Yum
Kamills
Poniewaz chcesz poznawac system potrzebna Ci informacje wyciagnij z tego listingu :) :
[root@localhost wojtekjs]# yum remove yum
Loading "installonlyn" plugin
Setting up Remove Process
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package yum.noarch 0:3.0.1-2.fc6 set to be erased
--> Running transaction check
Setting up repositories
livna					 100% |=========================| 1.1 kB	00:00
core					  100% |=========================| 1.1 kB	00:00
updates				   100% |=========================| 1.2 kB	00:00
extras					100% |=========================| 1.1 kB	00:00
primary.xml.gz			100% |=========================| 381 kB	00:06
################################################## 1023/1023
primary.xml.gz			100% |=========================| 1.7 MB	00:29
################################################## 5428/5428
--> Processing Dependency: yum >= 2.9.5 for package: pirut
--> Processing Dependency: yum = 3.0.1-2.fc6 for package: yum-updatesd
--> Restarting Dependency Resolution with new changes.
---> Package pirut.noarch 0:1.2.8-1.fc6 set to be erased
---> Package yum-updatesd.noarch 0:3.0.1-2.fc6 set to be erased
Dependencies Resolved
Package				 Arch	   Version		  Repository		Size
Removing:
yum					 noarch	 3.0.1-2.fc6	  installed		 1.8 M
Removing for dependencies:
pirut				   noarch	 1.2.8-1.fc6	  installed		 934 k
yum-updatesd			noarch	 3.0.1-2.fc6	  installed		 3.9 k
Transaction Summary
Install	  0 Package(s)
Update	   0 Package(s)
Remove	   3 Package(s)
Is this ok [y/N]:
