Błąd Przy Kompilacji Kdebase!
Gryhild
Witam!!
Przy kompilacji kdebase z src.rpm dostaje taki śmiesznawy komunikat :
Good - your configure finished. Start make now
+ make
cd . && /bin/sh /home/gryhild/rpmbuild/BUILD/kdebase-3.4.0/admin/missing --run autoheader
touch ./config.h.in
cd . && /bin/sh ./config.status config.h
config.status: creating config.h
config.status: config.h is unchanged
make all-recursive
make[1]: Entering directory `/home/gryhild/rpmbuild/BUILD/kdebase-3.4.0'
Making all in libkonq
make[2]: Entering directory `/home/gryhild/rpmbuild/BUILD/kdebase-3.4.0/libkonq'
Making all in pics
make[3]: Entering directory `/home/gryhild/rpmbuild/BUILD/kdebase-3.4.0/libkonq/pics'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/gryhild/rpmbuild/BUILD/kdebase-3.4.0/libkonq/pics'
Making all in favicons
make[3]: Entering directory `/home/gryhild/rpmbuild/BUILD/kdebase-3.4.0/libkonq/favicons'
/usr/lib/qt-3.3/bin/moc ./favicons.h -o favicons.moc
if /bin/sh ../../libtool --silent --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I/usr/include/kde -I/usr/lib/qt-3.3/include -I/usr/X11R6/include -DQT_THREAD_SUPPORT -D_REENTRANT -D_FILE_OFFSET_BITS=64 -Wnon-virtual-dtor -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -Wwrite-strings -DNDEBUG -DNO_DEBUG -O2 -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new-fno-common -fno-exceptions -fno-check-new -fno-common -fvisibility=hidden -fvisibility-inlines-hidden -DQT_CLEAN_NAMESPACE -DQT_NO_ASCII_CAST -DQT_NO_STL -DQT_NO_COMPAT -DQT_NO_TRANSLATION -D_GNU_SOURCE -MT favicons.lo -MD -MP -MF ".deps/favicons.Tpo" \
-c -o favicons.lo `test -f 'favicons.cpp' || echo './'`favicons.cpp; \
then mv -f ".deps/favicons.Tpo" ".deps/favicons.Plo"; \
else rm -f ".deps/favicons.Tpo"; exit 1; \
fi
favicons.cpp:269: error: visibility arg must be one of "default", "hidden", "protected" or "internal"
make[3]: *** [favicons.lo] Error 1
make[3]: Leaving directory `/home/gryhild/rpmbuild/BUILD/kdebase-3.4.0/libkonq/favicons'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/gryhild/rpmbuild/BUILD/kdebase-3.4.0/libkonq'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/gryhild/rpmbuild/BUILD/kdebase-3.4.0'
make: *** [all] Error 2
błąd: Błędny status wyjścia z /var/tmp/rpm-tmp.86134 (%build)
Błędy budowania RPM-a:
[gryhild@localhost SRPMS]$
No i wygląda na to że już sobie nie pokompiluje kde 3.4 !! :(:(
Czy może jednak da się z tym coś zrobić ??
Będe wdzięczny za pomoc!!
POZDRAWIAM
GRYHILD
No i przy kompilacji kdeedu-3.4.0 dostaje posobny wynik!! Tylko qt się skompilowało :(
Edytowane przez Gryhild
Spróbuj może paczek src.rpm z Rawhide'a. Jest tam zamieszczony tymczasowo ten patch → http://cvs.fedora.redhat.com/viewcvs/devel...isibility.patch Z tego co się kiedyś pytałem na fedora-devel-list, to z opcjami "-fvisibility=hidden -fvisibility-inlines-hidden" były jeszcze jakieś kłopoty i musieli je wyłączyć.
Znów wypowiem się na temat kompilacji. I po co?? Czy ten 1-2 procent cię zbawi?? Czy naprawdę narto psuć sobie system jakimiś niestebilnie skompilowanymi paczkami?? Fedora przecież wprowadza trochę udoskonaleń do swoich paczek. Więc po co wszystko psuć? Jeśli naprawdę zależy ci na szybkości to wgraj sobie VidaLinuksa na początek i kompiluj, kompiluj i kompiluj :)
Kompilacja => VidaLinux => To forum VLOS Polska
