Upgrade
bunkierek
Przy próbie zrobienia upgrade za pomocą czy to yum, czy up2date pojawia mi się konflikt, który przedstawiam w załączeniu. Jak z tego wybrnąć? Jest to tylko wycinek, nie całość.
Testowanie instalacji nie powiodło się z powodu
konfliktu między pakietami:
file /usr/share/doc/HTML/pl/common/1.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
and kdelibs-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/10.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/2.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/3.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/4.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/5.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/6.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/7.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/8.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/9.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/appheader.html conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/artistic-license.html conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/bottom-left.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/bottom-middle.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/bottom-right.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/bottom1.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/bottom2.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/bsd-license.html conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/docheadergears.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
file /usr/share/doc/HTML/pl/common/doctop1.png conflicts between attempted installs of kde-i18n-Polish-3.4.2-0.fc4.1
ja w trybie tekstowym odinstalowalbym paczke powodujaca problemy:
 # rpm -e kde-i18n-Polish
nastepnie zaktualizowalbym system:
 # yum update
jezeli w trakcie aktualizacji yum nie zainstalowalby tej paczki sam (w ramach zaleznosci) to wydalbym polecenie:
 # yum install kde-i18n-Polish
sposob moze niezbyt elegancki ;) ale powinien byc skuteczny
