Yum Conf - Wstawcie Fc 4
estudio
[u]Error: failure: repodata/primary.xml.gz from livna: [Errno 256] No more mirrors to try.[/u]
Albo serwer pada, albo masz zły wpis odnośnie fedora extras. Sprawdź w /etc/yum.repos.d/
ps. czy jest dostepne kadu w fedora extras?
Jeszcze nie → https://bugzilla.redhat.com/bugzilla/show_b...g.cgi?id=165878
/edit/
Tfu, miałem na myśli rpm.livna.org, a nie fedora extras :/
Edytowane przez gajownik
  • Odpowiedzi 47
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
Mam takie wpisy w /etc/yum.repos.d/:
[extras]
name=Fedora Extras $releasever - $basearch
#baseurl=http://download.fedora.redhat.com/pub/fedora/linux/extras/$releasever/$basearch/
mirrorlist=http://fedora.redhat.com/download/mirrors/fedora-extras-$releasever
enabled=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora-extras
gpgcheck=1
[base]
name=Fedora Core $releasever - $basearch - Base
#baseurl=http://download.fedora.redhat.com/pub/fedora/linux/core/$releasever/$basearch/os/
mirrorlist=http://fedora.redhat.com/download/mirrors/fedora-core-$releasever
enabled=1
gpgcheck=1
[livna]
name=Livna.org - Fedora Compatible Packages (stable)
baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.lvn/
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-livna
enabled=1
[livna-testing]
name=Livna.org - Fedora Compatible Packages (testing)
baseurl=http://rpm.livna.org/fedora/$releasever/$basearch/RPMS.lvn-testing
gpgcheck=1
enabled=0
[flash]
name=macromedia.mplug.org - Flash Plugin
baseurl=http://macromedia.mplug.org/rpm
 http://sluglug.ucsc.edu/macromedia/rpm
 http://ruslug.rutgers.edu/macromedia/rpm
 http://macromedia.rediris.es/rpm
enabled=1
gpgcheck=1
gpgkey=http://macromedia.mplug.org/FEDORA-GPG-KEY
[updates-released]
name=Fedora Core $releasever - $basearch - Released Updates
#baseurl=http://download.fedora.redhat.com/pub/fedora/linux/core/updates/$releasever/$basearch/
mirrorlist=http://fedora.redhat.com/download/mirrors/updates-released-fc$releasever
enabled=1
gpgcheck=1
takie mam wpisy, reszta (atrpms, freshrpms, dag, dries,jpackage) jest na enable=0 wiec zakladam, ze nie sa powlaczane. Nie wiem zabardzo co moze byc zle we wpisie (newbie), wiec daje do sprawdzenia :]
[livna]
gpgcheck=1
enabled=1
Wygląda dobrze. Pewnie im serwer siadł. Jak chcesz zapobiec takim problemom w przyszłości, to dodaj sobie jeszcze mirrory. Linijkę baseurl zamień na coś takiego:
      http://livna.cat.pdx.edu/fedora/$releasever/$basearch/RPMS.lvn/
      http://wftp.tu-chemnitz.de/pub/linux/livna/fedora/$releasever/$basearch/RPMS.lvn/
Jak jeden padnie to będzie się dobijac do drugiego, itd. :]
  • 3 weeks later...
Witam.
Na początku zaznaczam, że jestem zielony więc sorry jeśli pytanie już padło albo coś :).
W każdym razie używałem dotychczas FC3 i yum działał jak należy. Zaktualizowałem system do FC4z płyty, ściągnąłem i zainstalowałem livna-release-4-0.lvn.5.4.noarch.rpm z rpm.livna.org i teraz yum już nie działa ;). Cokolwiek próbuję zainstalować dostaję coś takiego:
Repository extras already added, not adding again
Repository livna already added, not adding again
Repository livna-testing already added, not adding again
Setting up Install Process
Setting up repositories
livna                     100% |=========================|  951 B    00:00
Cannot open/read repomd.xml file for repository: livna-stable
failure: repodata/repomd.xml from livna-stable: [Errno 256] No more mirrors to try.
Sorry ale nie bardzo orientuję się w tym co trzeba pozmieniać ewentualnie w tych plikach konfiguracyjnych o których pisaliście powyżej, więc jeżeli ktoś zna rozwiązanie tego problemu to byłbym dźwięczny za wyjaśnienie mi tego krok po kroku jak ciemniakowi :)...
[Edit]
Dobra znalazłem rozwiązanie tutaj
http://www.fedorafaq.org/#installsoftware
, sorry za zamieszanie :).
zrobilem prawe wszystko jak pisaliście edytowałem te wszytkie pliki ale mam pytanko:
Jaką komende należy wydąć, żeby zaktualizować te listy... czy może siię ich nie akutualizuje ??
Wklepałem coś takiego:
[root@localhost grs]# yum install mplayer
a to lista wszytkich rzeczy jakie mi zainstalował.
fribidi lame aalib libmad libdvdcss libdvdread portaudio lirc lzo xvidcore directfb mikmod xmms faad2 mplayer-fonts mplayer
Kapuje reszte ale dlaczego zainstalował xmms ??
poza tym jakieś stare te rzeczy. Mpalyer w wesji 1.0-0.lvn.7.... czy jakoś tak :P
AAA i jeszcz gdzie dodać ten wpis o kadu ?
trzeba zrobić osobny pik jak ten z Macromedia???
Edytowane przez grs_84pl
Po co? Wystarczyło to zrobić tak → http://faq.fedora.pl/#installsoftware
Wszystko działa od razu. Jak wpiszesz obojętnie jakie polecenie, np. yum udpate, to będziesz miał podane z jakich repo ściąga informacje.
Być może został skompilowany z obsługą XMMS-a
  --enable-xmms          build with XMMS inputplugin support
A jaką chcesz wersję? Z CVS-a? W repo jest mplayer-1.0-0.lvn.0.26.pre7try2.4.i386.rpm czyli najnowsza dostęþna.
Tak.
  • 4 months later...
Taki temat już jest → http://www.fedora.pl/site/forum/index.php?...?showtopic=4442 i to do tego jest przypięty!!
Ekspert
Postów: 578
12.11.2004
to nie działa
a lista repozytoriów przypięta na pewnowielu osobom by pomogła
   3. Wykonaj poniższe polecenia, by usunąć plik yum.conf i zastąpić go nowszym (Zaktualizowane 29 lipca 2005):
     cd /etc
     rm -f yum.conf
     wget http://www.fedorafaq.org/samples/yum.conf
  4. Zainstaluj teraz moją konfigurację wykonując to polecenie (Zaktualizowane 25 lipca 2005):
     rpm -Uvh http://www.fedorafaq.org/yum
[root@c181-54 etc]# rpm -Uvh http://www.fedorafag.org/yum
Ściąganie http://www.fedorafag.org/yum
błąd: http://www.fedorafag.org/yum pomijany - transmisja Nieznany lub nieoczekiwany błąd nie powiodła się
rpm: url.c:103: XurlFree: Warunek zapewnienia `u && u->magic == 0xd00b1ed0' nie został spełniony.
Przerwane
I co teraz....
Zbyszek duzy
Ile jeszcze razy będziemy pisać , ze były przenosiny forum
http://www.fedora.pl/forum/index.php?showtopic=4442
trzeba usunąć site z adresu
a dalej co napisałeś , to chodzi chyba o proxy
By dowiedzieć się więcej o yum, przejrzyj
    stronę projektu yum.
    (Podziękowania dla Rona Kurisa za tę poradę.)
By dowiedzieć się jak używać yum przez proxy, zobacz wątek
    na FedoraForum o yum i proxy. (Podziękowania dla Reinharda
    Herzfelda za ten link.)
podobny problem zobacz
http://linux.nfo.sk/viewtopic.php?p=2601&s...bcbe546a52ed68b
  • 2 weeks later...
witam, jesli mam cos takiego:
package-fedora          100% |=========================|  951 B    00:00
freshrpms                100% |=========================|  951 B    00:00
newrpms                  100% |=========================|  951 B    00:00
jpackage-generic          100% |=========================|  951 B    00:00
extras                    100% |=========================| 1.1 kB    00:00
updates-released          100% |=========================|  951 B    00:00
base                      100% |=========================| 1.1 kB    00:00
primary.xml.gz            100% |=========================| 1.0 MB    00:12
extras    : ################################################## 3041/3041
Added 0 new packages, deleted 22 old in 2.72 seconds
primary.xml.gz            100% |=========================| 431 kB    00:06
http://mirror.switch.ch/ftp/mirror/fedora/...primary.xml.gz: [Errno -1] Metadata file does not match checksum
Trying other mirror.
i tak dalej sobie leciał "trying" i wywalał następne mirrory.
to mam sie martwic? niektore pliki sciaga i znajduje ale to nie wiem co oznacza smile.gif repozytoria rozszerzone zgodnie z opisem <nazwa>.repo + klucz w terminalu smile.gif
Aż pewnie trafił na taki z ktorego sobie pobrał to czego szukał, bo inaczej instalacja nie zakończyłaby się sukcesem o czym yum jawnie informuje pisząc coś w rodzaju "no more mirrors to try" albo jakoś tak.
Krótko: nie przejmuj się.
  • 6 months later...
