/lib/bx/script:/usr/local/lib/bx\" -c ./irc.c
-DIRCLIB=\"/usr/local/lib/bx\" -DSHLIB_SUFFIX=\".so\" -c ./ircaux.c
-DPLUGINDIR=\"/usr/local/lib/bx/plugins\" -DSHLIB_SUFFIX=\".so\" -c ./modules.c
-DSCRIPT_PATH=\"/usr/local/lib/bx/script\" -c ./notice.c
-DWSERV_PATH=\"/usr/local/lib/bx/wserv\" -c ./screen.c
./screen.c: In function `BX_prepare_display':
./screen.c:419: warning: dereferencing type-punned pointer will break strict-aliasing rules
./screen.c:647: warning: dereferencing type-punned pointer will break strict-aliasing rules
./screen.c: In function `BX_strip_ansi':
./screen.c:2343: warning: dereferencing type-punned pointer will break strict-aliasing rules
./screen.c:2650: warning: dereferencing type-punned pointer will break strict-aliasing rules
i tak nic nie kapuje...
