marcin118 Napisano Kwiecień 22, 2005 Zgłoszenie Share Napisano Kwiecień 22, 2005 enter1: ale tobie udalo sie to zrobic z ppp0 czy pppoe ?????????? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ebnowak Napisano Kwiecień 23, 2005 Zgłoszenie Share Napisano Kwiecień 23, 2005 Potrzebana pomoc ? Jeżeli tak to proszę o wykonanie: # cat /var/log/messages | grep ppp | tail -20 # cat /var/log/messages | grep firmware | tail -4 Mam pytanie czy wykonałeś punkty z postu: Net24 Z Netii I Fc3 (to ten "wątek") Post: 16.04.2005 - 09:39 ??? Pozdrawiam. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcin118 Napisano Kwiecień 23, 2005 Zgłoszenie Share Napisano Kwiecień 23, 2005 no bardzo przydalaby mi sie pomoc a wiec tak cat /var/log/messages | grep ppp | tail -20 Apr 23 20:25:46 localhost pppd[4746]: remote IP address 10.112.112.113 Apr 23 20:25:49 localhost pppd[4746]: Starting link Apr 23 20:25:49 localhost pppd[4746]: Connect: ppp0 <--> 8.35 Apr 23 20:25:49 localhost pppd[4746]: Couldn't increase MTU to 1500. Using 1492 Apr 23 20:25:49 localhost pppd[4746]: Couldn't increase MRU to 1500. Using 1492 Apr 23 20:25:51 localhost wait_for_sysfs[4656]: either wait_for_sysfs (udev 039) needs an update to handle the device '/class/ppp' properly (class specific file unavailable) or the sysfs-support of your device's driver needs to be fixed, please report to <[email protected]> Apr 23 20:26:20 localhost pppd[4746]: LCP: timeout sending Config-Requests Apr 23 20:26:20 localhost pppd[4746]: Connection terminated. Apr 23 20:26:53 localhost pppd[4746]: Starting link Apr 23 20:26:53 localhost pppd[4746]: Connect: ppp0 <--> 8.35 Apr 23 20:26:53 localhost pppd[4746]: Couldn't increase MTU to 1500. Using 1492 Apr 23 20:26:53 localhost pppd[4746]: Couldn't increase MRU to 1500. Using 1492 Apr 23 20:27:23 localhost pppd[4746]: LCP: timeout sending Config-Requests Apr 23 20:27:23 localhost pppd[4746]: Connection terminated. Apr 23 20:27:57 localhost pppd[4746]: Starting link Apr 23 20:27:57 localhost pppd[4746]: Connect: ppp0 <--> 8.35 Apr 23 20:27:57 localhost pppd[4746]: Couldn't increase MTU to 1500. Using 1492 Apr 23 20:27:57 localhost pppd[4746]: Couldn't increase MRU to 1500. Using 1492 Apr 23 20:28:27 localhost pppd[4746]: LCP: timeout sending Config-Requests Apr 23 20:28:27 localhost pppd[4746]: Connection terminated. to wyniki drugiej komendy Apr 23 20:09:53 localhost kernel: usb 2-2: found stage 1 firmware speedtch-1.binApr 23 20:09:53 localhost kernel: usb 2-2: found stage 2 firmware speedtch-2.binApr 23 20:25:49 localhost kernel: usb 2-2: found stage 1 firmware speedtch-1.binApr 23 20:25:49 localhost kernel: usb 2-2: found stage 2 firmware speedtch-2.bin cat /proc/net/atm/speedtch:0 Speed Touch 330 (usb-0000:00:10.0-2) MAC: 00:0e:50:1a:95:86 AAL5: tx 30 ( 0 err ), rx 0 ( 0 err, 0 drop ) Line up, firmware loaded /etc/sysconfig/network-scripts/ifcfg-ppp0 PEERDNS=yes TYPE=xDSL DEVICE=ppp0 BOOTPROTO=dialup PIDFILE=/var/run/pppoa-adsl.pid LCP_FAILURE=86400 LCP_INTERVAL=1 CONNECT_POLL=6 CONNECT_TIMEOUT=604800 SYNCHRONOUS=no DEFROUTE=yes [email protected] VPI=8 VCI=35 LINUX_PLUGIN=pppoatm.so DEMAND=yes /etc/ppp/pap-secrets i chap-secrets # Secrets for authentication using PAP # client server secret IP addresses "[email protected]" "*" "xxxxxxxx" "*" ~ ~ Aha dodam jeszcze, ze w network device control nie ma nic z gory dzieki za pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
enter1 Napisano Kwiecień 24, 2005 Autor Zgłoszenie Share Napisano Kwiecień 24, 2005 Witam Tu masz moje chap-secrets, ifcfg-ppp0 i pap-secrets (W miejsce x-ów wstaw swoje login i hasło): chap-secrets: # Secrets for authentication using CHAP # client server secret IP addresses "[email protected]" * "xxxxxxxx" pap-secrets: # Secrets for authentication using PAP # client server secret IP addresses "[email protected]" * "xxxxxxxx" ifcfg-ppp0: PEERDNS=yes MRU=1500 MTU=1500 TYPE=xDSL DEVICE=ppp0 BOOTPROTO=dialup PIDFILE=/var/run/pppoe-adsl.pid LCP_FAILURE=86400 LCP_INTERVAL=1 BR2684DEV=0 CONNECT_POLL=6 CONNECT_TIMEOUT=604800 SYNCHRONOUS=no DEFROUTE=yes USER='[email protected]' VPI=8 VCI=35 LINUX_PLUGIN=rp-pppoe.so DEMAND=yes Sprawdź co masz w tych plikach i w razie czego skoryguj. Sprawdź w biosie typ portu USB (musi być 1.0 lub 1.1) W Network Device Control (używam KDE) mam: Status - Active Device - ppp0 NickName - ppp0 W razie czego dokładnie przestudiuj post http://www.fedora.pl/site/forum/index.php?...indpost&p=25997 Marek Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ebnowak Napisano Kwiecień 25, 2005 Zgłoszenie Share Napisano Kwiecień 25, 2005 Mogę stwierdzic z dużym prawdopodobieństwem, że nie wykonałeś: Net24 Z Netii I Fc3 (to ten "wątek") Post: 16.04.2005 - 09:39 Myślę, że to rozwiązuje problem Pozdrawiam. PS. Odezwij się, czy zadziałało po wykonaniu tego poasta. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcin118 Napisano Kwiecień 25, 2005 Zgłoszenie Share Napisano Kwiecień 25, 2005 ehh zglupialem troche ehh zglupialem troche no wiec dodalem do ifcfg-ppp0 linijki: MRU=1500 MTU=1500 i zmienilem peerdns na yes (vpi=8 mialem juz wczesniej) reboot wchodze w network control device i jest ppp0 (active) mysle sobie no udalo sie ale neta dalej nie ma wiec wykonalem komende # cat /var/log/messages | grep ppp | tail -20 a to sa wyniki: Apr 25 18:05:22 localhost system-config-network[6657]: chmod 0644 //etc/sysconfig/networking/devices/ifcfg-ppp0 Apr 25 18:05:22 localhost system-config-network[6657]: chmod 0644 //etc/sysconfig/networking/devices/ifcfg-ppp0 Apr 25 18:05:23 localhost adsl-stop: Killing pppd Apr 25 18:05:23 localhost pppd[6540]: Terminating on signal 15. Apr 25 18:05:23 localhost pppd[6540]: Exit. Apr 25 18:05:25 localhost pppd[6779]: Plugin pppoatm.so loaded. Apr 25 18:05:25 localhost pppd[6779]: PPPoATM plugin_init Apr 25 18:05:25 localhost pppd[6779]: PPPoATM setdevname_pppoatm - SUCCESS:8.35 Apr 25 18:05:25 localhost pppd[6779]: pppd 2.4.2 started by root, uid 0 Apr 25 18:05:25 localhost pppd[6779]: Using interface ppp0 Apr 25 18:05:25 localhost pppd[6779]: local IP address 10.112.112.112 Apr 25 18:05:25 localhost pppd[6779]: remote IP address 10.112.112.113 Apr 25 18:05:26 localhost pppd[6779]: Starting link Apr 25 18:05:26 localhost pppd[6779]: Connect: ppp0 <--> 8.35 Apr 25 18:05:56 localhost pppd[6779]: LCP: timeout sending Config-Requests Apr 25 18:05:56 localhost pppd[6779]: Connection terminated. Apr 25 18:11:50 localhost pppd[6779]: Starting link Apr 25 18:11:50 localhost pppd[6779]: Connect: ppp0 <--> 8.35 Apr 25 18:12:20 localhost pppd[6779]: LCP: timeout sending Config-Requests Apr 25 18:12:20 localhost pppd[6779]: Connection terminated. jezeli masz jeszcze jakis pomysl to bardzo prosze o napisanie w nastepnyj poscie jesli nie to sprbuje z pppoe pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
enter1 Napisano Kwiecień 26, 2005 Autor Zgłoszenie Share Napisano Kwiecień 26, 2005 Witam Nie czytasz dokładnie postów przecież wszystko jest w: 1. http://www.fedora.pl/site/index.php?option...id=98&Itemid=34 i 2. http://www.fedora.pl/site/forum/index.php?...indpost&p=25997 tam wyraźnie pisze, co zrobić, a w: 3. http://www.fedora.pl/site/forum/index.php?...indpost&p=25953 wyraźnie podałem, że netia posługuje się protokołem ATM - PPPoA Najlepiej zdrukuj sobie te posty i wykonaj dokładnie wszystkie podpunkty. Marek Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcin118 Napisano Kwiecień 29, 2005 Zgłoszenie Share Napisano Kwiecień 29, 2005 udalo sie :):):):) zrobiel wedlug instrukcji ppoe i ladie dziala ale wywalilem wpis /bin/bash z rc.modules bo podczas startu mi sie powloka wlaczala a be tego dziala jedyne co jest nie tak to to ze po restarcie polaczenie jest nie aktywne ale to nie problem jeszcze raz bardzo dzikuje za pomoc i cierpliwosc pozdrowienia Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
enter1 Napisano Maj 1, 2005 Autor Zgłoszenie Share Napisano Maj 1, 2005 Witam Ciesze się, że sobie poradziłeś. Swoją drogą możliwość dochodzenia do samodzielnych rozwiązań stawia (_linuxa_ → Linuksa) ORT bardzo wysoko w moim osobistym rankingu SO. Podnosi wysoko poprzeczkę, a wymaga odrobiny wysiłku i samozaparcia. Daje bardzo dużo satysfakcji z osiągniętego rezultatu i zmusza do ciągłego samokształcenia. Ponadto grupa użytkowników FC jest na tyle życzliwa, że zawsze w przypadku trudnośći można liczyć na czyjąś pomocną dłoń. Jednym słowem COOOL Marek Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
