Inkscape
MitS
Witam!
Mam pewien problem z instalacją Inkscape 0.41, a mianowicie gdy robie ./configure to wywala mi takie coś:
[root@ozyrys inkscape-0.41]# ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for intltool >= 0.22... 0.31.1 found
checking for perl... /usr/bin/perl
checking for XML::Parser... ok
checking for style of include used by make... GNU
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for library containing strerror... none required
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking dependency style of g++... (cached) gcc3
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for a sed that does not truncate output... /bin/sed
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking how to run the C preprocessor... gcc -E
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... f95
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether f95 accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag  works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for f95 option to produce PIC... -fPIC
checking if f95 PIC flag -fPIC works... yes
checking if f95 supports -c -o file.o... yes
checking whether the f95 linker (/usr/bin/ld) supports shared libraries... yes
checking GNU compiler version... 4.0.0
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for LC_MESSAGES... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for dgettext in libc... yes
checking for bind_textdomain_codeset... yes
checking for msgfmt... /usr/bin/msgfmt
checking for dcgettext... yes
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for catalogs to be installed...  am az be ca cs da de el es es_MX et fr ga gl hu it ja nb nl nn ru sk sl sr sr@Latn sv tr uk pl pt_BR pt zh_CN
checking for pkg-config... /usr/bin/pkg-config
checking for png_read_info in -lpng... yes
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
checking gc.h usability... no
checking gc.h presence... no
checking for gc.h... no
checking gc/gc.h usability... no
checking gc/gc.h presence... no
checking for gc/gc.h... no
configure: error: libgc (the Boehm Conservative Collector) 6.4+, is needed to compile inkscape -- http://www.hpl.hp.com/personal/Hans_Boehm/gc
i jak ja mam to zainstalowac ???
Jest już nowsza wersja:
[y4kk0@X FC-4]$ yum list inkscape
Setting up repositories
Available Packages
inkscape.i386                            0.42-2.fc4             extras
[y4kk0@X FC-4]$
Przeglądając plik spec → http://cvs.fedora.redhat.com/viewcvs/*chec...pec?root=extras wydaje mi się, że powinieneś zrobić:
yum instal gc-devel
yum install inkscape
To co powiedziałeś pomogło do pewnego momentu (bo jednak instaluje tą wersję co instalowałem gdyż to co powiedziałeś z tym yum-em to niby sie zainstalowało ale nie ma nigdzie w systemie.
Teraz po ponownym configure wywala mi taki bład:
[mits@ozyrys ~]$ su Password:
[root@ozyrys mits]# cd /home/mits/Desktop/inkscape-0.41
checking gc.h usability... yes
checking gc.h presence... yes
checking for gc.h... yes
checking for GC_init in -lgc... yes
checking libgc version 6.4+... yes
checking for freetype-config... /usr/bin/freetype-config
checking for Win32 platform... no
checking for xft... yes
checking XFT_CFLAGS... -I/usr/X11R6/include -I/usr/include/freetype2 -I/usr/include/freetype2/config
checking XFT_LIBS... -L/usr/X11R6/lib -lXft -lX11 -lfreetype -lXrender -lfontconfig
checking for pangoft2... yes
checking PANGOFT2_CFLAGS... -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include
checking PANGOFT2_LIBS... -lpangoft2-1.0 -lpango-1.0 -lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0
checking whether byte ordering is bigendian... no
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for Perl development environment... skipped
checking for Python development environment... skipped
checking for gtk+-2.0 >= 2.4.0  libxml-2.0 >= 2.6.0  libxslt >= 1.0.15  sigc++-2.0 >= 2.0.3  gtkmm-2.4  ... Package sigc++-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `sigc++-2.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'sigc++-2.0' found
configure: error: Library requirements (gtk+-2.0 >= 2.4.0  libxml-2.0 >= 2.6.0 libxslt >= 1.0.15  sigc++-2.0 >= 2.0.3  gtkmm-2.4  ) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
i co dalej ??
A bez grafiki wektorowej to jak bez ręki ...
Pokaż co wyświetli:
rpm -q inkscape
Na pewno Ci się zainstlowało? Poaż wszystko co Ci wyświetli:
Nie instaluj nic w systemie ze źródeł jeśli są paczki. Tylko sobie naśmiecisz i coś przestanie Ci w końcu działać...
Po pierwsze: nie kompiluje się programów na koncie roota!
Po drugie: kompilujesz starą wersję <_<
to się nie da :) skoro się zainstalowało, to znaczy, że jest
wpisz do terminala whereis inkscape i się dowiesz gdzie; zapewne nie ma tego w menu, ale można to uruchomić, np. z operacje | uruchom, albo po prostu wpisać inkscape w terminalu, albo zrobić aktywator na pulpicie - multum mozliwości
