lszk Napisano Sierpień 22, 2005 Zgłoszenie Share Napisano Sierpień 22, 2005 Chcąc go odpalić otrzymuje /etc/init.d/mysql start Starting MySQL database server: mysqld...failed. Please take a look at the syslog. /usr/bin/mysqladmin: connect to server at 'localhost' failed error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)' Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists! Zawartość /var/log/syslog Aug 22 21:48:00 debian mysqld_safe[5476]: started Aug 22 21:48:00 debian mysqld[5480]: 050822 21:48:00 InnoDB: Started Aug 22 21:48:00 debian mysqld[5480]: 050822 21:48:00 Fatal error: Can't open privilege tables: Table 'mysql.host' doesn't exist Aug 22 21:48:00 debian mysqld[5480]: 050822 21:48:00 Aborting Aug 22 21:48:00 debian mysqld[5480]: Aug 22 21:48:00 debian mysqld[5480]: 050822 21:48:00 InnoDB: Starting shutdown... Aug 22 21:48:02 debian mysqld[5480]: 050822 21:48:02 InnoDB: Shutdown completed Aug 22 21:48:02 debian mysqld[5480]: 050822 21:48:02 /usr/sbin/mysqld: Shutdown Complete Aug 22 21:48:02 debian mysqld[5480]: Aug 22 21:48:02 debian mysqld_safe[5509]: ended Aug 22 21:48:06 debian /etc/init.d/mysql[5554]: 0 processes alive and '/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping' resulted in Aug 22 21:48:06 debian /etc/init.d/mysql[5554]: ^G/usr/bin/mysqladmin: connect to server at 'localhost' failed Aug 22 21:48:06 debian /etc/init.d/mysql[5554]: error: 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)' Aug 22 21:48:06 debian /etc/init.d/mysql[5554]: Check that mysqld is running and that the socket: '/var/run/mysqld/mysqld.sock' exists! Aug 22 21:48:06 debian /etc/init.d/mysql[5554]: Kurka nie wiem, co zrobić z tą tabelą, której nie znajduje... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@Sorror Napisano Sierpień 23, 2005 Zgłoszenie Share Napisano Sierpień 23, 2005 Po pierwsze sprawdź czy masz uruchomiony daemon mysqld, jeśli tak to: Sprawdź czy nie masz konfliktu, co daje: nmap -Nnap | grep 3306 ? Jeśli nic nie przeszkadza możesz mieć konflikt my.cnf, sprawdź: libexec/mysqld --print-defaults mysqladmin --print-defaults To powinno zawsze działać: mysqladmin --socket=/tmp/mysqld.sock version Ewentualnie może to kwestia chown: chown -R mysql /usr/local/mysql //lub inna sciezka Jeśli dalej nic może restart? /usr/local/mysql/share/mysql.server stop następnie: /usr/local/mysql/share/mysql.server start Jeśli ścieżka się nie zgadza znajdź najpierw mysql.server. Jeśli wywala błędy to pewnie przez brak chmoda: chmod +x /path/to/mysql.server Choć największe prawdopodobieństwo yest takie, że błąd yest w /etc/my.cnf. Sprawdź zgodność: [mysql.server] datadir=/var/lib/mysql socket=/var/lib/mysql/mysql.sock [mysqladmin] socket=/var/lib/mysql/mysql.sock [mysqld] datadir=/var/lib/mysql socket=/var/lib/mysql/mysql.sock [mysql] socket=/var/lib/mysql/mysql.sock Uff, to by było na tyle... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
