cesarz Napisano Sierpień 25, 2005 Zgłoszenie Share Napisano Sierpień 25, 2005 Po zalogowaniu wywala mi pasek i taki błąd: "Program Panel KDE (kicker) uległ awarii, wywołując sygnał 6 (SIGABRT)" "Program zostaje zakończony sygnałem SIGABRT... blabla" W zakładce "ślad blabla" mam takie coś: Using host libthread_db library "/lib/tls/libthread_db.so.1". `shared object read from target memory' has disappeared; keeping its symbols. [Thread debugging using libthread_db enabled] [New Thread -1208871232 (LWP 5662)] [KCrash handler] #4 0xb7f3d402 in __kernel_vsyscall () #5 0x00267955 in raise () from /lib/tls/libc.so.6 #6 0x00269319 in abort () from /lib/tls/libc.so.6 #7 0x006496eb in __gnu_cxx::__verbose_terminate_handler () from /usr/lib/libstdc++.so.6 #8 0x006473fd in __cxa_call_unexpected () from /usr/lib/libstdc++.so.6 #9 0x00647432 in std::terminate () from /usr/lib/libstdc++.so.6 #10 0x0064757b in __cxa_throw () from /usr/lib/libstdc++.so.6 #11 0x006479cc in operator new () from /usr/lib/libstdc++.so.6 #12 0x00647a69 in operator new[] () from /usr/lib/libstdc++.so.6 #13 0x05f0507e in QString::setLength () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #14 0x05f0d519 in operator>> () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #15 0xb7ac48a6 in KlipperWidget::loadHistory () from /usr/lib/kde3/klipper_panelapplet.so #16 0xb7ac55d5 in KlipperWidget::readProperties () from /usr/lib/kde3/klipper_panelapplet.so #17 0xb7ac6ea3 in KlipperWidget::KlipperWidget () from /usr/lib/kde3/klipper_panelapplet.so #18 0xb7ac0d00 in KlipperAppletWidget::KlipperAppletWidget () from /usr/lib/kde3/klipper_panelapplet.so #19 0xb7ac0dfc in KlipperApplet::KlipperApplet () from /usr/lib/kde3/klipper_panelapplet.so #20 0xb7ac0ed0 in init () from /usr/lib/kde3/klipper_panelapplet.so #21 0x04c6c4ce in PluginManager::loadApplet () from /usr/lib/libkdeinit_kicker.so #22 0x04c5f50c in AppletContainer::AppletContainer () from /usr/lib/libkdeinit_kicker.so #23 0x04c6db42 in PluginManager::createAppletContainer () from /usr/lib/libkdeinit_kicker.so #24 0x04c54a48 in ContainerArea::loadContainers () from /usr/lib/libkdeinit_kicker.so #25 0x04c558da in ContainerArea::initialize () from /usr/lib/libkdeinit_kicker.so #26 0x04c736f2 in PanelExtension::populateContainerArea () from /usr/lib/libkdeinit_kicker.so #27 0x04c74822 in PanelExtension::qt_invoke () from /usr/lib/libkdeinit_kicker.so #28 0x05c3c10e in QObject::activate_signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #29 0x05f6ebad in QSignal::signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #30 0x05c54eed in QSignal::activate () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #31 0x05c5c0ff in QSingleShotTimer::event () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #32 0x05bdd539 in QApplication::internalNotify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #33 0x05bdd6ca in QApplication::notify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #34 0x009501e8 in KApplication::notify () from /usr/lib/libkdecore.so.4 #35 0x05bd18ab in QEventLoop::activateTimers () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #36 0x05b8d6fe in QEventLoop::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #37 0x05bf2c8d in QEventLoop::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #38 0x05bdc6ea in QApplication::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #39 0x05bdc715 in QApplication::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #40 0x04c68bc0 in ExtensionManager::initialize () from /usr/lib/libkdeinit_kicker.so #41 0x04c69181 in ExtensionManager::qt_invoke () from /usr/lib/libkdeinit_kicker.so #42 0x05c3c10e in QObject::activate_signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #43 0x05f6ebad in QSignal::signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #44 0x05c54eed in QSignal::activate () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #45 0x05c5c0ff in QSingleShotTimer::event () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #46 0x05bdd539 in QApplication::internalNotify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #47 0x05bdd6ca in QApplication::notify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #48 0x009501e8 in KApplication::notify () from /usr/lib/libkdecore.so.4 #49 0x05bd18ab in QEventLoop::activateTimers () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #50 0x05b8d6fe in QEventLoop::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #51 0x05bf2b85 in QEventLoop::enterLoop () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #52 0x05bf2ade in QEventLoop::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #53 0x05bdc73b in QApplication::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #54 0x04c4c518 in kdemain () from /usr/lib/libkdeinit_kicker.so #55 0xb7f3b6c0 in kdeinitmain () from /usr/lib/kde3/kicker.so #56 0x0804d9f1 in ?? () #57 0x00000001 in ?? () #58 0x09ca5628 in ?? () #59 0x00000001 in ?? () #60 0x00000000 in ?? () Pojęcia nie mam o co chodzi, wszystko działało, zrestartowałem kompa i już nie działało Co dziewniejsze od dwóch dni praktycznie nic nie robiłem przy kompie, korzystałem niego praktycznie godzinke dziennie System to fedora core 3, kernel najnowszy z livny... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
asasyn Napisano Sierpień 25, 2005 Zgłoszenie Share Napisano Sierpień 25, 2005 Masz 2 wyjścia, przynajmniej ja bym tak zrobił 1) Odpal kompa z płyty w trybie rescue i sprawdź system plików 2)Wejdź przez ctrl+alt +F2 do konsoli, zaloguj się jako root i zaktualizuj system yum-em Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
tomcio15 Napisano Sierpień 25, 2005 Zgłoszenie Share Napisano Sierpień 25, 2005 A nie aktualizowales ostatnio glibc? Jezeli tak, to radze zainstalowac glibc z plytki instalacyjnej, powinno pomoc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cesarz Napisano Sierpień 25, 2005 Autor Zgłoszenie Share Napisano Sierpień 25, 2005 Ale sam system działa, nawet pod kde mogę uruchamiać programy, przekładać internet itd. Wywala tylko pasek zadań Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Sierpień 25, 2005 Zgłoszenie Share Napisano Sierpień 25, 2005 Wywala tylko pasek zadań Na koncie nowego użytkownika też? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cesarz Napisano Sierpień 25, 2005 Autor Zgłoszenie Share Napisano Sierpień 25, 2005 Właśnie o to chodzi że wpierw wywałało na roocie na koncie użytkownika było ok. Teraz wywala na obu. Pewnie nowe konto rozwiązało by sprawę ale no wiesz ustawiać wszystko od nowa Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Sierpień 25, 2005 Zgłoszenie Share Napisano Sierpień 25, 2005 czy cos ostatnio instalowales? probowales przeinstalowac cale kde lub je zaktualizowac? z tego co widze problem bedzie sie powtarzal rowniez na nowych uzytkownikach, wiec nie warto uciekac tylko sprobowac rozwiazac Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cesarz Napisano Sierpień 25, 2005 Autor Zgłoszenie Share Napisano Sierpień 25, 2005 Pisałem że przez dwa dni nie prawie korzystałem z kompa. Najwyżej wywalę kde i zainstaluje gnome, ale pewnie wtedy pożagnam się z amarokiem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
asasyn Napisano Sierpień 26, 2005 Zgłoszenie Share Napisano Sierpień 26, 2005 probowales przeinstalowac cale kde lub je zaktualizowac? Dlaczego tego nie zrobisz, kto ci się każe z amarokiem żegnać Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
fraDiavolo Napisano Sierpień 26, 2005 Zgłoszenie Share Napisano Sierpień 26, 2005 Najwyżej wywalę kde i zainstaluje gnome, ale pewnie wtedy pożagnam się z amarokiem Tak źle to nie jest. Amarok bez problemu działa pod GNOME, tylko trzeba mieć Qt. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cesarz Napisano Sierpień 26, 2005 Autor Zgłoszenie Share Napisano Sierpień 26, 2005 Dobre z biedy doinstalowałem xfce4 i tak mi się spodobało że już nie chcę wracać do kde Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Sierpień 26, 2005 Zgłoszenie Share Napisano Sierpień 26, 2005 Dobre z biedy doinstalowałem xfce4 i tak mi się spodobało że już nie chcę wracać do kde cos o tym wiem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
