Patt Napisano Sierpień 28, 2005 Zgłoszenie Share Napisano Sierpień 28, 2005 Chce zkompilowac GG2, lecz zdaje sie, ze nie mam GTK, zainstalowalem iiimf-gtk-12.2-4.fc4, lecz to nie pomoglo, oto caly 'wykaz': [patt@localhost gg2-2.2.7]$ ./configure checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for awk... awk checking whether make sets $(MAKE)... yes checking for style of include used by make... GNU checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking dependency style of gcc... gcc3 checking how to run the C preprocessor... gcc -E checking for gcc... (cached) gcc checking whether we are using the GNU C compiler... (cached) yes checking whether gcc accepts -g... (cached) yes checking for gcc option to accept ANSI C... (cached) none needed checking dependency style of gcc... (cached) gcc3 checking for a BSD-compatible install... /usr/bin/install -c checking whether ln -s works... yes checking for gmake... /usr/bin/gmake checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking for a sed that does not truncate output... /bin/sed checking for egrep... grep -E checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking how to recognise dependent libraries... pass_all checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking dependency style of g++... gcc3 checking how to run the C++ preprocessor... g++ -E checking for g77... no checking for f77... no checking for xlf... no checking for frt... no checking for pgf77... no checking for fort77... no checking for fl32... no checking for af77... no checking for f90... no checking for xlf90... no checking for pgf90... no checking for epcf90... no checking for f95... f95 checking whether we are using the GNU Fortran 77 compiler... yes checking whether f95 accepts -g... yes checking the maximum length of command line arguments... 32768 checking command to parse /usr/bin/nm -B output from gcc object... ok checking for objdir... .libs checking for ar... ar checking for ranlib... ranlib checking for strip... strip checking if gcc static flag works... yes checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC checking if gcc PIC flag -fPIC works... yes checking if gcc supports -c -o file.o... yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking for shl_load... no checking for shl_load in -ldld... no checking for dlopen... no checking for dlopen in -ldl... yes checking whether a program can dlopen itself... yes checking whether a statically linked program can dlopen itself... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... no configure: creating libtool appending configuration tag "CXX" to libtool checking for ld used by g++... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking for g++ option to produce PIC... -fPIC checking if g++ PIC flag -fPIC works... yes checking if g++ supports -c -o file.o... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking for shl_load... (cached) no checking for shl_load in -ldld... (cached) no checking for dlopen... (cached) no checking for dlopen in -ldl... (cached) yes checking whether a program can dlopen itself... (cached) yes checking whether a statically linked program can dlopen itself... (cached) yes appending configuration tag "F77" to libtool checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... no checking for f95 option to produce PIC... -fPIC checking if f95 PIC flag -fPIC works... yes checking if f95 supports -c -o file.o... yes checking whether the f95 linker (/usr/bin/ld) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking whether /usr/bin/gmake sets $(MAKE)... yes checking for awk... (cached) awk checking for ANSI C header files... (cached) yes checking for ANSI C header files... (cached) yes checking for an ANSI C-conforming const... yes checking whether struct tm is in sys/time.h or time.h... time.h checking whether byte ordering is bigendian... no checking for long long... yes checking for va_copy... yes checking for __va_copy... yes checking for C99-compatible vsnprintf()... yes checking for the pthreads library -lpthreads... no checking whether pthreads work without any flags... no checking whether pthreads work with -Kthread... no checking whether pthreads work with -kthread... no checking for the pthreads library -llthread... no checking whether pthreads work with -pthread... yes checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE checking if more special flags are required for pthreads... no checking for cc_r... gcc checking return type of signal handlers... void checking for strftime... yes checking for vprintf... yes checking for _doprnt... no checking for memset... yes checking for mkdir... yes checking for strcasecmp... yes checking for strchr... yes checking for strlen... yes checking whether to enable maintainer-specific portions of Makefiles... no checking libintl.h usability... yes checking libintl.h presence... yes checking for libintl.h... yes checking whether NLS is requested... yes checking for msgfmt... /usr/bin/msgfmt checking for gmsgfmt... /usr/bin/msgfmt checking for xgettext... /usr/bin/xgettext checking for msgmerge... /usr/bin/msgmerge checking whether we are using the GNU C Library 2 or newer... yes checking for ranlib... (cached) ranlib checking for library containing strerror... none required checking for signed... yes checking for inline... inline checking for off_t... yes checking for size_t... yes checking for long long... yes checking for long double... yes checking for wchar_t... yes checking for wint_t... yes checking for inttypes.h... yes checking for stdint.h... yes checking for intmax_t... yes checking whether printf() supports POSIX/XSI format strings... yes checking for working alloca.h... yes checking for alloca... yes checking for stdlib.h... (cached) yes checking for unistd.h... (cached) yes checking for getpagesize... yes checking for working mmap... yes checking whether we are using the GNU C Library 2.1 or newer... yes checking whether integer division by zero raises SIGFPE... yes checking for unsigned long long... yes checking for inttypes.h... yes checking whether the inttypes.h PRIxNN macros are broken... no checking for stdint.h... (cached) yes checking for SIZE_MAX... yes checking for stdint.h... (cached) yes checking for CFPreferencesCopyAppValue... no checking for CFLocaleCopyCurrent... no checking for ld used by GCC... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for shared library run path origin... done checking for ptrdiff_t... yes checking argz.h usability... yes checking argz.h presence... yes checking for argz.h... yes checking limits.h usability... yes checking limits.h presence... yes checking for limits.h... yes checking locale.h usability... yes checking locale.h presence... yes checking for locale.h... yes checking nl_types.h usability... yes checking nl_types.h presence... yes checking for nl_types.h... yes checking malloc.h usability... yes checking malloc.h presence... yes checking for malloc.h... yes checking stddef.h usability... yes checking stddef.h presence... yes checking for stddef.h... yes checking for stdlib.h... (cached) yes checking for string.h... (cached) yes checking for unistd.h... (cached) yes checking sys/param.h usability... yes checking sys/param.h presence... yes checking for sys/param.h... yes checking for asprintf... yes checking for fwprintf... yes checking for getcwd... yes checking for getegid... yes checking for geteuid... yes checking for getgid... yes checking for getuid... yes checking for mempcpy... yes checking for munmap... yes checking for putenv... yes checking for setenv... yes checking for setlocale... yes checking for snprintf... yes checking for stpcpy... yes checking for strcasecmp... (cached) yes checking for strdup... yes checking for strtoul... yes checking for tsearch... yes checking for wcslen... yes checking for __argz_count... yes checking for __argz_stringify... yes checking for __argz_next... yes checking for __fsetlocking... yes checking whether _snprintf is declared... no checking whether _snwprintf is declared... no checking whether feof_unlocked is declared... yes checking whether fgets_unlocked is declared... no checking whether getc_unlocked is declared... yes checking for iconv... yes checking for iconv declaration... extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft); checking for nl_langinfo and CODESET... yes checking for LC_MESSAGES... yes checking for bison... bison checking version of bison... 2.0, ok checking for CFPreferencesCopyAppValue... (cached) no checking for CFLocaleCopyCurrent... (cached) no checking whether NLS is requested... yes checking whether included gettext is requested... no checking for GNU gettext in libc... yes checking whether to use NLS... yes checking where the gettext function comes from... libc checking for pkg-config... /usr/bin/pkg-config checking for glib-2.0 >= 2.2.0... yes checking GLIB_CFLAGS... -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include checking GLIB_LIBS... -lglib-2.0 checking for gthread-2.0 >= 2.2.0... yes checking GTHREAD_CFLAGS... -pthread -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include checking GTHREAD_LIBS... -pthread -lgthread-2.0 -lglib-2.0 checking for gtk+-2.0 >= 2.2.0... Package gtk+-2.0 was not found in the pkg-config search path. Perhaps you should add the directory containing `gtk+-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'gtk+-2.0' found configure: error: Pozdrawiam... Patt Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
spyro Napisano Sierpień 28, 2005 Zgłoszenie Share Napisano Sierpień 28, 2005 a masz zainstalowane gtk2 i gtk2-devel ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Patt Napisano Sierpień 28, 2005 Autor Zgłoszenie Share Napisano Sierpień 28, 2005 gtk2 mam w systemie, ale znalazlem tego czego nie mam brakowalo mi: gtkspell-devel gtkspell aspell-devel GNUTLS library libtlen loudmouth i tu sie zatrzymuje... teraz wywala mi blad: ... ********************************************************** Jabber plugin need loudmouth! You don't have loudmouth installed (or you have wrong version) Please download loudmouth: http://www.imendio.com/projects/loudmouth/ ********************************************************** ...ale ja mam zainstalowane... najpierw zainstalowalem wersje 1.0.1, ale jak wywalal blad to zainstalowalem starsza 1.0, z mysla, ze moze teraz ruszy... ale nie... nie wiem co robic... P.S Wiekszosc z tego trzeba bylo kompilowac i szukac po necie... juz powoli wysiadam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
kamillys Napisano Sierpień 28, 2005 Zgłoszenie Share Napisano Sierpień 28, 2005 Lepiej zainstaluj gg2 z rpm-a, lub poszukaj yum'em, czy apt-get'em. Fedora nie jest dystrybucją do kompliacji. Pod gentoo sprawa jest prosta i jasna: emerge gnugadu i po sprawie. Na fc powinno być yum install gnugadu lub yum install gg2. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SeeM Napisano Sierpień 28, 2005 Zgłoszenie Share Napisano Sierpień 28, 2005 http://apt.bzium.net/packages/ tu masz wszystkie niezbyt popularne zalezności; co prawda są pod FC3, więc najlepiej by było, jakbyś pościągał pakiety źródłowe (*.src.rpm) i przebudował; czyli rpmbuild --rebuild pakiet.src.rpm i będziesz miał pakiety dla FC4 - co ważne będa to pakiety g2, gg2-devel, gg2-gagugadu, gg2-tlen itd... więc zainstalujesz tylko te, które chcesz i to bez wczytywania się w opcje ./configure osobiście jeśli pakiet mi z jakiegoś powodu nie chce się zainstalować (bo na przykład jest do inej wersji Fedory niż mam) to ściągam pakiet źródłowy i po kłopocie; ta sama sytuacja jest z wykorzystywaniem pakietów rpm ogólnych (niedystrybucyjnych), lub pochodzących z innej dystrybucji (na przykład susłowych, czy mandriwowych), bo czasem nawet z tymi się to udaje Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Patt Napisano Sierpień 28, 2005 Autor Zgłoszenie Share Napisano Sierpień 28, 2005 @kamillys/ niestety, tu sprawa nie jest taka prosta... gg2 z rpm`a zrodlowego jest dostepna tylko w wersji 2.2.4, a najnowsza to 2.2.7 wiec jest rownica spora... w szczegolnosci, ze jestem o krok od ukonczenia... przynajmniej mam nadzieje @SeeM/ http://apt.bzium.net/packages/ tu masz wszystkie niezbyt popularne zalezności; taak... znam ta strone, ale udalo mi sie poznajdywac kody zrodlowe i wszystko kompilowalem i instalowalem... i zainstalowal sie rowniez ten loudmouth ale podczas konfiguracji go nie widzi... i w tym jest problem (on jest zainstalowany bez bledow)... nie wiem co robic dalej... Pozdrawiam... Patt Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Sierpień 28, 2005 Zgłoszenie Share Napisano Sierpień 28, 2005 z rpm`a zrodlowego jest dostepna tylko w wersji 2.2.4, a najnowsza to 2.2.7 A jaki problem przerobić gotową paczkę src.rpm? Uaktualnić źródła i wyedytować plik spec. w szczegolnosci, ze jestem o krok od ukonczenia... ...ukończenia śmiecenia systemu? zainstalowal sie rowniez ten loudmouth ale podczas konfiguracji go nie widzi Jak to zrobiłeś? yum install loudmouth-devel ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Patt Napisano Sierpień 28, 2005 Autor Zgłoszenie Share Napisano Sierpień 28, 2005 @gajownik, dzieki loudmouth-devel brakowalo... a teraz jeszcze chce XOSD library, wiec ide jej szukac i instalowac // edit jeszcze doinstalowalem jeden pakiet i wreszcie ma wszystko dzieki za pomoc... i pozdrawiam... Patt Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Sierpień 28, 2005 Zgłoszenie Share Napisano Sierpień 28, 2005 yum install xosd-devel A tak na przyszłość: jeśli wypluwa komunikaty, że brakuje paczki o nazwie cośtam, to musisz doinstalować cośtam-devel. RPM-y z devel w nazwie zawierają pliki nagłówkowe, biblioteki, itp. podobne rzeczy konieczne do kompilacji programów. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Patt Napisano Sierpień 28, 2005 Autor Zgłoszenie Share Napisano Sierpień 28, 2005 taak... czasami o tym zapominam... wiekszosc z tej listy powyzej wystarczuylo jak znalazlem zrodlo w necie i je skompilowalem i zainstalowalem i bylo dobrze... ale jak widac trzeba sprawdzac wszystko Pozdrawiam... i dzieki... Patt Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kokos Napisano Sierpień 29, 2005 Zgłoszenie Share Napisano Sierpień 29, 2005 Przy wszystkim gdzie będzie zwracać brak składnika należy zainstalować paczkę devel. A wszystkie wymagane paczki devel są w repo Fedory. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
